APC Symmetra LX Intelligence Module
Quicklinx: 6ZSTWS00 Mfr#: SYMIM5
Type: UPS
Power Rating: [N/A]
£900.61 ex VAT
£1,080.73 inc VAT
APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
  • Efficient power management
    The APC Intelligence Module is designed to optimize power control, ensuring your PC operates smoothly with enhanced power efficiency. Its Plug-and-Play form factor allows for easy integration into existing systems, providing a seamless upgrade path for power management.
  • Expansion capability
    With a dedicated expansion slot, this power control unit offers the flexibility to enhance your system's power infrastructure. It's tailored for PCs, making it a perfect fit for personal computing environments seeking to expand their power capabilities.
APC Intelligence Module - power control unit
Power control unit - plug-in module
2 kg
16.8 cm x 49.9 cm x 4.1 cm
Symmetra LX
USB Power Delivery Output
(Expansion Slot)
16.8 cm
49.9 cm
4.1 cm
2 kg
APC Symmetra LX
Type: UPS
Power Rating: [N/A]
Brand: APC
Price Range Ex VAT: £750 - £1000
