Mover. Maker. Boundary breaker.
Supercharged by M2 Pro or M2 Max, MacBook Pro takes its power and efficiency further than ever. It delivers exceptional performance whether it’s plugged in or not, and now has even longer battery life. Combined with a stunning Liquid Retina XDR display and all the ports you need — this is a pro laptop without equal.
M2 Pro
M2 Pro brings power to take on even more demanding projects. The advanced CPU and next-generation Neural Engine make pro workflows fly - from sorting and editing thousands of images to running computational fluid dynamics simulations. And the powerful GPU drives a huge boost in graphics performance for both work and play. -
Do this all day
Even longer battery life. Remains just as fast whether on battery or plugged in. That efficiency is the magic of Apple silicon. So, wherever inspiration strikes or whenever duty calls, run with it. -
The coolest part
Thanks to the efficiency of Apple silicon, the fans don't even have to turn on for most of your daily tasks. And for heavier workflows, the advanced thermal systems move air at low fan speeds. -
Think huge
MacBook Pro is built on an all-flash storage architecture designed to make everyday tasks snappy and responsive. -
Liquid Retina XDR
Extreme Dynamic Range brings refined specular highlights, incredible detail in shadows, and vibrant, true-to-life colours. The display is calibrated in the factory and features pro reference modes for HDR colour grading, photography, design and print production. -
ProMotion
Making everything from scrolling to gaming superfluid and responsive, ProMotion automatically adjusts to match the movement of content - with refresh rates up to 120 Hz. Video editors can also choose a fixed refresh rate that precisely aligns with their footage. -
Look sharp wherever you make or take video calls
Whether you're connecting with friends and family across time zones or collaborating with colleagues out in the field. The 1080p camera uses a wide aperture to let in more light, combined with a large image sensor for better performance in low light. -
Studio-quality three-mic array
With a signal-to-noise ratio that rivals professional-grade microphones, MacBook Pro can capture even the subtlest sounds. And directional beamforming minimizes background noise so your voice comes through loud and clear. -
Six-speaker sound system
Four force-cancelling woofers deliver deeper bass and room-filling sound. High-performance tweeters project clearer, fuller vocals. And Spatial Audio creates a sophisticated three-dimensional soundstage when you're playing music or video with Dolby Atmos. -
Magic Keyboard
The Magic Keyboard comes with a full-height function key row and Touch ID, which gives you a fast, easy, secure way to unlock your Mac and sign in to apps and sites.
- Apple MacBook Pro - 16.2" - Apple M2 Pro - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- macOS Ventura 13.0
- Processor
- Apple M2 Pro
- Memory
- 16 GB (unified memory)
- Storage
- 512 GB SSD
- Display
- 16.2" Mini LED backlight 3456 x 2234 @ 120 Hz - 254 ppi
- Graphics
- Apple M2 Pro 19-core
- Input Device
- Force Touch trackpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
- Battery
- Up to 22 hours
- Ambient light sensor
- Security
- Fingerprint reader
- Space grey
- 35.57 cm x 24.81 cm x 1.68 cm
- 2.15 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Specific Absorption Rate (SAR)
- 0.48 W/kg
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
- Apple macOS Ventura 13.0
Processor / Chipset
- CPU
- Apple M2 Pro
- Number of Cores
- 12-core
- RAM
Storage
- Main Storage
- 512 GB SSD soldered
Display
- 16.2"
- LCD Backlight Technology
- Mini LED backlight
- Resolution
- 3456 x 2234
- V-Sync Rate at Max Res.
- 120 Hz
- Widescreen
- Pixel Density (ppi)
- 254
- Image Brightness
- 500 cd/m²
- Colour Support
- 1 billion colours
- BFR/PVC-free, Mercury free, Zoom, arsenic-free glass, beryllium free, True Tone display, ProMotion technology, HDR10 compatible, HLG gamma, Liquid Retina display, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), Dolby Vision, 1000 cd/m² max full-screen brightness, 1600 cd/m² peak brightness (HDR)
- Keyboard Name
- Apple Magic Keyboard with Touch ID
Audio & Video
- Graphics Processor
- Max Monitors Supported
- 2 external monitor(s)
- Video System Features
- Hardware-accelerated H.264, HEVC, ProRes and ProRes RAW, video decode engine, ProRes encode and decode engine, video encode engine
- Camera
- Yes - 1080p
- Camera Features
- Advanced image signal processor (ISP), FaceTime 1080p HD camera
- Sound
- Six speakers, 3-microphone array
- Dolby Digital Plus, Dolby Atmos, Dolby Digital
- Audio Features
- Output: 4 force-cancelling woofers, wide stereo sound, Spatial Audio support
Input
- Keyboard, Force Touch trackpad
- Keyboard Layout
- UK
- Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, force click, Touch ID sensor
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 100 Wh
- Run Time
- Up to 22 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 15 hours , Video playback: up to 22 hours
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 140 Watt
Connections & Expansion
- Interfaces Details
- 3 x USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (charging) , Headphone output , HDMI
- Memory Card Reader
- Yes (SDXC Card)
Software
- Software Included
- Apple QuickTime, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, E-mail, Apple Time Machine, Apple FaceTime, Apple Preview, Maps, Photos, Reminders, App Store, Music, Contacts, Stocks, Notes, Calendar, Siri, Messages, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Podcasts, Home, Apple TV, Find My, Apple Books, Apple Shortcuts
- Space grey
- Case Material
- Aluminum
- Integrated Options
- Security
- VoiceOver screen reader, Dictation, Voice Control, Closed Captions, Switch Control, 200 GB/s memory bandwidth, reduce motion, text to speech, increase contrast
- Included Accessories
- USB-C power adapter, USB-C to MagSafe 3 charge cable (2m)
- 0.48 W/kg
- Localization
- 2.15 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
