Inspired by the best of Apple. Transformed by the M1 chip. Stands out in any space. Fits perfectly into your life.
So thin and compact design
This extraordinary design is only possible thanks to M1, the first system on a chip for Mac. It makes iMac so thin and compact that it fits in more places than ever. M1 integrates the processor, graphics, memory, and more onto a single chip. That let to put an entire computer into a space so small it practically disappears. -
See the big picture and all the details
See it all in sharp, glorious detail on the immersive 24-inch 4,5K Retina display. The P3 wide color gamut brings what you're watching to life in over a billion colors. Images shine with a brilliant 500 nits of brightness. Industry-leading anti-reflective coating delivers greater comfort and readability. And True Tone technology automatically adjusts the color temperature of your display to the ambient light of your environment, for a more natural viewing experience. So whether you're editing photos, working on presentations, or watching your favorite shows and movies, everything looks incredible on iMac. -
1080p FaceTime HD camera is ready for your close-up
It's the best camera system ever in a Mac. Double the resolution for higher-quality video calls. A larger sensor that captures more light. And the advanced image signal processor (ISP) of M1 greatly improves image quality. So from collaborating with coworkers to catching up with friends and family, you'll always look your best. -
Studio-quality mics for high-quality conversations
Whether you're on a video call with a friend, cutting a track, or recording a podcast, the microphones on iMac make sure you come through loud, crisp, and clear. The studio-quality three-mic array is designed to reduce feedback, so conversations flow more naturally and you interrupt each other less. And beamforming technology helps the mics ignore background noise. Which means everyone hears you - not what's going on around you. -
Six-speaker sound system
The sound system on iMac brings incredible, room-filling audio to any space. Two pairs of force-canceling woofers create rich, deep bass without unwanted vibrations. And each pair is balanced with a high-performance tweeter. The result is a massive, detailed soundstage that takes your movies, music, and more to the next level. Thanks to the redesigned speakers and advanced algorithms, iMac now supports spatial audio when playing music or video with Dolby Atmos. And when you combine that with the 4,5K Retina display, it's like bringing the whole theater home. -
iMac has apps for just about everything and everyone
With M1 and macOS Monterey, you can even run many of your favorite iPhone and iPad apps directly on your iMac. And as always, it's easy to search, discover, and download on the Mac App Store. -
Designed with the Earth in mind
iMac was designed to minimize its impact on the environment. All of the virgin wood fiber in its packaging comes exclusively from responsibly managed forests. The rare earth elements in the speakers, fan motor, and power connector magnets are completely recycled.
- Apple iMac with 4.5K Retina display - all-in-one - M1 - 8 GB - SSD 256 GB - LED 24" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Apple M1 (8-core)
- Processor Main Features
- 16-core Neural Engine
- RAM
- 8 GB
- Hard Drive
- SSD 256 GB - soldered
- Optical Storage
- No optical drive
- Monitor
- 24" - LED - 4480 x 2520 (4.5K) - 218 ppi
- Graphics Controller
- Apple M1 7-core
- Camera
- Audio Output
- Stereo
- Networking
- 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 5.0, 802.11ax (Wi-Fi 6)
- Keyboard
- UK
- Power
- (50/60 Hz)
- OS Provided
- Apple macOS Monterey 12.0
- Silver
- 54.7 cm x 14.7 cm x 46.1 cm
- 4.46 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Personal computer
- Product Form Factor
- All-in-one
- Built-in Devices
- Microphone array, 6 speakers
- Silver
- Localisation
Processor / Chipset
- CPU
- Apple M1
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 8 GB
- Configuration Features
- Unified memory
Hard Drive
- SSD - soldered
- Capacity
- 1 x 256 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- LED
- Diagonal Size
- 24"
- Viewable Size
- 23.5"
- Native Resolution
- Widescreen Display
- Pixel Density (ppi)
- 218
- Image Brightness
- 500 cd/m²
- Monitor Features
- Anti-reflective, arsenic free, Retina display, P3 Wide Color Gamut, True Tone technology
Graphics Controller
- Graphics Processor
- Apple M1 7-core
- Video Interfaces
- USB-C
Audio Output
- Sound Output Mode
- Stereo
- Dolby Atmos
- Speakers Included
- 6 x right / left channel
Camera
- Camera
- Resolution
- 1080p
- FaceTime HD camera, advanced image signal processor (ISP)
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- Apple Magic Keyboard
- Connectivity
- Wireless
- Interface
- Bluetooth
- Localization & Layout
- UK
Mouse
- Mouse Name
- Apple Magic Mouse
- Connectivity
- Wireless
- Technology
- Laser
- Interface
- Bluetooth
- Multi-Touch
Audio Input
- 3-microphone array
- Wireless LAN Supported
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0, IEEE 802.11ax (Wi-Fi 6)
- 2 x Thunderbolt 3/DisplayPort/USB4 , 1 x headphones
- Cables Included
- USB-C to Lightning cable
- BFR-free, PVC-free, Beryllium-free, Mercury-free
- Power adapter
- Voltage Required
- AC 100-240 V (50/60 Hz)
- Power Provided
- 143 Watt
Operating System / Software
- OS Provided
- Software
- Apple QuickTime, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Music, Contacts, Stocks, Notes, Calendar, Apple AirDrop, Siri, Messages, Dictation, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Podcasts, Home, Apple TV, Find My, Apple Pay
- ENERGY STAR Certified
- 54.7 cm
- 14.7 cm
- 46.1 cm
- 4.46 kg
- 10 °C
- 35 °C
- 5 - 90% (non-condensing)
Apple Lightning to USB Cable (0.5m) | In Stock | £15.00 |
Apple Lightning to USB Cable (2 m) | In Stock | £29.17 |
Apple USB-C VGA Multiport Adapter | In Stock | £60.29 |
Apple USB-C to USB Adapter | In Stock | £17.08 |
Apple USB-C Charge Cable (2m) | In Stock | £15.54 |
Apple Magic Keyboard with Numeric Keypad - UK Layout | In Stock | £103.71 |
Apple Magic Keyboard with Numeric Keypad | In Stock | £103.71 |
Apple USB-C to SD Card Reader | In Stock | £31.35 |
Apple Magic Keyboard with Numeric Keypad - Keyboard - Bluetooth | In Stock | £103.61 |
Apple USB-C Digital AV Multiport Adapter - Docking station | In Stock | £60.29 |
Apple AirPods - 2nd Generation | In Stock | £95.83 |
Apple AirPods Max - Space Grey | In Stock | £415.84 |
Apple AirPods Max - Silver | In Stock | £415.84 |
Apple AirPods Max - Green | In Stock | £415.84 |
Apple AirPods Max - Sky Blue | In Stock | £415.84 |
Apple AirPods Max - Pink | In Stock | £415.84 |
Apple Magic Mouse and USB-C to Lightning Cable | In Stock | £67.48 |
Apple Magic Keyboard Touch ID for M1 | In Stock | £119.05 |
Apple AirPods (3rd Gen) with MagSafe Charging Case | In Stock | £140.84 |
Apple USB-C to Lightning Cable (1 m) | In Stock | £14.33 |
Apple Magic Keyboard with Touch ID and Numeric Keypad | In Stock | £143.91 |
Apple Magic Keyboard - British English | In Stock | £79.59 |
Apple USB-C to Lightning Cable 2m | In Stock | £26.59 |
Apple AirPods (3rd Gen) with Lightning Charging Case | In Stock | £132.50 |
Apple USB-C Woven Charge Cable (1m) | In Stock | £15.24 |
