AirPods Max, the ultimate listening experience. Now in five new colours. An Apple-designed driver provides high-fidelity audio. Every detail, from canopy to cushions, has been designed for an exceptional fit. Pro-level Active Noise Cancellation1 blocks outside noise, while Transparency mode keeps you connected to your environment. Updated with a USB-C connector for even more convenient charging.?
- ULTIMATE OVER-EAR LISTENING EXPERIENCE — Apple-designed dynamic driver provides high-fidelity audio. Computational audio combines custom acoustic design with the Apple H1 chip and software for breakthrough listening experiences.
- FIVE FRESH COLOURS — AirPods Max come in five fresh colours: Midnight, Starlight, Blue, Purple and Orange. A colour-matched Smart Case is also included.
- FOCUS ON WHAT’S PLAYING — Pro-level Active Noise Cancellation removes up to 2x more background noise, so you can immerse yourself in music.1
- HEAR THE WORLD AROUND YOU — Transparency mode lets you comfortably hear and interact with the world around you.
- PERSONALISED SPATIAL AUDIO — With sound that suits your unique ear shape along with dynamic head tracking, AirPods Max deliver an immersive listening experience that places sound all around you. You can also listen to selected songs, shows and movies in Dolby Atmos.2
- ACOUSTIC-FIRST DESIGN — Designed with a knitted-mesh canopy and memory foam ear cushions for an exceptional over-ear fit that perfectly seals in sound.
- MAGICAL EXPERIENCE — Pair AirPods Max by simply placing them near your device and tapping Connect on your screen. AirPods Max pause audio when you take them off. And Automatic Switching makes listening between your iPhone, iPad and Mac completely effortless.3
- PRECISION CONTROL — Use the Digital Crown to play and pause music; to answer, end and mute yourself on calls; and to control volume and skip between tracks.
- NOW WITH USB-C CHARGING — The new USB-C connector lets you charge your AirPods Max with the same cable you use to charge your iPhone, iPad, Mac or other Apple devices.
1Up to 2x more Active Noise Cancellation compared with AirPods?Pro (1st?generation) and AirPods?4 with Active Noise Cancellation.
2Spatial Audio works with compatible content in supported apps. iPhone with TrueDepth camera required to create personalised profile.
3Requires an iCloud account and a compatible Apple device with the latest operating system software.
Apple-designed dynamic driver provides high-fidelity audio. Computational audio combines custom acoustic design with the Apple H1 chip and software for breakthrough listening experiences. -
FIVE FRESH COLOURS
AirPods Max come in five fresh colours: Midnight, Starlight, Blue, Purple and Orange. A colour-matched Smart Case is also included. -
FOCUS ON WHAT'S PLAYING
Pro-level Active Noise Cancellation removes up to 2x more background noise, so you can immerse yourself in music. -
Transparency mode lets you comfortably hear and interact with the world around you. -
With sound that suits your unique ear shape along with dynamic head tracking, AirPods Max deliver an immersive listening experience that places sound all around you. You can also listen to selected songs, shows and movies in Dolby Atmos. -
Designed with a knitted-mesh canopy and memory foam ear cushions for an exceptional over-ear fit that perfectly seals in sound. -
MAGICAL EXPERIENCE
Pair AirPods Max by simply placing them near your device and tapping Connect on your screen. AirPods Max pause audio when you take them off. And Automatic Switching makes listening between your iPhone, iPad and Mac completely effortless. -
PRECISION CONTROL
Use the Digital Crown to play and pause music; to answer, end and mute yourself on calls; and to control volume and skip between tracks. -
- Apple AirPods Max 2nd generation - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless
- Compatibility
- iPhone, iPad, Mac, iPod
- Recommended Use
- Portable electronics, computer
- Additional Functions
- Spatial audio with dynamic head tracking, transparency mode, wireless audio sharing
- Blue
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- Adaptive EQ
- Active Noise Canceling
- Microphones Included
- 9
- Controls
- Volume, play/pause, answer call, reject call, mute, next/previous track, voice assistant, ANC/transparency
- Intelligent Assistant
- Siri
- 1-year warranty
- Product Type
- Product Generation
- 2nd generation
- Compatibility
- Dimensions & Weight Details
- Headphones: 16.86 cm x 8.34 cm x 18.73 cm / 386.2 g , Case: 134.5 g
- 16.86 cm
- 8.34 cm
- 18.73 cm
- 386.2 g
- Blue
- Recommended Use
- Automatic device switching, fast charge
Audio Output
- Full size
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- Adaptive EQ
- Active Noise Cancelling Technology
- Pro-level Active Noise Cancellation
- Adjustable Headband
- Apple H1 chip
Microphone
- Form Factor
- Built-in
- 9
Remote Control
- Controls
Tracking
- Sensors
- Gyroscope, accelerometer, optical sensor, position sensor, case-detect sensor
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Siri
- Included Accessories
- Smart case, USB-C charging cable
- Cable Details
- USB-C charge cable - detachable
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 20 hour(s)
- Run Time Details
- Continuous playback (active noise-cancelling on): up to 20 hours , Continuous playback (spatial audio on): up to 20 hours , Continuous talk: up to 20 hours , Continuous playback (with 5 min charge): up to 1.5 hours
- Limited warranty - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HVYT 050626 Condition: Customer return - item has been used and shows signs of use |
£309.95 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
