APC SX 42U 750mm x 1200mm Deep Enclosure With Side Panels
Quicklinx: C93XWS00 Mfr#: AR3350
Depth (mm): 120cm
Width (mm): 75cm
£2,271.60 ex VAT
£2,725.92 inc VAT
The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
  • Robust design
    The APC NetShelter SX Enclosure with Roof and Sides is crafted to provide a sturdy and reliable housing solution for your computing equipment. Its robust design ensures your PC components are well-protected against physical impacts and environmental factors, offering peace of mind for the security and longevity of your technology investments.
  • Seamless compatibility
    Designed with PC compatibility in mind, this rack seamlessly integrates with your existing computing setup. It eliminates the hassle of mismatched components, ensuring a smooth and efficient organization of your PC hardware within a secure enclosure.
APC NetShelter SX Enclosure with Roof and Sides - rack - 42U
Rack
Rack Size
19"
Height (Rack Units)
42U
75 cm x 120 cm x 199 cm
161 kg
Wheels
5-year warranty
Rack
Rack Size
19"
Height (Rack Units)
42U
75 cm
120 cm
199 cm
161 kg
Weight Limit
1364 kg
Wheels
EIA-310-D, IEC 60529 IP20, BAA
TAA Compliant
Limited warranty: - 5 years
C93X APC Basic Rack-Mount PDU - power distribution strip In Stock £204.64
C93X APC 1U Vertical Cable Organiser In Stock £124.80
C93X APC 1U Horizontal Cable Organiser In Stock £55.47
C93X APC Smart-UPS SC 450VA 1U In Stock £279.98
C93X APC Netshelter heavy duty shelf In Stock £141.95
C93X APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £208.46
C93X APC Rack PDU Basic Zero U 16A 208/230V In Stock £302.47
C93X APC Smart-UPS 5000VA In Stock £3,661.99
C93X APC Rack PDU Basic Zero U 32A 230V In Stock £326.06
C93X APC Smart-UPS RT 20kVA RM 230V In Stock £12,172.54
C93X APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £289.09
C93X APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,186.69
C93X APC Cable Managers (Qty 10) In Stock £36.38
C93X APC 2G Power distribution strip In Stock £649.15
C93X APC Rack PDU 2G METERED ZEROU In Stock £687.91
C93X APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,317.04
C93X APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £511.74
C93X APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,667.34
C93X APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,000.76
C93X APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £959.96
C93X APC Fixed Shelf - 50lbs/23kg, Black In Stock £80.88
C93X APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,510.33
C93X APC NetShelter Zero U Accessory Mounting Bracket In Stock £99.01
C93X APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,457.00
C93X APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,932.90
C93X APC 1U Blanking Panel Kit In Stock £34.80
C93X APC Smart-UPS 1500VA LCD RM 1U 230V In Stock £975.47
C93X APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £55.94
C93X APC Smart-UPS SRT 6000VA RM 230V In Stock £4,787.01
C93X APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.98
C93X APC Smart-UPS SRT 8000VA RM 230V In Stock £6,184.96
C93X APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,642.73
C93X APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.11
C93X APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,389.72
C93X APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,636.88
C93X APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £638.53
C93X APC Smart-UPS SRT 2200VA RM 230V In Stock £1,801.52
C93X APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,750.54
C93X APC Metered Rack PDU In Stock £856.35
C93X APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,185.53
C93X APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £265.59
C93X APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,097.93
C93X APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.16
C93X APC Rack PDU 2G Metered-by-Outlet ZeroU 32A 230V (21) C13+(3)$ In Stock £1,207.93
C93X APC Smart-UPS SRT 10000VA RM 230V In Stock £7,502.13
C93X APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £677.83
C93X APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £595.90
C93X APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £717.17
C93X APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £891.35
C93X APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,261.34
C93X APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £163.11
C93X APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,306.71
C93X APC Rack PDU Basic 0U/1U 100-240V/ In Stock £84.13
C93X APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,488.58
C93X APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £472.34
C93X APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,128.26
C93X APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,932.30
C93X APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £2,254.08
C93X APC Smart-UPS 750VA RM 230V SmartConnect In Stock £525.39
Depth (mm): 120cm
Width (mm): 75cm
Brand: APC
Price Range Ex VAT: £1500+
