MacBook Air is designed to be powerful, capable, durable, and enjoyable to use. With enough battery life to get you through the day. That's the difference between a notebook that's simply thin and light and one that's so much more.
Multi-Touch technology is part of practically every Apple product. It's the best and most personal way to interact with your devices. And the optimal way to experience Multi-Touch on a notebook is through a trackpad. That's precisely the case with MacBook Air. The trackpad's spacious, all-glass surface doesn't have a button because the whole thing is the button. And with multi-touch gestures in OS X, you can interact with MacBook Air in ways that feel more intuitive and realistic than ever before.
MacBook Air features a unibody design for both the main enclosure and the display. Unibody construction means a higher-precision, less complex design with fewer parts. That translates to a notebook that's exceptionally thin and light, yet durable enough to handle the rigors of everyday use. In addition, MacBook Air offers innovations you won't find anywhere else.
Advanced technology from iPad
A truly mobile device needs to be light, thin, and strong enough to take with you wherever you go. It also needs to perform quickly, spring to life instantly, and have enough battery power to keep up with you. It should have no spinning hard drive, no optical drive, and no unnecessary parts. All of that is true of iPad. And it's true of Apple's incredibly mobile notebook ever: MacBook Air. -
Convenient way to multi-touch on a notebook
Multi-Touch technology is a convenient way to interact with your software. And the optimal way to experience Multi-Touch on a notebook is through a trackpad. That's precisely the case with MacBook Air. Now you can perform more gestures than you have fingers on a spacious, all-glass surface that's smooth to the touch. -
Incredible battery
Removing the flash storage enclosure and placing the flash chips on the logic board freed up even more room. And voila: space for a bigger battery. And when you put MacBook Air to sleep for more than an hour, it enters what's called standby mode. -
Unibody in unison
When MacBook Air first debuted, it was groundbreaking in many ways. Chief among them was the precision unibody enclosure. Now that same engineering process comes to the MacBook Air display. Just like the main enclosure, the display housing is crafted from a single piece of aluminum, with all the structural elements machined directly into it. The total unibody construction means a less complex design with fewer parts. That makes MacBook Air exceptionally thin and light, yet still durable enough to handle the rigors of everyday use.
- Apple MacBook Air with Retina display - 13.3" - Intel Core i5 - - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- macOS Big Sur 11.0
- Processor
- Intel Core i5 (8th Gen) - 1.6 GHz (3.6 GHz) / 4 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 13.3" LED backlight 2560 x 1600 / WQXGA - 227 ppi
- Graphics
- Intel UHD Graphics 617
- Input Device
- Force Touch trackpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- Up to 12 hours
- Security
- Fingerprint reader
- Silver
- 30.41 cm x 21.24 cm x 1.56 cm
- 1.25 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Repairability Index
- 6.1 (out of 10)
- SAR
- 0.71 W/kg (body)
- Limited warranty - 1 year ¦ Technical support - phone consulting - 90 days
- Product Type
- Notebook
- Operating System
- Apple macOS Big Sur 11.0
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 1.6 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 2133 MHz
Storage
- Main Storage
- 256 GB SSD soldered PCIe
Display
- 13.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 2560 x 1600 (WQXGA)
- Widescreen
- Pixel Density (ppi)
- 227
- Image Aspect Ratio
- 16:10
- BFR/PVC-free, Mercury free, beryllium free, arsenic free
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- FaceTime HD camera
- Sound
- Stereo speakers, three microphones
Input
- Keyboard, Force Touch trackpad
- Keyboard Layout
- UK
- Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor
Communications
- Wireless
- Technology
- Lithium polymer
- Capacity
- 50.3 Wh
- Run Time
- Up to 12 hours
- Battery Run Time
- Web browsing over Wi-Fi: up to 12 hours , Video playback: up to 13 hours , Standby time: up to 30 days
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 30 Watt
Connections & Expansion
- 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , Headphone output
Software
- Software Included
- iTunes, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Contacts, Stocks, Notes, Calendar, Siri, Messages, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Home
- Silver
- Case Material
- Aluminum
- Security
- T2 Security Chip
- Included Accessories
- USB-C power adapter
- Cables Included
- USB-C charge cable
- SAR Value
- 0.71 W/kg (body)
- Localization
- 1.25 kg
Sustainability Information
- 6.1 (out of 10)
- ENERGY STAR Certified
- 10 °C
- 35 °C
- 0 - 90% (non-condensing)
