Apple Grade A Magic Keyboard iPad Pro 11-inch M4 White
Quicklinx: J0QSWS00 Mfr#: 400020892
  • IEEE 802.11n
£135.00 ex VAT
£162.00 inc VAT
Express delivery Delivered on Tuesday
Magic Keyboard for iPad Pro delivers an amazing typing and trackpad experience in a sleek, portable design with an aluminium palm rest. The keyboard includes a 14-key function row for quick access to screen brightness, volume controls and other features, and a USB-C connector for pass-through charging. The floating cantilever design smoothly adjusts to multiple viewing angles.
A large trackpad with haptic feedback is perfect for precision tasks like editing a spreadsheet and selecting text, or simply navigating your iPad with intuitive and familiar Multi-Touch gestures. And a durable outer cover provides front and back protection, perfect for taking iPad Pro anywhere.
Grade A returned device
Want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
  • 12 months warranty
  • Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
  • SUPERCHARGED BY M3 PRO OR M3 MAX
    The Apple M3 Pro chip, with a 12-core CPU and 18-core GPU using hardware-accelerated ray tracing, delivers amazing performance for demanding workflows like manipulating gigapixel panoramas or compiling millions of lines of code. M3 Max, with an up to 16-core CPU and up to 40-core GPU, drives extreme performance for the most advanced workflows like rendering intricate 3D content or developing transformer models with billions of parameters.
  • UP TO 22 HOURS OF BATTERY LIFE¹
    Go all day thanks to the power-efficient design of Apple silicon. MacBook Pro delivers the same exceptional performance whether it’s running on battery or plugged in.
  • RESPONSIVE UNIFIED MEMORY AND STORAGE
    Up to 36GB (M3 Pro) or up to 128GB (M3 Max) of unified memory makes everything you do fast and fluid. Up to 4TB (M3 Pro) or up to 8TB (M3 Max) of superfast SSD storage launches apps and opens files in an instant.²
  • BRILLIANT PRO DISPLAY
    The 16.2-inch Liquid Retina XDR display³ features Extreme Dynamic Range, 1,000 nits of sustained brightness for stunning HDR content, up to 600 nits of brightness for SDR content and pro reference modes for doing your best work on the go.
  • FULLY COMPATIBLE
    All your pro apps run lightning fast — including Adobe Creative Cloud, Apple Xcode, Microsoft 365, SideFX Houdini, MathWorks MATLAB, Medivis SurgicalAR and many of your favourite iPhone and iPad apps.4 And with macOS, work and play on your Mac are even more powerful. Elevate your presence on video calls. Access information in all-new ways. And discover even more ways to personalise your Mac.
  • ADVANCED CAMERA AND AUDIO
    Look sharp and sound great with a 1080p FaceTime HD camera, a studio-quality three-mic array and a six-speaker sound system with Spatial Audio.
  • CONNECT IT ALL
    This MacBook Pro features a MagSafe charging port, three Thunderbolt 4 ports, an SDXC card slot, an HDMI port and a headphone jack. Enjoy fast wireless connectivity with Wi-Fi 6E5 and Bluetooth 5.3. And you can connect up to two external displays with M3 Pro, or up to four with M3 Max.
  • MAGIC KEYBOARD WITH TOUCH ID
    The backlit Magic Keyboard has a full-height function key row and Touch ID, which gives you a fast, easy, secure way to unlock your laptop and sign in to apps and sites.
  • ADVANCED SECURITY
    Every Mac comes with encryption, robust virus protections and a powerful firewall system. And free security updates help keep your Mac protected.
  • WORKS WITH ALL YOUR APPLE DEVICES
    You can do amazing things when you use your Apple devices together. Copy something on iPhone and paste it on MacBook Pro. Use your MacBook Pro to answer FaceTime calls or send texts with Messages.6 And that’s just the beginning.
  • BUILT TO LAST
    The all-aluminium unibody enclosure is exceptionally durable and comes in Space Black and Silver. Free software updates keep things running smoothly for years to come.
  • Legal
    *Configurable options are available.¹Battery life for Apple TV app movie playback. Battery life varies by use and configuration. See apple.com/uk/batteries for more information.²1GB = 1 billion bytes and 1TB = 1 trillion bytes; actual formatted capacity less.³The display on the 16-inch MacBook Pro has rounded corners at the top. When measured as a standard rectangular shape, the screen is 16.2 inches diagonally (actual viewable area is less).4Apps are available on the App Store.5Wi Fi 6E available in countries and regions where supported.6Requires iCloud and internet connection.
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: J0QS 051229
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £109.53
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Apple
Stock Status: While stocks last
Stock Status: Used Stock
Stock Status: Clearance
