APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U
Quicklinx: CX22WS00 Mfr#: AR7580A
£265.77 ex VAT
£318.92 inc VAT
The vertical channels have smooth plastic fingers at 1U increments to allow patch cords to enter and exit in an organized manner.
Cable managers feature high capacity slim cable fingers to provide maximum capacity at every rackspace unit and a rigid design to decrease deflection when cables are routed in/out of the cable manager channel.
  • High capacity cable finger design
    Cable managers feature high capacity slim cable fingers to provide maximum capacity at every rack space unit and a rigid design to decrease deflection when cables are routed in/out of the cable manager channel.
  • Backplate optimized for accessorizing
    Backplates feature multiple holes for toollessly mounting accessories such as cable managers for cable tie-off (AR8621) and airflow management brush strips (AR7714) to allow cable pass-through while restricting airflow through the openings.
  • Dedicated cable manager for each enclosure height
    Dedicated cable managers for each enclosure height 42U, 45U, and 48U, provide the maximum u-space coverage. Optional covers will match cable manager height to provide full coverage over the entire height of the enclosure.
  • Secure cabling with easy access
    Secure cabling inside the cable manager with the provided snap hinge cable retainers that open to the left or right for easy access.
  • Optional hinging left or right covers
    Covers (not provided) install quickly without tools and include two easy to use latches that allow the cover to open to the left or right. The covers hide the cabling to keep the enclosure space neat for future maintenance and an clean aesthetic.
APC - rack cable management kit - 42U
Rack cable management kit
Packaged Quantity
2 (specifications are for single item)
Height (Rack Units)
42U
9.7 cm x 16 cm x 177.8 cm
4.09 kg
Vertical orientation
NetShelter SX
Packaged Quantity
Height (Rack Units)
42U
9.7 cm
16 cm
177.8 cm
4.09 kg
Mounting Kit
Included
RoHS, REACH
TAA Compliant
Limited warranty: - 2 years
APC NetShelter SX
CX22 APC AP9520TH TEMP & HUMIDITY In Stock £262.08
Product Type: Rack cable management kit
Brand: APC
