Apple 14-inch MacBook Pro: M2 Max chip 12-core CPU 30-core GPU 1TB SSD - Silver
Quicklinx: H45KWS00 Mfr#: MPHK3B/A
Type: MacBook
Display Size: 14.2in
Processor Model: M2 Max chip
Operating System: Apple macOS Ventura 13.0
Installed Memory: 32GB
  • IEEE 802.11n
£2,595.29 ex VAT
£3,114.34 inc VAT
Mover. Maker. Boundary breaker.
Supercharged by M2 Pro or M2 Max, MacBook Pro takes its power and efficiency further than ever. It delivers exceptional performance whether it’s plugged in or not, and now has even longer battery life. Combined with a stunning Liquid Retina XDR display and all the ports you need — this is a pro laptop without equal.
  • M2 Max
    The powerful and efficient chip in a pro laptop, M2 Max is engineered to help pros push the boundaries of their ingenuity and creativity. With the same next-generation CPU as M2 Pro, M2 Max has twice the memory bandwidth, up to three times the unified memory and up to 38 GPU cores. So, you can render effects, merge massive panoramas and design extreme 3D geometry on an unprecedented scale.
  • Do this all day
    Even longer battery life. Remains just as fast whether on battery or plugged in. That efficiency is the magic of Apple silicon. So, wherever inspiration strikes or whenever duty calls, run with it.
  • The coolest part
    Thanks to the efficiency of Apple silicon, the fans don't even have to turn on for most of your daily tasks. And for heavier workflows, the advanced thermal systems move air at low fan speeds.
  • Think huge
    MacBook Pro is built on an all-flash storage architecture designed to make everyday tasks snappy and responsive.
  • Liquid Retina XDR
    Extreme Dynamic Range brings refined specular highlights, incredible detail in shadows, and vibrant, true-to-life colours. The display is calibrated in the factory and features pro reference modes for HDR colour grading, photography, design and print production.
  • ProMotion
    Making everything from scrolling to gaming superfluid and responsive, ProMotion automatically adjusts to match the movement of content - with refresh rates up to 120 Hz. Video editors can also choose a fixed refresh rate that precisely aligns with their footage.
  • Look sharp wherever you make or take video calls
    Whether you're connecting with friends and family across time zones or collaborating with colleagues out in the field. The 1080p camera uses a wide aperture to let in more light, combined with a large image sensor for better performance in low light.
  • Studio-quality three-mic array
    With a signal-to-noise ratio that rivals professional-grade microphones, MacBook Pro can capture even the subtlest sounds. And directional beamforming minimizes background noise so your voice comes through loud and clear.
  • Six-speaker sound system
    Four force-cancelling woofers deliver deeper bass and room-filling sound. High-performance tweeters project clearer, fuller vocals. And Spatial Audio creates a sophisticated three-dimensional soundstage when you're playing music or video with Dolby Atmos.
  • Magic Keyboard
    The Magic Keyboard comes with a full-height function key row and Touch ID, which gives you a fast, easy, secure way to unlock your Mac and sign in to apps and sites.
Apple MacBook Pro - 14.2" - Apple M2 Max - - 32 GB RAM - 1 TB SSD - UK
Notebook
Operating System
macOS Ventura 13.0
Apple M2 Max
32 GB (unified memory)
Storage
1 TB SSD
Display
14.2" Mini LED backlight 3024 x 1964 @ 120 Hz - 254 ppi
Graphics
Apple M2 Max 30-core
Input Device
Force Touch trackpad
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
Up to 18 hours
Ambient light sensor
Security
Fingerprint reader
Silver
31.26 cm x 22.12 cm x 1.55 cm
1.63 kg
Environmental Standards
ENERGY STAR Qualified
SAR
0.58 W/kg
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Processor / Chipset
CPU
Apple M2 Max
Number of Cores
12-core
16-core Neural Engine
RAM
Storage
Main Storage
1 TB SSD soldered
Display
14.2"
LCD Backlight Technology
Mini LED backlight
Resolution
3024 x 1964
V-Sync Rate at Max Res.
120 Hz
Widescreen
Pixel Density (ppi)
254
Image Brightness
500 cd/m²
Colour Support
1 billion colours
BFR/PVC-free, Mercury free, Zoom, arsenic-free glass, beryllium free, True Tone display, ProMotion technology, HDR10 compatible, HLG gamma, Liquid Retina display, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), Dolby Vision, 1000 cd/m² max full-screen brightness, 1600 cd/m² peak brightness (HDR)
Keyboard Name
Magic Keyboard
Audio & Video
Graphics Processor
Max Monitors Supported
4 external monitor(s)
Video System Features
Hardware-accelerated H.264, HEVC, ProRes and ProRes RAW, two ProRes encode and decode engines, video decode engine, two video encode engines
Camera
Yes - 1080p
Camera Features
Advanced image signal processor (ISP), FaceTime 1080p HD camera
Sound
Six speakers, 3-microphone array
Dolby Digital Plus, Dolby Atmos, Dolby Digital
Audio Features
Output: 4 force-cancelling woofers, wide stereo sound, Spatial Audio support
Input
Keyboard, Force Touch trackpad
Keyboard Backlight
Keyboard Layout
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, force click, Touch ID sensor
Communications
Wireless
Lithium polymer
70 Wh
Run Time
Up to 18 hours
Battery Run Time
Video playback: up to 18 hours , Web browsing over Wi-Fi: up to 12 hours
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
67 Watt
Connections & Expansion
3 x USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (charging) , Headphone output , HDMI
Memory Card Reader
Yes (SDXC Card)
Software
Software Included
Apple QuickTime, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, E-mail, Apple Time Machine, Apple FaceTime, Apple Preview, Maps, Photos, Reminders, App Store, Music, Contacts, Stocks, Notes, Calendar, Siri, Messages, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Podcasts, Home, Apple TV, Find My, Apple Books, Apple Shortcuts
Silver
Case Material
Aluminum
Integrated Options
Security
Fingerprint reader
VoiceOver screen reader, Dictation, Voice Control, Closed Captions, Switch Control, 400 GB/s memory bandwidth, reduce motion, text to speech, increase contrast
USB-C power adapter, USB-C to MagSafe 3 charge cable (2m)
SAR Value
0.58 W/kg
Localization
1.63 kg
Sustainability Information
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
H45K Apple 96W USB-C Power Adapter In Stock £63.51
H45K Apple USB-C to Magsafe 3 Cable (2 m) In Stock £39.39
H45K Apple 140 Watt USB-C Power Adapter In Stock £79.59
Other bundles (8)
H45K Apple AirPods - 2nd Generation In Stock £95.83
H45K Apple AirPods Max - Space Grey In Stock £415.84
H45K Apple AirPods Max - Silver In Stock £415.84
H45K Apple AirPods Max - Green In Stock £415.84
H45K Apple AirPods Max - Sky Blue In Stock £415.84
H45K Apple AirPods Max - Pink In Stock £415.84
H45K Apple AirPods (3rd Gen) with MagSafe Charging Case In Stock £140.84
H45K Apple AirPods (3rd Gen) with Lightning Charging Case In Stock £132.50
Type: MacBook
Hard Drive Capacity: 1TB
Graphics: Apple M2 Max 30-core
Brand: Apple
Price Range Ex VAT: £1500+
