Apple 12.9-inch iPad Pro Wi-Fi 1TB - Space Grey
CONTACT OUR IT SPECIALISTS TO ENQUIRE ABOUT EDUCATION PRICING!
Quicklinx: H1TVWS00 Mfr#: MNXW3B/A
The ultimate iPad experience. Now with breakthrough M1 performance and a breathtaking XDR display. Buckle up.
  • M2 chip
    The M2 chip is the next generation of Apple silicon, with a CPU that delivers faster performance and a GPU that provides faster graphics performance. With a faster Neural Engine to accelerate machine learning tasks and more memory bandwidth, M2 brings astonishing performance and capabilities to iPad Pro. So, you can create photorealistic 3D designs, build intricate AR models and play games with console-quality graphics at high frame rates faster than ever. All while enjoying all-day battery life.
  • A complete film studio in your hands
    The high-performance media engine on M2 accelerates ProRes encode and decode. You can convert video projects to ProRes faster. And with the image signal processor in M2 and advanced cameras on iPad Pro, you can capture ProRes video. Five studio-quality microphones and four-speaker audio with support for Dolby Atmos let you record and deliver cinema-quality sound.
  • Liquid Retina XDR display
    The Liquid Retina XDR display delivers true-to-life detail with a 1000000:1 contrast ratio, great for viewing and editing HDR photos and videos or enjoying your favorite movies and TV shows. It also features a breathtaking 1000 nits of full-screen brightness and 1600 nits of peak brightness along with advanced display technologies like P3 wide color, True Tone and ProMotion. And you can use Reference Mode for a more color-accurate workflow.
  • Mini-LEDs
    To achieve extremely high brightness, an array of LEDs was used across the entire back of the display. To fit them in the incredibly thin iPad Pro, custom-designed mini-LEDs were used. Custom-size optical films and diffusers mix the light more efficiently and fit in a thin design.
  • Local dimming zones
    Over 10000 mini-LEDs are grouped into more than 2500 local dimming zones. Depending on the content, the brightness in each zone can be precisely adjusted to achieve an astonishing 1000000:1 contrast ratio. Even the most detailed HDR content with the finest specular highlights - like galaxies and action movie explosions - are more true to life than ever.
  • Front-facing camera
    The iPad Pro features an Ultra-Wide camera with a 12MP sensor and a 122-degree field of view, perfect for capturing photos and video for social posts, FaceTime calls with Centre Stage, or epic Portrait mode selfies. And it works with the TrueDepth camera to securely unlock iPad Pro with Face ID.
  • Centre Stage
    Using the Ultra-Wide camera and machine learning, Centre Stage changes the way you participate in video calls. As you move around, it automatically adjusts to keep you centered in the frame. When others join in or leave the call, the view expands or zooms in. Centre Stage works with FaceTime and other video conferencing apps for an even more engaging experience.
  • Pro cameras
    Advanced Wide and Ultra-Wide cameras help you capture the perfect photo or video. And with support for ProRes video capture, iPad Pro is a complete mobile video studio. The more powerful ISP in the M2 chip also supports Smart HDR 4, so photos shot on iPad look even more true to life.
  • LiDAR scanner
    The LiDAR scanner measures how long it takes light to reflect back from objects, so it can create a depth map of any space you're in and unlock immersive AR experiences. And it works with the powerful ISP to more accurately focus images and videos in low-light conditions and reduce capture time.
  • Blazing-fast connections
    The iPad has always been uniquely portable with superfast Wi-Fi. With Wi-Fi 6E, you've got faster wireless connection. So, you'll get faster transfers of photos, documents and large video files.
Apple 12.9-inch iPad Pro Wi-Fi - 6th generation - tablet - 1 TB - 12.9"
Tablet
Display
12.9" IPS Mini LED backlight - 2732 x 2048 (264 ppi) - Multi-Touch
Apple M2 (8-core)
Storage
1 TB
RAM
16 GB
Wireless Connectivity
802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
Rear Camera
12 Megapixel focus: automatic
Second Rear Camera
10 Megapixel
Front Camera
12 Megapixel
Security Devices
Face ID
Battery Run Time
Up to 10 hours
21.49 cm x 0.64 cm x 28.06 cm
682 g
Space grey
Environmental Standards
ENERGY STAR Qualified
0.77 W/kg
1-year warranty
Tablet
Operating System
Apple iPadOS 16
Display
12.9" IPS - Mini LED backlight
Resolution
Touchscreen
Multi-Touch
Image Brightness
600 cd/m²
Anti-reflective, BFR/PVC-free, Mercury free, arsenic-free glass, beryllium free, fully laminated display, True Tone display, ProMotion technology, HDR10 compatible, fingerprint-resistant oleophobic coating, HLG gamma, Liquid Retina display, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), Apple Pencil (2nd generation) support, Dolby Vision, 2D backlighting system, 1000 cd/m² max full-screen brightness, 1600 cd/m² peak brightness (HDR), 1.8% reflectivity, Audio Description, Live Captions, 2596 local dimming zones
Apple M2
Number of Cores
8-core
Storage
1 TB
RAM
16 GB
Communications
Rear Camera
Sensor Resolution
12 Megapixel
Camera Zoom
2x optical zoom, 5x digital zoom
Focus Adjustment
Automatic
Lens Aperture
F/1.8
Lens Element Qty
5-element
HDR Mode
Smart HDR 4
Camera Modes
Burst mode, Panorama, Time-lapse mode, Slow motion mode, wide colour capture for photos and Live Photos, Wide
Light Source
Brighter True Tone flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, 1920 x 1080 (1080p) at 25 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 3840 x 2160 (4K) at 25 fps
Sapphire crystal lens cover, Cinematic video stabilisation, Focus Pixels, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, Time-lapse video with stabilisation, Advanced red-eye correction, Panorama (up to 63MP), HEIF image capture, Audio zoom, Extended dynamic range for video at 30 fps, 2x optical zoom out, JPEG image capture
Second Rear Camera
Sensor Resolution
10 Megapixel
Lens Aperture
F/2.4
Field of View (FoV)
125 degree(s)
Ultra-wide angle shot, Lens correction
Front Camera
Sensor Resolution
12 Megapixel
Lens Aperture
F/2.4
Field of View (FoV)
122 degree(s)
HDR Mode
Smart HDR 4
Camera Modes
Burst mode, Time-lapse mode, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos, Ultra Wide Mode, Centre Stage
Special Effects
Natural, Studio, Contour, Stage, Stage Mono, High-Key Mono
Light Source
Retina Flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1920 x 1080 (1080p) at 25 fps
FaceTime HD camera, Auto image stabilisation, Animoji, Memoji, TrueDepth camera, Cinematic video stabilisation, Extended dynamic range for video at 30 fps, Time-lapse video with stabilisation, Lens correction
Multimedia
Graphics
Apple M2 10-core
Supported Digital Audio Standards
AAC, MP3, FLAC, Apple Lossless, Dolby Atmos, Dolby Digital, Dolby Digital Plus
Supported Digital Video Standards
H.264, HEVC, ProRes, ProRes RAW
Audio
5 microphones, four speakers
Input Device
Security Devices
Face ID
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Stocks, iMovie, Weather, Siri, Books, Reminders, Music, Settings, Voice Memos, iTunes Store, Numbers, GarageBand, Pages, Keynote, Podcasts, Apple Pay, Trailers, Apple TV App, Home, Measure, Tips, Find My, Shortcuts, Translate, Magnifier
System Requirements for PC Connection
Windows 10 or later, Apple macOS Catalina 10.15 or later
Expansion and Connectivity
1 x Thunderbolt 3/DisplayPort/USB4 , 1 x Smart Connector , 1 x Magnetic connector
Lithium polymer
40.88 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s)
Space grey
Case Material
Aluminum
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer, LiDAR scanner
VoiceOver screen reader, AirPlay, Dictation, AssistiveTouch, iBeacon microlocation, Voice Control, rounded corners, 2x2 MiMo function, Magnifier, Closed Captions, Switch Control, Spoken Content, Spatial Audio, 100 GB/s memory bandwidth, hands-free, video decode engine, video encode engine, ProRes encode and decode engine
20W USB-C power adapter
USB-C charge cable - 1 m
0.77 W/kg
21.49 cm
0.64 cm
28.06 cm
682 g
Sustainability Information
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
35 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
45 °C
Max Altitude Operating
3 km
H1TV Apple AirTag 4-Pack In Stock £99.17
H1TV Apple USB-C Woven Charge Cable (1m) In Stock £21.19
