APC UPS 2kvA LCD 230V SmartConnect
Quicklinx: F3ZFWS00 Mfr#: SMT2200IC
Type: UPS
Power Rating: 1980Watt
More than 50 In Stock
£1,102.03 ex VAT
£1,322.43 inc VAT
Intelligent and efficient network power protection from entry level to scaleable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
  • StruxureWare Data Center Expert compatible
    Enables centralized management via StruxureWare Data Center Expert.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • Software package
    SmartConnect software for remote power monitoring feature availability varies by terms of use
  • Communication port support
    SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Sequenced network shutdown and reboot
    Customize network shutdown and reboot sequence of connected servers and UPSs.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Intelligent Card Slot
    Customize UPS capabilities with management cards.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS SMT2200IC - UPS - 1980 Watt - 2200 VA - Lead Acid - with APC SmartConnect
UPS - external
48.8 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
1980 Watt / 2200 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 2 x IEC jumper , 1 x power IEC 60320 C19
Lead Acid Lead Acid
Batteries Qty
1
Run Time (Up To)
8.7 min at full load
RS-232, USB
19.7 cm x 54.4 cm x 43.5 cm
3-year warranty
Bundled with
APC SmartConnect
UPS - external
Bundled with
APC SmartConnect
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
50/60 Hz ± 3Hz
Frequency Required
50/60 Hz ± 3Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 50/60 Hz
Power Capacity
1980 Watt / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
365 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid Lead Acid
Run Time (Up To)
8.7 min at full load , 25 min at half load
Recharge Time
3 hours
Transfer Time
6 ms
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) , 1 x USB , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , USB cable - external
Audible alarm, emergency power off, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic self-test, predicitive failure notification, hot-swappable batteries, energy metre
CSA, UL 1778, VDE, IEC 62040-2, RoHS, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
Software Included
APC PowerChute Business Edition
Limited warranty - replace or repair - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
45 dBA
19.7 cm
54.4 cm
43.5 cm
48.8 kg
Shipping Width
38.1 cm
Shipping Depth
76.2 cm
Shipping Height
69.9 cm
Shipping Weight
61.9 kg
F3ZF APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.83
F3ZF APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £50.78
F3ZF APC - Power cable - Male-Female - 1.98 m In Stock £50.45
F3ZF APC Basic Rack-Mount PDU - power distribution strip In Stock £203.03
F3ZF APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.28
F3ZF APC Power cable - 2.4 m In Stock £85.15
F3ZF APC Rack PDU Basic Zero U 16A 208/230V In Stock £295.63
F3ZF APC Replacement Battery Cartridge RBC55 In Stock £436.60
F3ZF APC Temperature and Humidity Sensor In Stock £132.56
F3ZF APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £296.69
F3ZF APC APC POWERCORD C19 TO C20 1.8M In Stock £189.39
F3ZF APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £976.20
F3ZF APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £89.29
F3ZF APC Power Cord Locking C19 to C20 3.0m In Stock £69.88
F3ZF APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £55.05
F3ZF APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £58.76
F3ZF APC Power Cable (pack of 6) 1.22m In Stock £88.33
F3ZF APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £134.48
F3ZF APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £105.93
F3ZF APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £631.16
F3ZF APC Extended Warranty Service Pack 3 Year In Stock £162.59
F3ZF APC Switched Rack PDU AC 208-230 V Ethernet In Stock £760.50
F3ZF APC Service Pack 1 Year Warranty Extension In Stock £80.89
F3ZF APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £61.55
F3ZF APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £702.09
F3ZF APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,246.30
F3ZF APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.84
F3ZF APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.02
Type: UPS
Brand: APC
Price Range Ex VAT: £1000 - £1500
