Intelligent and efficient network power protection from entry level to scaleable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
StruxureWare Data Center Expert compatible
Enables centralized management via StruxureWare Data Center Expert. -
SmartConnect
Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services. -
Software package
SmartConnect software for remote power monitoring feature availability varies by terms of use -
Communication port support
SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use -
High online efficiency
Reduces utility costs, generates less heat. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users. -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning. -
Intuitive LCD interface
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. -
Single switched outlet group
Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding. -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
Sequenced network shutdown and reboot
Customize network shutdown and reboot sequence of connected servers and UPSs. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Intelligent Card Slot
Customize UPS capabilities with management cards. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS SMT2200IC - UPS - 1980 Watt - 2200 VA - Lead Acid - with APC SmartConnect
- UPS - external
- 48.8 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 220/230/240 V ± 5%
- Power Capacity
- 1980 Watt / 2200 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 8 x power IEC 60320 C13 , 2 x IEC jumper , 1 x power IEC 60320 C19
- Battery
- Lead Acid Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 8.7 min at full load
- Networking
- RS-232, USB
- Black
- 19.7 cm x 54.4 cm x 43.5 cm
- 3-year warranty
- Bundled with
- APC SmartConnect
- UPS - external
- Black
- Bundled with
- APC SmartConnect
- UPS Technology
- Line interactive
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Provided
- 50/60 Hz ± 3Hz
- Frequency Required
- 50/60 Hz ± 3Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 5% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 365 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Run Time (Up To)
- 8.7 min at full load , 25 min at half load
- Recharge Time
- 3 hours
- Transfer Time
- 6 ms
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) , 1 x USB , 1 x EPO (emergency power off)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Serial cable - external , USB cable - external
- Audible alarm, emergency power off, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic self-test, predicitive failure notification, hot-swappable batteries, energy metre
- CSA, UL 1778, VDE, IEC 62040-2, RoHS, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
- Software Included
- APC PowerChute Business Edition
- Limited warranty - replace or repair - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 19.7 cm
- 54.4 cm
- 43.5 cm
- 48.8 kg
- Shipping Width
- 38.1 cm
- Shipping Depth
- 76.2 cm
- Shipping Height
- 69.9 cm
- Shipping Weight
- 61.9 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £29.76 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £49.49 |
APC - Power cable - Male-Female - 1.98 m | In Stock | £49.24 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £199.36 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £52.59 |
APC Power cable - 2.4 m | In Stock | £83.05 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £294.53 |
APC Replacement Battery Cartridge RBC55 | In Stock | £421.97 |
APC Temperature and Humidity Sensor | In Stock | £131.36 |
APC POWER CORD C13 TO C20 1.98m Black | In Stock | £51.35 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £284.90 |
APC Power Cord Locking C19 to IEC309-16A 3.0m | In Stock | £84.10 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £68.95 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £51.93 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £58.03 |
APC Power Cable (pack of 6) 1.22m | In Stock | £85.46 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £130.76 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £630.78 |
APC Extended Warranty Service Pack 3 Year | In Stock | £152.13 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £739.43 |
APC Service Pack 1 Year Warranty Extension | In Stock | £72.51 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £59.64 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,159.17 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £653.11 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,245.58 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £157.34 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £82.70 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £465.61 |
