Apple  Battery case for mobile phone silicone black for iPhone XS
Quicklinx: F2CDWS00 Mfr#: MRXQ2ZM/A
The Smart battery case gives you even longer battery life while offering great protection. Inside, a soft microfiber lining helps protect your phone. And on the outside, the silky, soft-touch finish of the silicone exterior feels great in your hand. A soft elastomer hinge design makes it easy to put the case on and take it off.
Apple Smart - battery case for mobile phone
Material
Silicone
iPhone XS Max
Material
Silicone
Lining Material
Microfibre
Carrying Case
Battery case
Recommended Use
For mobile phone
Wireless Charging Standards
Qi
Lithium
Apple iPhone XS Max
