More power. More performance. More pro.
- New eighth-generation Intel 6-core and quad-core processors.
- Up to 32GB of memory for running multiple pro apps.
- Stunning Retina display with True Tone technology.
- Touch Bar for working more productively.
With great power comes great capability.
MacBook Pro elevates the notebook to a whole new level of performance and portability. Wherever your ideas take you, you’ll get there faster than ever with high-performance processors and memory, advanced graphics, amazingly fast storage and more.
More power at its cores.
With eighth-generation Intel Core processors, MacBook Pro reaches new heights in compute performance. The 15-inch model now features a 6-core Intel Core processor that works up to 70 per cent faster than the previous generation, enabling up to 4.8GHz Turbo Boost speeds. And a quad-core processor on the 13-inch MacBook Pro with Touch Bar now makes it up to twice as fast as the previous generation. So when you’re powering through pro-level processing jobs like compiling code, rendering 3D models, adding special effects, layering multiple tracks or encoding video, you’ll get everything done. Faster.
Eye-opening graphics performance.
MacBook Pro features a Radeon Pro discrete GPU in every 15-inch model, combining impressive power with remarkable power efficiency. And now we’ve paired each discrete GPU with 4GB of GDDR5 memory as standard, giving you fluid, real-time performance for pro tasks like rendering 3D titles in Final Cut Pro X. The 13-inch model with Touch Bar features powerful integrated graphics with 128MB of embedded DRAM — twice as much as the previous generation — which accelerates graphics tasks. That means more time for what matters most — creating amazing work.
MacBook Pro features a fast GPU, combining impressive power with remarkable power efficiency. That means more time for what matters most - creating amazing work. -
Make quicker work of everything
MacBook Pro includes a drive that's blazing fast and has enough space to take even your big files with you, like large photo libraries or video projects. So you can boot up, launch multiple apps, or import huge files in a flash. -
Powerful and versatile port
Thunderbolt 3 combines ultrahigh bandwidth with the versatility of the USB-C to create one revved up universal port. It integrates data transfer, charging, and video output in a single connector. -
Music to your ears
MacBook Pro has beautifully balanced high-fidelity sound that takes listening to other levels with wide dynamic range and more bass for maximum boom. And the speakers are connected directly to the system power, enabling greater peak amplification. So you can mix a track on the fly, edit video on location, or enjoy a movie on the go.
- Apple MacBook Pro with Touch Bar - 13.3" - Intel Core i5 - - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- macOS Big Sur 11.0
- Processor
- Intel Core i5 (8th Gen) - 2.3 GHz (3.8 GHz)
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 13.3" LED backlight 2560 x 1600 / WQXGA - 227 ppi
- Graphics
- Intel Iris Plus Graphics 655
- Input Device
- Force Touch trackpad, Touch Bar
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 5.0
- Battery
- Up to 10 hours
- Security
- Fingerprint reader
- Space grey
- 30.41 cm x 21.24 cm x 1.49 cm
- 1.37 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Repairability Index
- 6 (out of 10)
- SAR
- 0.9 W/kg (body)
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
- Apple macOS Big Sur 11.0
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 2.3 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- 64-bit Computing
- Intel Turbo Boost Technology
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD soldered
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 2560 x 1600 (WQXGA)
- Widescreen
- Pixel Density (ppi)
- 227
- Image Brightness
- 500 cd/m²
- BFR/PVC-free, Mercury free, Wide Colour Gamut, arsenic-free glass, beryllium free, Retina display, True Tone display
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- FaceTime HD camera
- Sound
- Stereo speakers, three microphones
Input
- Keyboard, Force Touch trackpad, Touch Bar
- Keyboard Layout
- UK
- Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 58 Wh
- Run Time
- Up to 10 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 10 hours , Standby time: up to 30 days
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 61 Watt
Connections & Expansion
- 4 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , Headphone output
Software
- Software Included
- Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple Mac OS X Chess, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Maps, Reminders, Contacts, Notes, Calendar, Apple AirDrop, Siri, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers
- Space grey
- Case Material
- Aluminum
- Security
- Included Accessories
- USB-C power adapter
- Cables Included
- USB-C charge cable
- SAR Value
- 0.9 W/kg (body)
- Localization
- 1.37 kg
Sustainability Information
- 6 (out of 10)
- ENERGY STAR Certified
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
Essential Accessories (4)
Get more from your purchase from one of our essential accessories
Apple World Travel Adapter Kit | In Stock | £23.32 |
Apple Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter | In Stock | £36.96 |
Apple Magic Keyboard with Numeric Keypad - Keyboard - Bluetooth | In Stock | £103.61 |
Apple 96W USB-C Power Adapter | In Stock | £63.51 |
Other bundles (14)
Apple USB-C VGA Multiport Adapter | In Stock | £60.29 |
Apple USB-C to USB Adapter | In Stock | £17.08 |
Apple Power Adapter Extension Cable | In Stock | £16.23 |
Apple USB-C Charge Cable (2m) | In Stock | £14.36 |
Apple Magic Keyboard with Numeric Keypad - UK Layout | In Stock | £103.71 |
Apple USB-C to SD Card Reader | In Stock | £31.35 |
Apple USB-C Digital AV Multiport Adapter - Docking station | In Stock | £60.29 |
Apple AirPods - 2nd Generation | In Stock | £95.83 |
Apple Pro Display XDR 32" 6016x3384 IPS LED Monitor- Standard Glass | In Stock | £3,790.23 |
Apple AirPods Max - Space Grey | In Stock | £415.84 |
Apple AirPods Max - Silver | In Stock | £415.84 |
Apple AirPods Max - Green | In Stock | £415.84 |
Apple AirPods Max - Sky Blue | In Stock | £415.84 |
Apple AirPods Max - Pink | In Stock | £415.84 |
