To create an iPad this huge, no detail was too small. From the way images are brought to life to its considerable versatility, it was pushed every aspect of what's possible with iPad to advanced heights. The end result, unmistakable the moment you begin using it, goes beyond a larger display. Unlike anything before it, iPad Pro is a far bigger experience.
M2 chip
M2 turbocharges machine learning with a faster Neural Engine and has extra memory-ordinary power that brings unprecedented performance and capabilities to the iPad Pro. You'll be able to create ultra-realistic 3D designs, build complex AR models, and immerse yourself in games with console graphics at even higher frame rates. And even when you throw yourself into such intense activities, you can count on a battery that lasts a full day. -
Take video production into your own hands
The M2 chip has a high-performance media engine that speeds up ProRes encoding and decoding-now conversion to this format is faster. -
XDR Liquid Retina Display
The Liquid Retina XDR display achieves an extraordinarily realistic level of definition. With excellent contrast, it's ideal for viewing and editing HDR photos and videos, and it's also perfect for enjoying movies and TV series. Its brightness is to die for. It comes standard with advanced technologies such as ProMotion, True Tone and the wide P3 color gamut. Plus you can use it in Reference mode, an essential aid for all jobs that require absolute color accuracy. -
Zone-based brightness management
The more than 10,000 mini-LEDs are grouped into more than 2,500 local dimming zones. The brightness of each is carefully adjusted according to what you're seeing, to achieve the incredible level of contrast. This ensures that even the most detailed HDR images and the most spectacular lighting effects, from explosions in action movies to panoramas of stars and galaxies, are rendered extremely accurately. -
Front-facing camera
iPad Pro has an ultra-wide-angle front-facing camera with a 12MP sensor and 122° field angle, ideal for taking photos and videos to post on social media. With the Auto Frame feature it always keeps you center stage in FaceTime calls, and there is also Portrait mode for taking beautiful selfies. It also works together with the TrueDepth camera to let you securely unlock your device with Face ID. -
Automatic framing
With ultra-wide-angle and machine learning, the Auto Frame feature frees you from your desk during video calls. Move around the room, and the frame will shift so you're never out of view. The lens also narrows the field or widens it as other people join you or leave during the call. And it also works with other developers' video conferencing apps, not just FaceTime. So you'll always be center stage. -
Ultra-wide-angle
The LiDAR scanner measures the time it takes light to reach an object and return, creating a depth map of the space you're in and making incredibly immersive AR experiences possible. Plus, it works with the powerful ISP processor to focus images and videos more accurately when there is little light, and reduce capture time. -
Ultra-fast connections
With ultrafast Wi-Fi and cellular connectivity, iPad has always been a champion of portability. And with Wi-Fi, you have the fastest wireless connection-everything goes like clockwork, even when sending large photos, files, and videos. -
5G
With 5G compatibility, you can connect to the fastest networks to download or share files, watch movies, and work in teams wherever you are. Not only that, iPad Pro supports more bands than any other tablet, so you blaze through 5G in even more places.
- Apple 12.9-inch iPad Pro Wi-Fi + Cellular - 2nd generation - tablet - 64 GB - 12.9" - 3G, 4G
- Product Type
- Tablet
- Display
- 12.9" IPS TFT - LED backlight - 2732 x 2048 (264 ppi) - Multi-Touch
- Processor
- Apple A10X Fusion (6-core) - 64-bit
- Storage
- 64 GB
- Cellular Technology
- 3G, 4G
- Cellular Protocols
- GSM, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, HSPA, HSPA+, LTE, DC-HSDPA, CDMA 2000 1X EV-DO Rev. B, LTE Advanced
- Wireless Connectivity
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Rear Camera
- 12 Megapixel focus: automatic
- Front Camera
- 7 Megapixel
- Navigation System
- A-GPS/GLONASS
- Security Devices
- Fingerprint reader
- Battery Run Time
- Up to 10 hours
- 22.06 cm x 0.69 cm x 30.57 cm
- 692 g
- Gold
- Localisation
- English / United Kingdom
- Specific Absorption Rate (SAR)
- 0.97 W/kg (body)
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Apple iOS 12
Display
- Resolution
- Touchscreen
- Multi-Touch
- Anti-glare, anti-reflective, anti-fingerprint, Retina display, fully laminated display, True Tone display, ProMotion technology
- Processor
- Apple A10X Fusion
- Number of Cores
- 6-core
- 64-bit Computing
- Storage
- 64 GB
Communications
- 3G, 4G
- Band
- GSM 850/900/1800/1900 / UMTS 850/900/1700/1900/2100 / CDMA 2000 X1 800/1900 / LTE 700/700 APT/700b/700c/700 de/800/ 800 DD/850/900/1500/1800/1900/TD 1900/2100/2300/TD 2300/TD 2500/2600/TD 2600/AWS
Rear Camera
- Sensor Resolution
- 12 Megapixel
- Camera Zoom
- 5x digital zoom
- Focus Adjustment
- Automatic
- Lens Aperture
- F/1.8
- HDR Mode
- Auto HDR mode
- Face Detection
- Body and face detection
- Sapphire crystal lens cover, Focus Pixels, Cinematic video stabilisation, Live Photo, Playback zoom, Hybrid IR filter, Exposure control, noise reduction, geotagging
Front Camera
- Sensor Resolution
- 7 Megapixel
- Lens Aperture
- F/2.2
- FaceTime HD camera
Navigation System
- Receiver
- A-GPS/GLONASS
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, MP3 VBR
- Supported Digital Video Standards
- MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K)
- Audio
- Two microphones, four speakers
Input Device
- Security Devices
Software
- Preloaded Software
- Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Find My iPhone, Stocks, Siri, Books, Reminders, Music, Find My Friends, Voice Memos, iTunes Store, Podcasts, Apple TV App, Home, Measure
System Requirements for PC Connection
- OS Required
- Microsoft Windows 7 or later, Apple MacOS X 10.9.5 or later
Expansion and Connectivity
- 1 x headphones mini jack (3.5mm) , 1 x Lightning , 1 x Smart Connector
- Technology
- Lithium polymer
- Capacity
- 41 Wh
- Run Time
- Up to 10 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s)
- Gold
- Sensors
- Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer
- Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, iBeacon microlocation, Family Sharing, Night Shift, Apple M10 motion coprocessor
- Included Accessories
- Power adapter
- Cables Included
- Lightning to USB cable
- 0.97 W/kg (body)
- Localisation
- 22.06 cm
- 0.69 cm
- 30.57 cm
- 692 g
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 45 °C
- Max Altitude Operating
- 3 km
