Apple Grade B AirPods 4 with Active Noise Cancellation
Quicklinx: J0RCWS00 Mfr#: 400021281
Type: Earbuds
Connectivity: Wireless
Colour: White
Hurry, only 2 left in stock!
£99.17 ex VAT
£119.00 inc VAT
Express delivery Order within the next 27 minutes for delivery tomorrow
Grade B returned device
Looking for AirPods, but want to make your money go further? Try one of our Grade B devices and you’ll find amazing deals on some of the latest and greatest devices.
  • 12 months warranty
  • Good condition, showing small signs of wear which includes, but not limited to, small/fine scratches and marks.
AirPods 4 with Active Noise Cancellation — featuring a totally transformed audio experience with Adaptive Audio and Transparency mode,¹ and an updated fit for all-day comfort.
  • Legal
    ¹Device performance and noise control features like Active Noise Cancellation, Adaptive Audio and Transparency can be affected by debris or earwax build up. Clean the device regularly to maintain performance and full feature functionality. Refer to support.apple.com/102672 for AirPods 4 cleaning instructions. ²Feature available only on AirPods 4 with Active Noise Cancellation. ³Available on compatible devices with iOS 18, iPadOS 18 or macOS Sequoia and later when paired with AirPods 4, AirPods 4 with Active Noise Cancellation or AirPods Pro 2 with the latest firmware. 4Siri and activating with just “Siri” may not be available in all languages or in all areas, and features may vary by area. Compatible device and internet access required. Mobile data charges may apply. Activating with just “Siri” is not available on AirPods with the H1 headphone chip and Intel-based Mac computers. Devices must support and have the latest operating system software. 5Requires a compatible Apple device with the latest operating system software. 6Find My functionality requires iOS 18 or later. 7Spatial Audio works with compatible content in supported apps. iPhone with TrueDepth camera required to create personalised profile. 8AirPods 4 with Active Noise Cancellation support wireless charging, which requires a Qi certified wireless charger. AirPods 4 with Active Noise Cancellation charging case also works with the Apple Watch charger or USB C connector. ?Testing conducted by Apple in July and August 2024 using pre-production AirPods 4 (Active Noise Cancellation) with Wireless Charging Case paired with pre-production iPhone 16 Pro Max units, all with pre-release software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256Kb/s AAC encoding). Volume was set to 50%; Spatial Audio, Conversation Awareness and Noise Control were all off. With Noise Control set to Active Noise Cancellation, listening time was up to 4 hours. Testing consisted of full AirPods battery discharge while playing audio until the first AirPod stopped playback. Battery life depends on device settings, environment, usage and many other factors. ¹°Testing conducted by Apple in July and August 2024 using pre-production AirPods 4 (Active Noise Cancellation) with Wireless Charging Case paired with pre-production iPhone 16 Pro Max units, all with pre-release software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256Kb/s AAC encoding). Volume was set to 50%; Spatial Audio, Conversation Awareness and Noise Control were all off. With Noise Control set to Active Noise Cancellation, listening time was up to 20 hours. Testing consisted of full AirPods battery discharge while playing audio until the first AirPod stopped playback. The drained AirPods were charged to 100 per cent, then audio playback was resumed until the first AirPod stopped playback. This cycle was repeated until both the AirPods and charging case were fully discharged. Battery life depends on device settings, environment, usage and many other factors. ¹¹AirPods 4 with Active Noise Cancellation are dust, sweat and water resistant for non-water sports and exercise. Products including charging case were tested under controlled laboratory conditions and have a rating of IP54 under IEC standard 60529. Dust, sweat and water resistance are not permanent conditions and resistance might decrease as a result of normal wear. Do not attempt to charge when wet; refer to https://support.apple.com/kb/HT210711 for cleaning and drying instructions.
Apple AirPods 4 with Active Noise Cancellation - true wireless earphones with mic
True wireless earphones - Bluetooth
Compatibility
iPhone, iPad, iPod, Mac
Recommended Use
Portable electronics
Additional Functions
Spatial audio with dynamic head tracking, wireless audio sharing, adaptive audio, transparency mode, conversation awareness
White
Headphones Form Factor
Ear-bud
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Active Noise Canceling
Microphone Operation Mode
Beamforming
Microphones Included
2
Controls
Play/pause, next/previous track, answer call, reject call, mute, voice assistant
Intelligent Assistant
Siri
Compatible Software
Apple Find My
1-year warranty
True wireless earphones - Bluetooth - wireless
Compatibility
Dimensions & Weight Details
Charging case: 5.01 cm x 2.12 cm x 4.62 cm / 34.7 g
1.83 cm
1.81 cm
3.02 cm
4.3 g
White
Recommended Use
Voice Isolation Technology, automatic device switching
Protection
IP54, dust-resistant, sweat-resistant, water-resistant
Audio Output
Ear-bud
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
AAC-ELD
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Apple H2 chip, Auto Pause, high dynamic range amplifier, high-excursion Apple driver, vent system for pressure equalisation
Microphone
Built-in
Beamforming
2
Remote Control
Controls
Tracking
Sensors
Force sensor, optical sensor, motion-detecting accelerometer, speech-detecting accelerometer
Internet of Things (IoT)
Siri
Wireless charging case with built-in speaker
Compatible Software
Apple Find My
Headphone battery rechargeable
Run Time (Up To)
30 hour(s)
Run Time Details
Continuous playback (active noise-cancelling on): up to 4 hours , Continuous playback (active noise-cancelling off): up to 5 hours , Continuous talk: up to 4.5 hours , Continuous playback (active noise-cancelling on) (with included charging case): up to 20 hours , Continuous playback (active noise-cancelling off) (with included charging case): up to 30 hours , Continuous talk (with included charging case): up to 20 hours , Continuous playback (with 5 min charge): up to 1 hour , Continuous talk (with 5 min charge): up to 45 min
Limited warranty - 1 year
Type: Earbuds
Colour: White
Brand: Apple
Stock Status: While stocks last
Stock Status: Clearance
