Introducing AirPods Max — a perfect balance of exhilarating high-fidelity audio and the effortless magic of AirPods. The ultimate personal listening experience is here.
The over-ear headphone has been completely reimagined. From cushion to canopy, AirPods Max are designed for an uncompromising fit that creates the optimal acoustic seal for many different head shapes — fully immersing you in every sound.
AirPods Max combine high-fidelity audio with industry-leading Active Noise Cancellation to deliver an unparalleled listening experience. Each part of their custom-built driver works to produce sound with ultra-low distortion across the audible range. From deep, rich bass to accurate mids and crisp, clean highs, you’ll hear every note with a new sense of clarity.
With a powerful Apple-designed H1 chip in each cup, our custom acoustic design and advanced software, AirPods Max use computational audio to create a breakthrough listening experience. By tapping into each chip’s 10 audio cores, computational audio helps block outside noise, adapts audio to the fit and seal of your ear cushions, and makes movie scenes sound like they’re happening all around you.
A radically original composition
The over-ear headphone has been completely reimagined. From cushion to canopy, AirPods Max are designed for an uncompromising fit that creates the optimal acoustic seal for many different head shapes - fully immersing you in every sound. The canopy spanning the headband is made from a breathable knit mesh, distributing weight to reduce on-head pressure. The stainless steel frame is wrapped with a soft-to-the-touch material for a remarkable combination of strength, flexibility, and comfort. Telescoping arms smoothly extend and stay where you set them, for a consistent fit and seal. The beautifully anodized aluminum cups feature a revolutionary mechanism that allows each cup to rotate independently and balance pressure. A custom-designed mesh textile wraps the ear cushions to provide pillow-like softness while listening. Crafted with acoustically engineered memory foam, the ear cushions gently create an immersive seal that is the foundation of incredible sound. The Digital Crown lets you precisely control volume, skip between tracks, answer phone calls, and activate Siri. -
Sounds like an epiphany
AirPods Max combine high-fidelity audio with Active Noise Cancellation to deliver an unparalleled listening experience. Each part of their custom-built driver works to produce sound with ultra-low distortion across the audible range. From deep, rich bass to accurate mids and crisp, clean highs, you'll hear every note with a new sense of clarity. -
Immersive listening
To cancel unwanted external sound, AirPods Max use a total of six outward-facing microphones to detect noise in your environment, and two inward-facing microphones to measure what you're hearing. Beamforming microphones help isolate your voice on phone calls, so it's heard clearly - even in windy situations. -
Hear every detail
The Apple-designed dynamic driver produces a wide frequency range that uncovers the rich details of every sound - delivering your favorite songs with previously unheard texture and accuracy. -
Distortionless playback
Modeled after those in high-end floor-standing speakers, the driver's dual-neodymium ring magnet motor minimizes total harmonic distortion across the entire audible range. The result is consistently clear playback, even at full volume. -
Computational audio - key to performance
With a powerful Apple-designed H1 chip in each cup, the custom acoustic design, and advanced software, AirPods Max use computational audio to create a breakthrough listening experience. By tapping into each chip's 10 audio cores, computational audio helps block outside noise, adapts audio to the fit and seal of your ear cushions, and makes movie scenes sound like they're happening all around you. The Active Noise Cancellation counters external sound with equal anti-noise, allowing you to immerse yourself in what you're listening to. Press the noise control button to switch to Transparency mode, which lets outside sound in so you can interact naturally with your surroundings. Adaptive EQ tailors sound to the bespoke fit and seal created by the ear cushions. Inward-facing microphones measure what you're hearing, then adjust the frequencies of your music to deliver a rich, consistent experience that faithfully reproduces every note. -
Spatial audio with dynamic head tracking
Spatial audio with dynamic head tracking gives you a theater-like experience for movies and shows, with sound that surrounds you. Using built-in gyroscopes and accelerometers, AirPods Max and your iPhone or iPad track the subtle motion of your head, anchoring sounds to your device. -
Magical experience, elaborately simple
AirPods Max inherit all of the wireless, effortless magic of the AirPods family. From setup to Siri commands, they make the listening experience completely fluid - day to day, device to device. -
One-tap setup
AirPods Max connect immediately to your iPhone or iPad. To pair, simply place AirPods Max near your device and tap Connect on your screen. -
Seamless switching
Seamlessly move between your iPhone, iPad, and Mac. If you're playing music on your Mac and take a call on your iPhone, AirPods Max will automatically switch over. -
Audio Sharing
Easily share an audio stream between two sets of AirPods on your iPhone, iPad, iPod touch, or Apple TV. Bring any AirPods near the device you're listening to and connect in a tap. -
On-head detection
AirPods Max pause audio when you take them off, and resume playback when you put them back on. So you never miss a beat. -
Announce Messages
Let Siri speak incoming messages as they arrive with Announce Messages. You can even tell Siri to respond - no hands required. -
Always-on Siri
Get directions, check the weather, schedule a meeting, and more with a simple "Hey Siri." With an expansive set of commands, your favorite personal assistant is more helpful than ever. -
A battery that keeps staying alive
20 hours of listening, movie watching, or talk time - with Active Noise Cancellation and spatial audio enabled. Simply charge via Lightning connector. A quick 5-minute charge delivering 1.5 hours of listening.
- Apple AirPods Max - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless
- Compatibility
- iPhone, iPad, iPod, Mac
- Recommended Use
- Portable electronics, computer
- Additional Functions
- Wireless audio sharing, transparency mode, spatial audio with dynamic head tracking
- Space grey
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- Adaptive EQ
- Active Noise Canceling
- Microphones Included
- 9
- Controls
- Volume, play/pause, next/previous track, voice assistant, answer call, ANC/transparency
- Intelligent Assistant
- Siri
- 1-year warranty
- Product Type
- Compatibility
- Dimensions & Weight Details
- Headphones: 16.86 cm x 8.34 cm x 18.73 cm / 384.8 g , Case: 134.5 g
- 16.86 cm
- 8.34 cm
- 18.73 cm
- 384.8 g
- Space grey
- Body Material
- Stainless steel, anodised aluminium
- Headband Material
- Knit mesh
- Earpad Material
- Memory foam, mesh textile
- Recommended Use
- On-ear detection
Audio Output
- Full size
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- Adaptive EQ
- Magnet Material
- Neodymium magnet
- Adjustable Headband
- Apple H1 chip
Microphone
- Form Factor
- Built-in
- 9
Remote Control
- Controls
Tracking
- Sensors
- Accelerometer, gyro sensor, position sensor, optical sensor, case-detect sensor
Internet of Things (IoT)
- Siri
- Included Accessories
- Charging case, Lightning to USB-C cable
- Cable Details
- USB-C to Lightning cable - detachable
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 20 hour(s)
- Run Time Details
- Continuous playback (active noise-cancelling on): up to 20 hours , Continuous playback (spatial audio on): up to 20 hours , Continuous talk: up to 20 hours
- Limited warranty - 1 year
Apple Lightning to USB Cable (0.5m) | In Stock | £18.75 |
Apple Lightning to USB Cable (2 m) | In Stock | £29.17 |
Apple Lightning to USB Cable (1m) | In Stock | £17.41 |
Apple USB-C 20W Power Adapter | In Stock | £15.00 |
Apple USB-C to Lightning Cable (1 m) | In Stock | £14.33 |
Apple USB-C to Lightning Cable 2m | In Stock | £26.59 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
G31Z 048319 Condition: Customer return - item has been opened but is in excellent condition |
£366.39 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
