Astonishing performance. An incredibly advanced display. Superfast wireless connectivity. Powerful features. The ultimate iPad experience.
M2 chip
The M2 chip is the next generation of Apple silicon, with a CPU that delivers faster performance and a GPU that provides faster graphics performance. With a faster Neural Engine to accelerate machine learning tasks and more memory bandwidth, M2 brings astonishing performance and capabilities to iPad Pro. So, you can create photorealistic 3D designs, build intricate AR models and play games with console-quality graphics at high frame rates faster than ever. All while enjoying all-day battery life. -
A complete film studio in your hands
The high-performance media engine on M2 accelerates ProRes encode and decode. You can convert video projects to ProRes faster. And with the image signal processor in M2 and advanced cameras on iPad Pro, you can capture ProRes video. Five studio-quality microphones and four-speaker audio with support for Dolby Atmos let you record and deliver cinema-quality sound. -
Liquid Retina XDR display
The Liquid Retina XDR display delivers true-to-life detail with a 1000000:1 contrast ratio, great for viewing and editing HDR photos and videos or enjoying your favorite movies and TV shows. It also features a breathtaking 1000 nits of full-screen brightness and 1600 nits of peak brightness along with advanced display technologies like P3 wide color, True Tone and ProMotion. And you can use Reference Mode for a more color-accurate workflow. -
Mini-LEDs
To achieve extremely high brightness, an array of LEDs was used across the entire back of the display. To fit them in the incredibly thin iPad Pro, custom-designed mini-LEDs were used. Custom-size optical films and diffusers mix the light more efficiently and fit in a thin design. -
Local dimming zones
Over 10000 mini-LEDs are grouped into more than 2500 local dimming zones. Depending on the content, the brightness in each zone can be precisely adjusted to achieve an astonishing 1000000:1 contrast ratio. Even the most detailed HDR content with the finest specular highlights - like galaxies and action movie explosions - are more true to life than ever. -
Front-facing camera
The iPad Pro features an Ultra-Wide camera with a 12MP sensor and a 122-degree field of view, perfect for capturing photos and video for social posts, FaceTime calls with Centre Stage, or epic Portrait mode selfies. And it works with the TrueDepth camera to securely unlock iPad Pro with Face ID. -
Centre Stage
Using the Ultra-Wide camera and machine learning, Centre Stage changes the way you participate in video calls. As you move around, it automatically adjusts to keep you centered in the frame. When others join in or leave the call, the view expands or zooms in. Centre Stage works with FaceTime and other video conferencing apps for an even more engaging experience. -
Pro cameras
Advanced Wide and Ultra-Wide cameras help you capture the perfect photo or video. And with support for ProRes video capture, iPad Pro is a complete mobile video studio. The more powerful ISP in the M2 chip also supports Smart HDR 4, so photos shot on iPad look even more true to life. -
LiDAR scanner
The LiDAR scanner measures how long it takes light to reflect back from objects, so it can create a depth map of any space you're in and unlock immersive AR experiences. And it works with the powerful ISP to more accurately focus images and videos in low-light conditions and reduce capture time. -
Blazing-fast connections
The iPad has always been uniquely portable with superfast Wi-Fi and cellular options. With Wi-Fi 6E, you've got faster wireless connection. So, you'll get faster transfers of photos, documents and large video files.
- Apple 12.9-inch iPad Pro Wi-Fi + Cellular - 6th generation - tablet - 256 GB - 12.9" - 3G, 4G, 5G
- Product Type
- Tablet
- Display
- 12.9" IPS Mini LED backlight - 2732 x 2048 (264 ppi) - Multi-Touch
- Processor
- Apple M2 (8-core)
- Storage
- 256 GB
- RAM
- 8 GB
- Cellular Technology
- 3G, 4G, 5G
- Cellular Protocols
- UMTS, HSPA, HSPA+, DC-HSDPA, FDD LTE, TDD LTE, 5G NR
- Wireless Connectivity
- 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Bluetooth 5.3
- Rear Camera
- 12 Megapixel focus: automatic
- Second Rear Camera
- 10 Megapixel
- Front Camera
- 12 Megapixel
- Navigation System
- GPS/GNSS
- Security Devices
- Face ID
- Battery Run Time
- Up to 10 hours
- 21.49 cm x 0.64 cm x 28.06 cm
- 685 g
- Silver
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- SAR
- 0.99 W/kg
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Apple iPadOS 16
Display
- 12.9" IPS - Mini LED backlight
- Resolution
- Touchscreen
- Multi-Touch
- Image Brightness
- 600 cd/m²
- Anti-reflective, BFR/PVC-free, Mercury free, arsenic-free glass, beryllium free, fully laminated display, True Tone display, ProMotion technology, HDR10 compatible, fingerprint-resistant oleophobic coating, HLG gamma, Liquid Retina display, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), Apple Pencil (2nd generation) support, Dolby Vision, 2D backlighting system, 1000 cd/m² max full-screen brightness, 1600 cd/m² peak brightness (HDR), 1.8% reflectivity, Audio Description, Live Captions, 2596 local dimming zones
- Processor
- Apple M2
- Number of Cores
- 8-core
- Storage
- 256 GB
- RAM
- 8 GB
Communications
- 3G, 4G, 5G
- Band
- UMTS/HSPA/HSPA+/DC-HSDPA 850/900/1700/2100/1900/2100 / 5G NR n1-3/5/7/8/12/14/20/25/26/28/29/30/38/40/41/48/66/70/71/77/78/79 / 5G NR mmWave n258/260/261 / LTE FDD B1-5/7/8/11-14/17-21/25/26/28/29/30/32/66/71 / TD-LTE B34/38-42/46/48
Rear Camera
- Sensor Resolution
- 12 Megapixel
- Camera Zoom
- 2x optical zoom, 5x digital zoom
- Focus Adjustment
- Automatic
- Lens Aperture
- F/1.8
- Lens Element Qty
- 5-element
- HDR Mode
- Smart HDR 4
- Camera Modes
- Burst mode, Panorama, Time-lapse mode, Slow motion mode, wide colour capture for photos and Live Photos, Wide
- Light Source
- Brighter True Tone flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, 1920 x 1080 (1080p) at 25 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 3840 x 2160 (4K) at 25 fps
- Sapphire crystal lens cover, Cinematic video stabilisation, Focus Pixels, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, Time-lapse video with stabilisation, Advanced red-eye correction, Panorama (up to 63MP), HEIF image capture, Audio zoom, Extended dynamic range for video at 30 fps, 2x optical zoom out, JPEG image capture
Second Rear Camera
- Sensor Resolution
- 10 Megapixel
- Lens Aperture
- F/2.4
- Field of View (FoV)
- 125 degree(s)
- Ultra-wide angle shot, Lens correction
Front Camera
- Sensor Resolution
- 12 Megapixel
- Lens Aperture
- F/2.4
- 122 degree(s)
- HDR Mode
- Smart HDR 4
- Camera Modes
- Burst mode, Time-lapse mode, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, wide colour capture for photos and Live Photos, Ultra Wide Mode, Centre Stage
- Special Effects
- Natural, Studio, Contour, Stage, Stage Mono, High-Key Mono
- Light Source
- Retina Flash
- Video Resolutions
- 1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1920 x 1080 (1080p) at 25 fps
- FaceTime HD camera, Auto image stabilisation, Animoji, Memoji, TrueDepth camera, Cinematic video stabilisation, Extended dynamic range for video at 30 fps, Time-lapse video with stabilisation, Lens correction
Navigation System
- Receiver
- GPS/GNSS
Multimedia
- Graphics
- Apple M2 10-core
- Supported Digital Audio Standards
- AAC, MP3, FLAC, Apple Lossless, Dolby Atmos, Dolby Digital, Dolby Digital Plus
- Supported Digital Video Standards
- H.264, HEVC, ProRes, ProRes RAW
- Audio
- 5 microphones, four speakers
Input Device
- Security Devices
- Face ID
Software
- Preloaded Software
- Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Stocks, iMovie, Weather, Siri, Books, Reminders, Music, Settings, Voice Memos, iTunes Store, Numbers, GarageBand, Pages, Keynote, Podcasts, Apple Pay, Trailers, Apple TV App, Home, Measure, Tips, Find My, Shortcuts, Translate, Magnifier
System Requirements for PC Connection
- OS Required
- Windows 10 or later, Apple macOS Catalina 10.15 or later
Expansion and Connectivity
- 1 x Thunderbolt 3/DisplayPort/USB4 , 1 x Smart Connector , 1 x Magnetic connector
- Technology
- Lithium polymer
- Capacity
- 40.88 Wh
- Run Time
- Up to 10 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s)
- Silver
- Case Material
- Aluminum
- Sensors
- Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer, LiDAR scanner
- VoiceOver screen reader, AirPlay, Dictation, AssistiveTouch, iBeacon microlocation, Voice Control, rounded corners, 2x2 MiMo function, Magnifier, Closed Captions, Switch Control, 16-core Neural Engine, Spoken Content, Spatial Audio, 100 GB/s memory bandwidth, hands-free, video decode engine, video encode engine, ProRes encode and decode engine
- Included Accessories
- 20W USB-C power adapter
- Cables Included
- USB-C charge cable - 1 m
- SAR Value
- 0.99 W/kg
- Localisation
- 21.49 cm
- 0.64 cm
- 28.06 cm
- 685 g
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 45 °C
- Max Altitude Operating
- 3 km
Apple USB-C to 3.5 mm Headphone Jack Adapter | In Stock | £7.21 |
Apple Pencil Generation 2 | In Stock | £115.84 |
Apple USB-C Digital AV Multiport Adapter - Docking station | In Stock | £60.29 |
Apple AirPods - 2nd Generation | In Stock | £95.83 |
Apple Smart Keyboard Folio for the 12.9-inch iPad Pro - 3rd/4th Gen | In Stock | £195.38 |
Apple AirPods Max - Space Grey | In Stock | £415.84 |
Apple AirPods Max - Silver | In Stock | £415.84 |
Apple AirPods Max - Green | In Stock | £415.84 |
Apple AirPods Max - Sky Blue | In Stock | £415.84 |
Apple AirPods Max - Pink | In Stock | £415.84 |
Apple AirTag | In Stock | £25.00 |
Apple AirTag 4-Pack | In Stock | £99.17 |
Apple Magic Keyboard iPad Pro 12.9 Black | In Stock | £315.84 |
Apple AirPods (3rd Gen) with MagSafe Charging Case | In Stock | £140.84 |
Apple Magic Keyboard for iPad Pro 12.9" Black | In Stock | £338.13 |
Apple AirPods (3rd Gen) with Lightning Charging Case | In Stock | £132.50 |
Apple USB-C Woven Charge Cable (1m) | In Stock | £15.24 |
Apple HomePod - Midnight (2nd Gen 2023) | In Stock | £249.17 |
Apple HomePod - White (2nd Gen 2023) | In Stock | £249.17 |
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H1VX 048542 Condition: Customer return - item has been used and shows signs of use |
£1,143.75 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
