Apple Final Cut Express 4.0
Quicklinx: 502RWS00 Mfr#: MB278Z/A
Apple's powerful moviemaking package now supports the latest AVCHD cameras, features an open format Timeline, provides iMovie '08 compatibility, and offers sophisticated effects and filters.
Offering plenty of creative options, Final Cut Express 4 lets you edit footage captured in the most popular formats - including AVCHD. Simply connect your camcorder to your Mac, preview and select the AVCHD clips you'd like to import, and start editing your video.
No need to worry about formats, frame rates, or conversions. Final Cut Express 4 provides an open format Timeline that handily accommodates DV (both NTSC and PAL) and HD footage simultaneously and in real time. Just drop video into the Timeline and edit away.
With iMovie '08, putting together a great movie is as quick as drag and drop. When you want to add professional polish to your project, simply export to Final Cut Express 4 and edit like a pro.
Add cinematic looks to your project with an expansive library of professional-quality transitions and filters and experiment with over 50 brand-new video effects, including Soft Focus, Vignette, Light Rays, and Line Art.
Use multiple audio tracks, audio level automation, advanced audio filters, and the new Soft Normalize and Gain feature to achieve pro results easily. Learn more
Mix different video formats in the new open format Timeline, editing them in real time using the same precision tools found in Final Cut Pro.
Add dynamic animated text to your video projects using LiveType with its exclusive LiveFont animated font technology and huge library of textures and effects.
Create impressive composites and easily enhance video with sophisticated transitions, filters, and effects, including a wide assortment of FxPlug plug-ins.
Final Cut Express (v. 4) - box pack - 1 user
Box pack
Category
Creativity application - video editing & production
Version
4
Licence Qty
1 user
Platform
MacOS
Distribution Media
DVD-ROM
Category
Box pack
Version
4
Platform
MacOS
Distribution Media
DVD-ROM
Licencing
Licence Qty
1 user
Supported OS
Apple MacOS X 10.4.10 or later
Hardware Requirements
PowerPC G4 - 1.25 GHz - RAM 1 GB - HD 500 MB
Additional Requirements
DVD-ROM, QuickTime 7.2 or later
