This USB 2.0 cable connects your iPod, iPhone, or iPad - directly or through a dock - to your computer's USB port for efficient syncing and charging or to the Apple USB power adapter for convenient charging from a wall outlet.
Efficient charging and data transfer
Designed to connect specifically to iPod, iPhone, or iPad, this Apple Dock Connector to USB Cable ensures efficient charging and data transfer. It supports USB 2.0 for high-speed data exchange, making it ideal for syncing your device to your computer or charging through a USB power adapter. -
Durable design
Featuring a robust Apple Dock connector on one end and a 4-pin USB Type-A connector on the other, this cable is built to withstand daily use while maintaining reliable connectivity. The male connectors on both ends ensure a secure connection between your device and the charging or data transfer source.
- Apple Dock Connector to USB Cable - charging / data cable
- Cable
- Charging / data cable
- Connector
- Apple Dock - male
- Connector (Second End)
- USB - male
- Cable Type
- Connector
- Apple Dock connector - male
- 4 pin USB Type A - male
