Apple 60W USB-C Charge Cable (1M)
Quicklinx: HZS9WS00 Mfr#: MW493ZM/A
Product Range: Apple
More than 50 In Stock
£17.13 ex VAT
£20.55 inc VAT
Discover the efficiency and durability of Apple's USB-C cable, designed to meet your charging and connectivity needs. With fast charging support through USB Power Delivery (60 W), this cable ensures your devices are quickly ready to go, saving you time and hassle. Its sync and charge capability makes it a versatile tool for both power and data transfer. Crafted with a woven design, it not only looks good but is built to last, resisting wear and tear from daily use. Compliant with USB 2.0 standards, it offers wide compatibility with a range of devices, making it a reliable choice for those who value both form and function.
  • Fast charging capability
    Equipped with USB Power Delivery (60 W), this USB-C cable ensures your devices charge quickly and efficiently, minimizing downtime and keeping you connected when you need it most.
  • Durable design
    The woven design not only adds an aesthetic touch but also enhances the cable's durability, making it resistant to fraying and everyday wear and tear.
  • Versatile connectivity
    With male connectors on both ends and compliance with USB 2.0 standards, this cable supports both sync and charge functionalities, offering a seamless connection for a wide range of devices.
Apple - USB-C cable - USB-C to USB-C - 1 m
USB-C cable
USB Power Delivery (60W), sync and charge, fast charging support, woven design
Cable Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
1-year warranty
USB-C cable
Cable Length
1 m
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0
1-year warranty
Brand: Apple
