Apple 13-inch MacBook Pro M2 chip with 8-core CPU and 10-core GPU 256GB SSD - Space Grey
Quicklinx: GW6ZWS00 Mfr#: MNEH3B/A
  • IEEE 802.11n
The new M2 chip makes the 13-inch MacBook Pro more capable than ever. The same compact design supports up to 20 hours of battery life1 and an active cooling system to sustain enhanced performance. Featuring a brilliant Retina display, a FaceTime HD camera and studio-quality mics, it’s our most portable pro laptop.
The M2 chip begins the next generation of Apple silicon, with even more of the speed and power efficiency introduced by M1. So you can rip through workflows with a more powerful 8-core CPU. Create stunning graphics with a lightning-fast 10-core GPU. Work with more streams of 4K and 8K ProRes video with the high-performance media engine. And do it all at once with up to 24GB of faster unified memory
  • Thermal efficiency
    Active cooling sustains blazing-fast performance. Thanks to its advanced thermal system and the efficiency of Apple silicon, MacBook Pro can sustain pro levels of performance, so you can run CPU- and GPU-intensive tasks for hours on end.
  • Faster memory, and more of it
    M2 has 100 GB per second of memory bandwidth - 50 percent more than M1.
  • Performs well with others
    macOS and M2 work together to bring more speed and responsiveness to all your go-to apps - including Microsoft 365 and your favorite iOS apps. Over 10,000 apps and plug-ins are already optimized for Apple silicon. And Rosetta 2 seamlessly translates apps designed for Intel processors for use on your MacBook Pro.
  • A portable editing bay
    The high-performance media engine on M2 supports ProRes encode and decode. So you can play and edit up to 11 streams of 4K ProRes video and up to 2 streams of 8K ProRes video And convert projects to ProRes up to 3x faster than before.
  • MacBook Pro securely yours
    The M2 chip and macOS give MacBook Pro security and privacy features beyond anything in its class. With built-in protections against malware and viruses, the freedom to choose what you share and how you share it, and silicon-level features like Touch ID and Apple Pay, it's built to safeguard your privacy and data at every stage.
  • Superfast SSD storage
    Bring your photos, movies, music, and documents with you - and open them in a flash.
  • Retina display, see the better picture
    With the brilliant Retina display, images take on an incredible level of detail and realism. Text is sharp and clear. Bright LED backlighting delivers deep blacks and bright whites. P3 wide color brings even more vibrant greens and reds than sRGB. And MacBook Pro features True Tone technology, so the white balance automatically adjusts to match the color temperature of the light around you - for a more natural viewing experience.
  • Be seen, be heard
    Thanks to M2, the FaceTime HD camera takes full advantage of Apple's advanced image signal processor - so you'll look great in video calls. And whether you're running a meeting, hosting a podcast, or connecting with friends and family, the studio-quality mics will make sure everyone hears you loud and clear.
  • Magic Keyboard, just your type
    Magic Keyboard delivers a comfortable, quiet, and responsive typing experience. The Touch Bar puts the commands you need most right where you need them, saving time and keystrokes. And Touch ID provides fast, easy authentication for secure logins and purchases.
  • Make connections, faster than ever
    Ultra-high bandwidth, meets ultra-versatility. Thunderbolt enables data transfer, charging, and video output all through a single port - and MacBook Pro has two of them. Wi-Fi 6 keeps MacBook Pro going strong as more and more devices join the network. And the headphone jack even supports high-impedance headphones.
Apple MacBook Pro - 13.3" - Apple M2 - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
macOS Monterey 12.0
Apple M2
Neural Processor Unit (NPU)
16-core Neural Engine
8 GB (unified memory)
Storage
256 GB SSD
Display
13.3" LED backlight 2560 x 1600 / WQXGA - 227 ppi
Graphics
Apple M2 10-core
Input Device
Force Touch trackpad, Touch Bar
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
Up to 20 hour(s)
Ambient light sensor
Security
Fingerprint reader
Space grey
30.41 cm x 21.24 cm x 1.56 cm
1.4 kg
Environmental Standards
ENERGY STAR Qualified
0.89 W/kg (body) , 0.89 W/kg (limb)
Limited warranty - 1 year , Technical support - phone consulting - 90 days
Notebook
Operating System
Apple macOS Monterey 12.0
Processor / Chipset
CPU
Apple M2
Number of Cores
8-core
RAM
Storage
Main Storage
256 GB SSD soldered
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
2560 x 1600 (WQXGA)
Widescreen
Pixel Density (ppi)
227
Image Brightness
500 cd/m²
BFR/PVC-free, Mercury free, beryllium free, arsenic free, Retina display, P3 Wide Color Gamut, True Tone technology
Keyboard Name
Magic Keyboard
Audio & Video
Graphics Processor
Apple M2 10-core
Video System Features
Hardware-accelerated H.264, HEVC, ProRes and ProRes RAW, video decode engine, ProRes encode and decode engine, video encode engine
Camera
Yes - 720p
Camera Features
FaceTime HD camera, advanced image signal processor (ISP)
Sound
Stereo speakers, 3-microphone array
Dolby Atmos
Input
Keyboard, Force Touch trackpad, Touch Bar
Keyboard Backlight
Keyboard Layout
Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor, scissor mechanism
Communications
Wireless
Lithium polymer
58.2 Wh
Run Time
Up to 20 hour(s)
Battery Run Time
Video playback: up to 20 hours , Web browsing over Wi-Fi: up to 17 hours
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
67 Watt
Connections & Expansion
Interfaces Details
2 x USB4/Thunderbolt 3/DisplayPort (charging) , Headphone output
Software
Software Included
Apple QuickTime, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Music, Contacts, Stocks, Notes, Calendar, Siri, Messages, Dictation, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Podcasts, Home, Apple TV, Find My, Apple Shortcuts
Space grey
Case Material
Low-carbon aluminium
Integrated Options
Security
Fingerprint reader
VoiceOver screen reader, Voice Control, Closed Captions, 100 GB/s memory bandwidth
USB-C power adapter
USB-C charge cable
Localization
1.4 kg
Sustainability Information
ENERGY STAR Certified
10 °C
35 °C
0 - 90% (non-condensing)
GW6Z Apple USB-C Woven Charge Cable (1m) In Stock £21.19
