Apple AirPods Max - Starlight
Quicklinx: HVYSWS00 Mfr#: MWW53ZM/A
Type: Headphones
Connectivity: Wireless
Colour: Starlight
Colours:
15 In Stock
£412.50 ex VAT
£495.00 inc VAT
Express delivery Order within the next 11 hours for delivery tomorrow
AirPods Max, the ultimate listening experience. Now in five new colours. An Apple-designed driver provides high-fidelity audio. Every detail, from canopy to cushions, has been designed for an exceptional fit. Pro-level Active Noise Cancellation1 blocks outside noise, while Transparency mode keeps you connected to your environment. Updated with a USB-C connector for even more convenient charging.?
  • ULTIMATE OVER-EAR LISTENING EXPERIENCE — Apple-designed dynamic driver provides high-fidelity audio. Computational audio combines custom acoustic design with the Apple H1 chip and software for breakthrough listening experiences.
  • FIVE FRESH COLOURS — AirPods Max come in five fresh colours: Midnight, Starlight, Blue, Purple and Orange. A colour-matched Smart Case is also included.
  • FOCUS ON WHAT’S PLAYING — Pro-level Active Noise Cancellation removes up to 2x more background noise, so you can immerse yourself in music.1
  • HEAR THE WORLD AROUND YOU — Transparency mode lets you comfortably hear and interact with the world around you.
  • PERSONALISED SPATIAL AUDIO — With sound that suits your unique ear shape along with dynamic head tracking, AirPods Max deliver an immersive listening experience that places sound all around you. You can also listen to selected songs, shows and movies in Dolby Atmos.2
  • ACOUSTIC-FIRST DESIGN — Designed with a knitted-mesh canopy and memory foam ear cushions for an exceptional over-ear fit that perfectly seals in sound.
  • MAGICAL EXPERIENCE — Pair AirPods Max by simply placing them near your device and tapping Connect on your screen. AirPods Max pause audio when you take them off. And Automatic Switching makes listening between your iPhone, iPad and Mac completely effortless.3
  • PRECISION CONTROL — Use the Digital Crown to play and pause music; to answer, end and mute yourself on calls; and to control volume and skip between tracks.
  • NOW WITH USB-C CHARGING — The new USB-C connector lets you charge your AirPods Max with the same cable you use to charge your iPhone, iPad, Mac or other Apple devices.
1Up to 2x more Active Noise Cancellation compared with AirPods?Pro (1st?generation) and AirPods?4 with Active Noise Cancellation.
2Spatial Audio works with compatible content in supported apps. iPhone with TrueDepth camera required to create personalised profile.
3Requires an iCloud account and a compatible Apple device with the latest operating system software.
  • FOCUS ON WHAT'S PLAYING
  • PRECISION CONTROL
Apple AirPods Max 2nd generation - headphones with mic
Headphones - Bluetooth - wireless
Compatibility
iPhone, iPad, Mac, iPod
Recommended Use
Portable electronics, computer
Additional Functions
Spatial audio with dynamic head tracking, transparency mode, wireless audio sharing
Starlight
Headphones Form Factor
Full size
Wireless
Wireless Technology
Bluetooth
Headphones Technology
Dynamic
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Active Noise Canceling
Microphones Included
9
Controls
Volume, play/pause, answer call, reject call, mute, next/previous track, voice assistant, ANC/transparency
Intelligent Assistant
Siri
1-year warranty
Product Generation
2nd generation
Compatibility
Dimensions & Weight Details
Headphones: 16.86 cm x 8.34 cm x 18.73 cm / 386.2 g , Case: 134.5 g
16.86 cm
8.34 cm
18.73 cm
386.2 g
Starlight
Recommended Use
Automatic device switching, fast charge
Audio Output
Full size
Dynamic
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Sound Effects
Adaptive EQ
Active Noise Cancelling Technology
Adjustable Headband
Apple H1 chip
Microphone
Built-in
9
Remote Control
Controls
Tracking
Sensors
Gyroscope, accelerometer, optical sensor, position sensor, case-detect sensor
Internet of Things (IoT)
Siri
Smart case, USB-C charging cable
Cable Details
USB-C charge cable - detachable
Headphone battery rechargeable
Run Time (Up To)
20 hour(s)
Run Time Details
Continuous playback (active noise-cancelling on): up to 20 hours , Continuous playback (spatial audio on): up to 20 hours , Continuous talk: up to 20 hours , Continuous playback (with 5 min charge): up to 1.5 hours
Limited warranty - 1 year
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: HVYS 050517
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £253.59
Ref: HVYS 050552
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £237.49
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Headphones
Colour: Starlight
Brand: Apple
Stock Status: Used Stock
