Lose your knack for losing things.
AirTag is an easy way to keep track of your stuff. Attach one to your keys, slip another one in your backpack. And just like that, they’re on your radar in the Find My app. AirTag has your back.
Legal
¹Testing conducted by Apple in March 2021 using preproduction AirTag units and software paired with iPhone 11, iPhone 11 Pro, iPhone 11 Pro Max, iPhone 12 mini, iPhone 12, iPhone 12 Pro, and iPhone 12 Pro Max units running preproduction software. Battery life based on an everyday use of four play sound events and one Precision Finding event per day. Battery life varies with usage, environmental conditions, replacement battery manufacturer, and many other factors; actual results will vary. ²AirTag is splash, water, and dust resistant and was tested under controlled laboratory conditions with a rating of IP67 under IEC standard 60529 (maximum depth of 1 meter up to 30 minutes). Splash, water, and dust resistance are not permanent conditions and resistance might decrease as a result of normal wear. Refer to the Safety and Handling documentation for cleaning and drying instructions.
 - Apple AirTag - anti-loss Bluetooth tag for mobile phone, tablet
- Product Type
 - Anti-loss Bluetooth tag
- Packaged Quantity
 - 4 (specifications are for single item)
- Intended For
 - Mobile phone, tablet
- Integrated Components
 - Accelerometer, speaker
- Wireless Interface
 - Bluetooth, NFC
- Protection
 - Splashproof, water-resistant, dust-resistant
- Battery
 - CR2032
- Run Time (Up To)
 - 1 year
- Product Material
 - Stainless steel
 - 3.19 cm x 3.19 cm x 0.8 cm
 - 11 g
- Designed For
 - iPhone/iPad/iPod
- Packaged Quantity
- Product Type
- Intended For
 - Bluetooth, NFC
- Protection
- Product Material
 - Stainless steel
 - 3.19 cm
 - 3.19 cm
 - 0.8 cm
 - 11 g
- Form Factor
 - CR2032
- Run Time (Up To)
 - 1 year
 - IP67
- Designed For
 - iPhone/iPad/iPod
