Brand
Active Noise Cancellation for immersive sound. Transparency mode for hearing what's happening around you. A customizable fit for all-day comfort. Magic like you've never heard.
  • Unheard-of sound on every level
    The H2-powered AirPods Pro feature Adaptive Audio, automatically prioritizing sounds that need your attention as you move through the world. By seamlessly blending Active Noise Cancellation with Transparency mode when you need it, Adaptive Audio magically delivers the right mix of sound for any environment. Noise-canceling microphones and a rear vent are optimally placed to quickly detect sound coming in, working together to counter noise before it reaches your ear. Driver and acoustic algorithms help Active Noise Cancellation reduce more unwanted noise. With control over what you hear - and don't hear - you can immerse yourself in music and podcasts, or simply stay focused, like never before. Four pairs of silicone tips are included to fit a wide range of ears. The tips secure AirPods Pro in place and create an acoustic seal that closes in the sound. Transparency mode harnesses the power of H2 to minimize the intensity of loud noises like sirens or power tools - so you can comfortably hear the world around you. Personalized Volume uses machine learning to understand your listening preferences in different environments, and automatically adapts sound based on your patterns over time. When you're wearing AirPods Pro and need to speak with someone nearby, Conversation Awareness automatically lowers the volume of what's playing, enhances voices in front of you and reduces background noise.
  • A higher level of control
    Touch control lets you manage playback functions from the stem. Swipe up or down to adjust volume, press to play and pause music or mute and unmute yourself on calls, and press twice to end a call. You can also hold the stem to switch between listening modes.
  • Sound tuned to you
    AirPods Pro take the listening experience to the next level of individuality. Personalized Spatial Audio with dynamic head tracking works with all your devices to immerse you deeper in all-around-you sound. And Adaptive EQ accounts for the fit of AirPods Pro, so you hear every frequency just as it was intended. To play sound that better suits your unique ear shape, Personalized Spatial Audio works with the TrueDepth camera on your iPhone to create a custom profile based on your head's geometry. The profile syncs across your devices - delivering phenomenal sound every way you listen. Dynamic head tracking brings three-dimensional audio to Group FaceTime calls, so conversations feel like you're in the same room as your friends and family. Adaptive EQ tunes music to your ears in real time, based on the fit of AirPods Pro. Inward-facing microphones measure what you're hearing, then adjust the low to high frequencies of a song - so you get consistently detailed playback, every time.
  • A case of unmistakable power
    The MagSafe Charging Case is loaded with features that make listening on the move especially convenient. An updated design offers more ways to keep track of the case, and extended battery life lets you listen, watch and talk longer between charges. You won't find a more capable case. Recharge the MagSafe Charging Case with a USB-C connector, Apple Watch charger or MagSafe charger. You can also use a Qi-certified charger. The U1 chip enables Find My with Precision Finding for your case, so you can locate it exactly. You can also use Find My with proximity view if you lose track of your AirPods Pro. A lanyard loop allows you to attach the case to a backpack or handbag, so immersive sound is always within reach. The case's built-in speaker plays sound to help you easily locate it, and alert tones let you know when the battery is low, or pairing is complete. Both AirPods Pro and the MagSafe Charging Case are IP54 dust-, sweat- and water-resistant.
  • Simplicity on a grand scale
    From instant setup to Siri commands, AirPods Pro hold all the qualities that make the AirPods family so magical. And thoughtful features give you the ability to move through more tasks with unprecedented ease.
  • Easy, magical setup
    Place AirPods Pro near your iPhone and tap Connect to seamlessly pair with every device in your iCloud account.
  • Audio sharing
    Easily share a song or show between any two sets of AirPods. Simply bring AirPods near the iPhone, iPad or Apple TV you're listening to and connect instantly.
  • Always-on Siri
    Play music, make calls, get directions or check your schedule simply by using your voice. Just say "Siri" or "Hey Siri" to activate your favorite personal assistant and stay on top of everyday tasks.
  • Seamless switching
    Automatic Switching is now significantly faster and more reliable between your iPhone, iPad and Mac, and easily moves to your Apple Watch. So, if you're playing music on your Mac, you can answer a call on your iPhone - without having to switch devices.
  • AirPods and accessibility
    AirPods Pro go beyond the listening experience to assist with selected hearing needs. Features like Conversation Boost bring focus to voices directly in front of you. Headphone Accommodations amplify frequencies you may need to hear clearly. And if you need to focus on a guest speaker in a bustling auditorium, Live Listen works with your iPhone to pick up sound at a distance.
  • Announce notifications
    Siri can read your important messages or alerts as they arrive - and you can reply to messages with just your voice.
Apple AirPods Pro 2nd generation - true wireless earphones with mic
True wireless earphones - Bluetooth
Compatibility
iPhone, iPad, iPod, Mac
Recommended Use
Portable electronics
Additional Functions
Wireless audio sharing
White
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Active Noise Canceling
Microphone Operation Mode
Beamforming
Controls
Volume, answer/end, play/pause, next/previous track, voice assistant, ANC/transparency
Intelligent Assistant
Siri
1-year warranty
True wireless earphones - Bluetooth - wireless
Product Generation
2nd generation
Compatibility
Dimensions & Weight Details
Charging case: 6.06 cm x 2.17 cm x 4.52 cm / 50.8 g
2.18 cm
2.4 cm
3.09 cm
5.3 g
White
Recommended Use
Protection
Sweat-resistant, IPX4, water-resistant
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Apple H2 chip, Adaptive Transparency technology, vent system for pressure equalisation, MagSafe charging case with Precision Finding, MagSafe charging case with Apple U1 chip
Microphone
Built-in
Beamforming
Remote Control
Controls
Tracking
Sensors
Motion-detecting accelerometer, speech-detecting accelerometer, skin-detecting sensors, touch control
Internet of Things (IoT)
Siri
4 pairs of silicone ear tips (extra small, small, medium, large), Lightning to USB-C cable, MagSafe charging case with speaker and lanyard loop
Cable Details
USB-C to Lightning cable
Auto On/Off
Headphone battery rechargeable - wireless charging
Wireless Charging Standards
Qi
Run Time (Up To)
6 hour(s)
Run Time Details
Continuous playback (active noise-cancelling on): up to 6 hours , Continuous playback (personalised spatial audio, head tracking on): up to 5.5 hours , Continuous talk: up to 4.5 hours , Continuous playback (active noise-cancelling on) (with included charging case): up to 30 hours , Continuous talk (with included charging case): up to 24 hours
Limited warranty - 1 year
GZLB Apple Lightning to USB Cable (0.5m) In Stock £18.75
GZLB Apple Lightning to USB Cable (2 m) In Stock £29.17
GZLB Apple Lightning to USB Cable (1m) In Stock £15.70
GZLB Apple USB-C 20W Power Adapter In Stock £15.00
GZLB Apple MagSafe Charger In Stock £35.84
GZLB Apple MagSafe Duo Charger - Wireless charging mat In Stock £90.84
GZLB Apple USB-C to Lightning Cable (1 m) In Stock £14.34
GZLB Apple USB-C to Lightning Cable 2m In Stock £26.59
