Apple AirPods with Charging Case - 2nd Gen
Quicklinx: FJLMBTBS Mfr#: MV7N2ZM/A
Type: Earbuds
Connectivity: Wireless
Colour: White
Sorry but this product has been discontinued.
View used stock
More magical than ever.
Now with more talk time and voice-activated Siri access AirPods deliver an unparalleled wireless headphone experience. Simply take them out and they’re ready to use with all your devices. Put them in your ears and they connect immediately, immersing you in rich, high-quality sound. Just like magic.
Wireless to the fullest.
After a simple one-tap setup, AirPods are automatically on and always connected. Using them is just as easy. They sense when they’re in your ears and pause when you take them out. And the AirPods experience is just as amazing whether you’re using them with your iPhone, Apple Watch, iPad, or Mac.
Just ask Siri.
Talking to your favourite personal assistant is easier than ever. Simply say "Hey Siri" for assistance without having to reach for your iPhone.
Performance you’ll want to hear.
Powered by the all-new Apple H1 headphone chip, AirPods deliver a faster and more stable wireless connection to your devices — up to 2x faster when switching between active devices, and a 1.5x faster connection time for phone calls. The H1 chip also drives voice-enabled Siri access and delivers up to 30 per cent lower gaming latency.So whether you’re playing games, listening to music or enjoying podcasts, you’ll experience higher-quality sound.
  • Legal
    ¹Spatial Audio works with movies, TV and video in supported apps. iPhone with TrueDepth camera required to create personalised profile.²Battery life depends on device settings, environment, usage and many other factors.³AirPods (3rd generation) are sweat and water resistant for non-water sports and exercise, and they are IPX4 rated. Sweat and water resistance are not permanent conditions.4Siri may not be available in all languages or in all areas, and features may vary by area. Internet access required. Mobile data charges may apply.5Requires an iCloud account and a compatible Apple device with the latest operating system software.6Requires a compatible Apple device running the latest operating system software.
Apple AirPods with Charging Case 2nd generation - true wireless earphones with mic
True wireless earphones - Bluetooth
Compatibility
iPhone, iPad, iPod, Mac
Recommended Use
Portable electronics
Headphones Form Factor
Ear-bud
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Controls
Volume, answer/end, next/previous track
Intelligent Assistant
Siri
True wireless earphones - Bluetooth - wireless
Product Generation
2nd generation
Compatibility
Dimensions & Weight Details
Charging case: 4.43 cm x 2.13 cm x 5.35 cm / 38 g
1.65 cm
1.8 cm
4.05 cm
4 g
Recommended Use
Audio Output
Ear-bud
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Apple H1 chip
Microphone
Built-in
Remote Control
Controls
Tracking
Sensors
Dual optical sensors, motion-detecting accelerometer, speech-detecting accelerometer
Internet of Things (IoT)
Siri
Charging case, Lightning cable
Auto On/Off
Headphone battery rechargeable
Run Time (Up To)
5 hour(s)
Run Time Details
Continuous playback: up to 5 hours , Continuous talk: up to 3 hours
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FJLM 050984
Condition: Customer return - item has been repaired under warranty by the manufacturer
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £82.36
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Earbuds
Colour: White
Brand: Apple
Stock Status: Used Stock
Stock Status: Clearance
