APC SYMMETRA LX EXT RUN RM
Quicklinx: 70X2WS00 Mfr#: SYARMXR9B9I
Type: Battery
Power Rating: [N/A]
£6,988.97 ex VAT
£8,386.76 inc VAT
Hot-swappable battery ensures clean, uninterrupted power to protected equipment while batteries are being replaced.
Plug-and-Play external battery ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS.
  • Battery modules connected in parallel
    Delivers higher availability through redundant batteries.
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced.
  • Plug-and-Play external batteries
    Ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS.
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
  • Modular design
    Increases adaptability with an open architecture configurable to any IT environment.
APC Extended Run - power array cabinet
Power array cabinet - rack-mountable
Rack Size
13U
313 kg
Input Voltage
AC 230 V
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
9 (supported) 9
47.2 cm x 68.6 cm x 57.2 cm
P/N: AR3357X674, ISXCR1SY16K16P5, ISXT216MD1RI, SYA12K16I, SYA12K16ICH, SYA12K16IXR, SYA12K16IXRCH, SYA12K16RMICH, SYA16K16I, SYA16K16ICH, SYA16K16IXR, SYA16K16IXRCH, SYA16K16RMI, SYA16K16RMICH, SYA4K8RMI, SYA8K16I, SYA8K16ICH, SYA8K16IXR, SYA8K16RMI, SYA8K16RMICH, SYA8K8I, SYA8K8RMI, SYAF16KRMICH
Battery Enclosure Type
Plug-in module
Height (Rack Units)
13U
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Quantity
9 (supported) 9
Lead Acid
Voltage Provided
120 V
CSA, VCCI, BSMI, EN 60950, UL 1778, VDE, IEC 60950, EN 50091-2, EN 50091-1
0 - 95%
47.2 cm
68.6 cm
57.2 cm
313 kg
P/N: AR3357X674, ISXCR1SY16K16P5, ISXT216MD1RI, SYA12K16I, SYA12K16ICH, SYA12K16IXR, SYA12K16IXRCH, SYA12K16P, SYA12K16PXR, SYA12K16RMI, SYA12K16RMICH, SYA12K16RMP, SYA16K16I, SYA16K16ICH, SYA16K16IXR, SYA16K16IXRCH, SYA16K16P, SYA16K16PXR, SYA16K16RMI, SYA16K16RMICH, SYA16K16RMP, SYA4K8I, SYA4K8P, SYA4K8RMI, SYA4K8RMP, SYA8K16I, SYA8K16ICH, SYA8K16IXR, SYA8K16P, SYA8K16PXR, SYA8K16RMI, SYA8K16RMICH, SYA8K16RMP, SYA8K8I, SYA8K8P, SYA8K8RMI, SYA8K8RMP, SYAF16KRMICH
70X2 APC Symmetra LX Battery Module In Stock £593.56
70X2 APC Service Pack 3 Year Warranty Extension In Stock £975.99
Type: Battery
Power Rating: [N/A]
Brand: APC
Price Range Ex VAT: £1500+
