Introducing AirPods Max — a perfect balance of exhilarating high-fidelity audio and the effortless magic of AirPods. The ultimate personal listening experience is here.
The over-ear headphone has been completely reimagined. From cushion to canopy, AirPods Max are designed for an uncompromising fit that creates the optimal acoustic seal for many different head shapes — fully immersing you in every sound.
AirPods Max combine high-fidelity audio with industry-leading Active Noise Cancellation to deliver an unparalleled listening experience. Each part of their custom-built driver works to produce sound with ultra-low distortion across the audible range. From deep, rich bass to accurate mids and crisp, clean highs, you’ll hear every note with a new sense of clarity.
With a powerful Apple-designed H1 chip in each cup, our custom acoustic design and advanced software, AirPods Max use computational audio to create a breakthrough listening experience. By tapping into each chip’s 10 audio cores, computational audio helps block outside noise, adapts audio to the fit and seal of your ear cushions, and makes movie scenes sound like they’re happening all around you.
Good to know
- You'll be heard loud and clear on phone calls thanks to beamforming mics which isolate your voice, even on windy days
- They create an acoustic seal around your ears to fully immerse you in sound
- Your music automatically pauses when you remove the headphones and resumes when you put them back on
- A simple "Hey Siri" summons your voice assistant without lifting a finger - control your music, calls, volume and more
- One-tap setup lets you easily pair with and switch between all your Apple devices
- A quick 5-minute charge gives you up to 1.5 hours of playback - perfect when you're in a rush
Legal
¹Spatial Audio works with movies, TV and video in supported apps. iPhone with TrueDepth camera required to create personalised profile. ²Battery life depends on device settings, environment, usage and many other factors. ³Siri may not be available in all languages or in all areas, and features may vary by area. Internet access required. Mobile data charges may apply. 4Requires an iCloud account and a compatible Apple device with the latest operating system software. 5Requires a compatible Apple device running the latest operating system software.
- Apple AirPods Max - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless
- Compatibility
- iPhone, iPad, iPod, Mac
- Recommended Use
- Portable electronics, computer
- Additional Functions
- Wireless audio sharing, transparency mode, spatial audio with dynamic head tracking
- Silver
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- Adaptive EQ
- Active Noise Canceling
- Microphones Included
- 9
- Controls
- Volume, play/pause, next/previous track, voice assistant, answer call, ANC/transparency
- Intelligent Assistant
- Siri
- 1-year warranty
- Product Type
- Compatibility
- Dimensions & Weight Details
- Headphones: 16.86 cm x 8.34 cm x 18.73 cm / 384.8 g , Case: 134.5 g
- 16.86 cm
- 8.34 cm
- 18.73 cm
- 384.8 g
- Silver
- Body Material
- Stainless steel, anodised aluminium
- Headband Material
- Knit mesh
- Earpad Material
- Memory foam, mesh textile
- Recommended Use
- On-ear detection
Audio Output
- Full size
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- Adaptive EQ
- Magnet Material
- Neodymium magnet
- Adjustable Headband
- Apple H1 chip
Microphone
- Form Factor
- Built-in
- 9
Remote Control
- Controls
Tracking
- Sensors
- Accelerometer, gyro sensor, position sensor, optical sensor, case-detect sensor
Internet of Things (IoT)
- Siri
- Included Accessories
- Charging case, Lightning to USB-C cable
- Cable Details
- USB-C to Lightning cable - detachable
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 20 hour(s)
- Run Time Details
- Continuous playback (active noise-cancelling on): up to 20 hours , Continuous playback (spatial audio on): up to 20 hours , Continuous talk: up to 20 hours
- Limited warranty - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
G321 051125 Condition: UNWANTED CUSTOMER RETURN , FULLY TESTED EXCELLENT CONDITION , OPENED ITEM |
£301.26 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
