The Apple Mini-DVI to VGA Adapter is designed for use with the iMac (Intel Core Duo), MacBook, and 12-inch PowerBook G4. Connect the adapter to the Mini-DVI port of the computer and the VGA end of the adapter to an external VGA monitor or projector. You can use this cable in both video mirroring and extended desktop modes.
- Apple VGA adapter
- VGA adapter
- Connector
- Mini-DVI - male
- Connector (Second End)
- HD-15 (VGA) - female
- Designed For
- PowerBook G4
- VGA adapter
- Connector
- Apple mini-DVI - male
- 15 pin HD D-Sub (HD-15) - female
- Designed For
- Apple PowerBook G4
