APC Symmetra PX 10kW Power Module
Quicklinx: 86B9WS00 Mfr#: SYPM10K16H
  • Increases adaptability with an open architecture configurable to any IT environment.
  • Modular construction - can be deployed as a non-standby and migrate to a standby (UPS) system.
  • Provides fast serviceability and reduced maintenance requirements via self-diagnosing, field-replaceable modules.
  • Minimizes installation costs by enabling the use of smaller generators and cabling.
  • Modular design provides scalable solutions to add cooling as demand increases.
  • Input Power Factor Correction
    This product has a power factor corrected input side ensuring that the input power factor is always 1 regardless of load and mains voltage. A power factor of 1 minimizes installation costs by allowing the use of smaller cables and smaller fuses.
  • Modular design
    Enables IT projects that were previously infeasible or cost-prohibitive.
APC Symmetra PX Power Module - UPS - 16 kW - 16000 VA
UPS - plug-in module
Rack Size
3U
28.5 kg
Input Wiring
3-phase
Input Voltage
AC 400 V
Output Voltage
AC 230/380/400/415 V ± 2%
Power Capacity
16 kW / 16000 VA
Input Connectors
1 x hardwire 5-wire (3PH + N + G)
Output connectors
No battery
48.3 cm x 70 cm x 13.2 cm
1-year warranty
P/N: SY128K160H, SY128K160H-NB, SY160K160H, SY160K160H-NB, SY160K160H-PD, SY16K48H-PD, SY32K160H-NB, SY32K96H, SY32K96H-NB, SY32K96H-PD, SY48K48H-PD, SY64K160H, SY64K160H-NB, SY64K160H-PD, SY64K96H, SY64K96H-NB, SY64K96H-PD, SY96K160H-NB, SY96K160H-PD, SY96K96H, SY96K96H-NB, SY96K96H-PD
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 400 V
Input Voltage Range
AC 340 - 477 V
Frequency Provided
50/60 Hz
Input Voltage Margin
± 5%
Input Wiring
3-phase
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230/380/400/415 V ± 2% - 50/60 Hz
Power Capacity
16 kW / 16000 VA
Output Waveform
Sinewave
No battery
FCC Class A certified, FCC Part 15, EN 50091-1
Limited warranty - 1 year
0 - 95%
Sound Emission
63 dBA
48.3 cm
70 cm
13.2 cm
28.5 kg
Shipping Width
59.5 cm
Shipping Depth
70 cm
Shipping Height
22.5 cm
Shipping Weight
31.6 kg
P/N: SY128K160H, SY128K160H-NB, SY128K160H-PD, SY160K160H, SY160K160H-NB, SY160K160H-PD, SY16K48H-PD, SY32K160H, SY32K160H-NB, SY32K160H-PD, SY32K96H, SY32K96H-NB, SY32K96H-PD, SY48K48H-PD, SY64K160H, SY64K160H-NB, SY64K160H-PD, SY64K96H, SY64K96H-NB, SY64K96H-PD, SY96K160H, SY96K160H-NB, SY96K160H-PD, SY96K96H, SY96K96H-NB, SY96K96H-PD
