Apple AirPods Pro With Wireless Case
Quicklinx: FHC2WS00 Mfr#: MWP22ZM/A
Accessory Type: Headphones
Connectivity: Wireless
Colour: White
More than 50 in stock
£158.33 ex VAT
£189.99 inc VAT
Express delivery Order within the next 6 hours for delivery tomorrow
AirPods Pro have been designed to deliver Active Noise Cancellation for immersive sound, Transparency mode so you can hear your surroundings and a customizable fit for all-day comfort. Just like AirPods, AirPods Pro connect like magic to your iPhone or Apple Watch. And they're ready to use straight out of the case.
  • Active Noise Cancellation
    Incredibly light noise-canceling headphones, AirPods Pro block out your environment so you can focus on what you're listening to. AirPods Pro use two microphones, an outward-facing microphone and an inward-facing microphone, to create superior noise cancellation. By continuously adapting to the geometry of your ear and the fit of the ear tips, Active Noise Cancellation silences the world to keep you fully tuned in to your music, podcasts and calls.
  • Transparency mode
    Switch to Transparency mode and AirPods Pro let outside sound in, allowing you to hear and connect to your surroundings. Outward- and inward-facing microphones enable AirPods Pro to undo the sound-isolating effect of the silicone tips so things sound and feel natural, like when you're talking to people around you.
  • Amazing audio quality
    A custom-built high-excursion, low-distortion driver delivers powerful bass. A super-efficient high dynamic range amplifier produces pure, incredibly clear sound while also extending battery life. And Adaptive EQ automatically tunes music to suit the shape of your ear for a rich, consistent listening experience.
  • Even more magical
    The Apple-designed H1 chip delivers incredibly low audio latency. A force sensor on the stem makes it easy to control music and calls, and switch between Active Noise Cancellation and Transparency mode. Announce Messages with Siri gives you the option to have Siri read your messages through your AirPods. And with Audio Sharing, you and a friend can share the same audio stream on two sets of AirPods - so you can play a game, watch a film or listen to a song together.
Apple AirPods Pro - true wireless earphones with mic
True wireless earphones - Bluetooth
Compatibility
iPhone, iPad, iPod, Mac
Recommended Use
Portable electronics
Additional Functions
Wireless audio sharing
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Active Noise Canceling
Controls
Answer/end, play/pause, next/previous track, audio transparency, ANC on/off
Intelligent Assistant
Siri
10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 10.9-inch iPad Air; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iMac; iMac Pro; iPad Air 2; iPad mini; iPad mini 2; 4; 5; iPhone 11, 12, 5c, 6s, 7, 8, SE, X, XR, XS, XS Max; MacBook Air; MacBook Pro; TV 4K, HD
True wireless earphones - Bluetooth - wireless
Compatibility
Dimensions & Weight Details
Charging case: 6.06 cm x 2.17 cm x 4.52 cm / 45.6 g
2.18 cm
2.4 cm
3.09 cm
5.4 g
Recommended Use
Protection
IPX4
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Apple H1 chip
Microphone
Built-in
Remote Control
Controls
Tracking
Sensors
Dual optical sensors, motion-detecting accelerometer, speech-detecting accelerometer, force sensor
Internet of Things (IoT)
Siri
3 pairs of silicone ear tips, wireless charging case, Lightning to USB-C cable
Auto On/Off
Headphone battery rechargeable
Run Time (Up To)
4.5 hour(s)
Run Time Details
Continuous playback: up to 4.5 hrs , Continuous talk: up to 3.5 hrs
Apple 10.2-inch iPad (7th generation, 8th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation, 5th generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iMac (Early 2019, Mid 2017) , Apple iMac Pro (Late 2017) , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad mini 5 , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod touch (7G) , Apple Mac mini (Early 2020, Late 2018, Late 2020) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2020, Late 2018, Late 2020, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Late 2020, Mid 2017, Mid 2018, Mid 2019) , Apple TV 4K, HD , Apple Watch
FHC2 Apple Lightning to USB Cable (0.5m) In Stock £18.83
FHC2 Apple Lightning to USB Cable (2 m) In Stock £28.77
FHC2 Apple USB-C to Lightning Cable 2m In Stock £31.57
FHC2 Apple Lightning to USB Cable (1m) In Stock £17.14
FHC2 Apple MagSafe Charger In Stock £31.94
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FHC2 044767
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £155.27
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Colour: White
Brand: Apple
Stock Status: In stock
Stock Status: Used Stock
