Updated design
AirPods are lightweight and offer a contoured design. They sit at just the right angle for comfort and to better direct audio to your ear. The stem is 33 per cent shorter than AirPods (2nd generation) and includes a force sensor to easily control music and calls.
Personalised Spatial Audio with dynamic head tracking
Sound is placed all around you to create an immersive, three-dimensional listening experience for music, TV shows and movies. Gyroscopes and accelerometers in AirPods work together to track your head movements — so it sounds like you’re in the centre of songs and scenes.
Adaptive EQ
Music is automatically tuned to suit the shape of your ear. Inward-facing microphones detect what you’re hearing, then adjust low- and mid-range frequencies to deliver the rich details in every song.
Longer battery life
AirPods have an extra hour of battery life compared with AirPods (2nd generation) for up to 6 hours of listening time and up to 4 hours of talk time. With just 5 minutes of charge, you’ll get around an hour of listening or talk time. And with the Lightning Charging Case, you can enjoy up to 30 hours of total listening time.
Sweat and water resistant
Both AirPods and the Lightning Charging Case are rated IPX4 water resistant — so they’ll withstand anything from rain to heavy workouts.
Magical in every way
Setup is effortless — pull them out of the case and they’re ready to use. Automatically switch between your Apple devices. In-ear detection knows the difference between your ear and other surfaces. Announce Notifications with Siri gives you the option to have Siri read your notifications through your AirPods. And with Audio Sharing, you and a friend can easily share a song or show between any two sets of AirPods.
Legal
¹Spatial Audio works with movies, TV and video in supported apps. iPhone with TrueDepth camera required to create personalised profile. ²Battery life depends on device settings, environment, usage and many other factors. ³AirPods (3rd generation) are sweat and water resistant for non-water sports and exercise, and they are IPX4 rated. Sweat and water resistance are not permanent conditions. 4Siri may not be available in all languages or in all areas, and features may vary by area. Internet access required. Mobile data charges may apply. 5Requires an iCloud account and a compatible Apple device with the latest operating system software. 6Requires a compatible Apple device running the latest operating system software.
- Apple AirPods with Lightning Charging Case 3rd generation - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Compatibility
- iPhone, iPad, iPod, Mac
- Recommended Use
- Portable electronics
- Additional Functions
- Wireless audio sharing
- White
- Headphones Form Factor
- Ear-bud
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- Adaptive EQ
- Microphone Operation Mode
- Beamforming
- Controls
- Play/pause, answer/end, next/previous track, voice assistant
- Intelligent Assistant
- Siri
- 1-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- Product Generation
- 3rd generation
- Compatibility
- Dimensions & Weight Details
- Charging case: 5.44 cm x 2.138 cm x 4.64 cm / 37.91 g
- 1.826 cm
- 1.921 cm
- 3.079 cm
- 4.28 g
- White
- Recommended Use
- Protection
- IPX4, sweat-resistant, water-resistant
Audio Output
- Ear-bud
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Sound Effects
- Adaptive EQ
- Apple H1 chip, Personalised Spatial Audio with dynamic head tracking
Microphone
- Form Factor
- Built-in
- Beamforming
Remote Control
- Controls
Tracking
- Sensors
- Motion-detecting accelerometer, speech-detecting accelerometer, skin-detecting sensors, force sensor
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Siri
- Included Accessories
- Lightning charging case, Lightning to USB-C cable
- Cable Details
- USB-C to Lightning cable
- Auto On/Off
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 6 hour(s)
- Run Time Details
- Continuous playback: up to 6 hours , Continuous playback (spatial audio on): up to 5 hours , Continuous talk: up to 4 hours , Continuous playback (with included charging case): up to 30 hours , Continuous talk (with included charging case): up to 20 hours
- Limited warranty - 1 year
Apple MagSafe Charger | In Stock | £35.84 |
