APC SX 42U 750mm x 1200mm Deep Enclosure With Side Panels
Quicklinx: C93XWS00 Mfr#: AR3350
Depth (mm): 120cm
Width (mm): 75cm
£2,311.11 ex VAT
£2,773.33 inc VAT
The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
  • Robust design
    The APC NetShelter SX Enclosure with Roof and Sides is crafted to provide a sturdy and reliable housing solution for your computing equipment. Its robust design ensures your PC components are well-protected against physical impacts and environmental factors, offering peace of mind for the security and longevity of your technology investments.
  • Seamless compatibility
    Designed with PC compatibility in mind, this rack seamlessly integrates with your existing computing setup. It eliminates the hassle of mismatched components, ensuring a smooth and efficient organization of your PC hardware within a secure enclosure.
APC NetShelter SX Enclosure with Roof and Sides - rack - 42U
Rack
Rack Size
19"
Height (Rack Units)
42U
75 cm x 120 cm x 199 cm
161 kg
Wheels
5-year warranty
Rack
Rack Size
19"
Height (Rack Units)
42U
75 cm
120 cm
199 cm
161 kg
Weight Limit
1364 kg
Wheels
EIA-310-D, IEC 60529 IP20, BAA
TAA Compliant
Limited warranty: - 5 years
C93X APC Basic Rack-Mount PDU - power distribution strip In Stock £205.11
C93X APC 1U Vertical Cable Organiser In Stock £126.54
C93X APC 1U Horizontal Cable Organiser In Stock £56.75
C93X APC Smart-UPS SC 450VA 1U In Stock £285.55
C93X APC Netshelter heavy duty shelf In Stock £143.02
C93X APC - rack cable guide - 1U In Stock £52.84
C93X APC Rackmount Rail Kit In Stock £91.99
C93X APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £206.67
C93X APC Rack PDU Basic Zero U 16A 208/230V In Stock £298.65
C93X APC Smart-UPS 5000VA In Stock £3,750.33
C93X APC Rack PDU Basic Zero U 32A 230V In Stock £325.48
C93X APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £288.08
C93X APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,205.80
C93X APC Cable Managers (Qty 10) In Stock £37.21
C93X APC 2G Power distribution strip In Stock £646.62
C93X APC Rack PDU 2G METERED ZEROU In Stock £716.89
C93X APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,301.19
C93X APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £509.59
C93X APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,686.54
C93X APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,000.79
C93X APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £982.07
C93X APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.93
C93X APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,510.85
C93X APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,494.27
C93X APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,946.22
C93X APC 1U Blanking Panel Kit In Stock £35.63
C93X APC Smart-UPS 1500VA LCD RM 1U 230V In Stock £976.63
C93X APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £57.04
C93X APC Smart-UPS SRT 6000VA RM 230V In Stock £4,896.44
C93X APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £49.22
C93X APC Smart-UPS SRT 8000VA RM 230V In Stock £6,299.60
C93X APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,665.73
C93X APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.70
C93X APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,425.62
C93X APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,617.46
C93X APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £637.60
C93X APC Smart-UPS SRT 2200VA RM 230V In Stock £1,763.13
C93X APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,839.15
C93X APC Metered Rack PDU In Stock £847.72
C93X APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,213.27
C93X APC Switched Rack PDU AC 208-230 V Ethernet In Stock £777.52
C93X APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,096.40
C93X APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.15
C93X APC Smart-UPS SRT 5000VA RM 208/230V HW In Stock £4,566.12
C93X APC Smart-UPS SRT 10000VA RM 230V In Stock £7,790.51
C93X APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £687.96
C93X APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £590.47
C93X APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £704.61
C93X APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £884.31
C93X APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,259.02
C93X APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,309.03
C93X APC Rack PDU Basic 0U/1U 100-240V/ In Stock £83.64
C93X APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,500.66
C93X APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £470.78
C93X APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,137.29
C93X APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,965.24
C93X APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £2,293.48
C93X APC Smart-UPS 750VA RM 230V SmartConnect In Stock £518.33
Depth (mm): 120cm
Width (mm): 75cm
Brand: APC
Price Range Ex VAT: £1500+
