The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
Robust design
The APC NetShelter SX Enclosure with Roof and Sides is crafted to provide a sturdy and reliable housing solution for your computing equipment. Its robust design ensures your PC components are well-protected against physical impacts and environmental factors, offering peace of mind for the security and longevity of your technology investments. -
Seamless compatibility
Designed with PC compatibility in mind, this rack seamlessly integrates with your existing computing setup. It eliminates the hassle of mismatched components, ensuring a smooth and efficient organization of your PC hardware within a secure enclosure.
- APC NetShelter SX Enclosure with Roof and Sides - rack - 42U
- Product Type
- Rack
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 42U
- 75 cm x 120 cm x 199 cm
- 161 kg
- Wheels
- 5-year warranty
- Product Type
- Rack
- Rack Size
- 19"
- 42U
- 75 cm
- 120 cm
- 199 cm
- 161 kg
- Black
- Weight Limit
- 1364 kg
- Wheels
- EIA-310-D, IEC 60529 IP20, BAA
- TAA Compliant
- Limited warranty: - 5 years
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £210.09 |
APC 1U Vertical Cable Organiser | In Stock | £126.54 |
APC 1U Horizontal Cable Organiser | In Stock | £56.75 |
APC Smart-UPS SC 450VA 1U | In Stock | £286.62 |
APC Netshelter heavy duty shelf | In Stock | £143.54 |
APC - rack cable guide - 1U | In Stock | £52.84 |
APC Rackmount Rail Kit | In Stock | £91.99 |
APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £207.45 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £299.73 |
APC Smart-UPS 5000VA | In Stock | £3,736.99 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £326.66 |
APC Smart-UPS RT 20kVA RM 230V | In Stock | £12,584.24 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £289.61 |
APC Smart-UPS X 1500VA Rack/Tower LCD 230V | In Stock | £1,210.30 |
APC Cable Managers (Qty 10) | In Stock | £37.21 |
APC 2G Power distribution strip | In Stock | £649.00 |
APC Rack PDU 2G METERED ZEROU | In Stock | £703.99 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V | In Stock | £2,299.91 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 | In Stock | £511.43 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card | In Stock | £2,686.29 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,004.42 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £982.07 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £82.24 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,510.85 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £67.39 |
APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U | In Stock | £1,499.85 |
APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA | In Stock | £1,941.69 |
APC 1U Blanking Panel Kit | In Stock | £35.63 |
APC Smart-UPS 1500VA LCD RM 1U 230V | In Stock | £980.28 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £57.24 |
APC Smart-UPS SRT 6000VA RM 230V | In Stock | £4,885.92 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £49.22 |
APC Smart-UPS SRT 8000VA RM 230V | In Stock | £6,286.06 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,698.57 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £70.70 |
APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V | In Stock | £2,419.96 |
APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net | In Stock | £1,626.42 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £639.97 |
APC Smart-UPS SRT 2200VA RM 230V | In Stock | £1,772.89 |
APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid | In Stock | £2,841.57 |
APC Metered Rack PDU | In Stock | £866.74 |
APC Smart-UPS 1500VA RM 230V w/Network Card | In Stock | £1,217.80 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £777.52 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,100.38 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £62.38 |
APC Smart-UPS SRT 5000VA RM 208/230V HW | In Stock | £4,483.82 |
APC Smart-UPS SRT 10000VA RM 230V | In Stock | £7,665.72 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £675.56 |
APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) | In Stock | £593.74 |
APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) | In Stock | £708.52 |
APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) | In Stock | £906.61 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,263.60 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,336.79 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £83.95 |
APC Smart UPS 2200VA LCD RM 2U 230 | In Stock | £1,508.97 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £472.50 |
APC Smart-UPS SRT 3000VA RM Network Card | In Stock | £3,135.54 |
APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ | In Stock | £1,965.01 |
APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V | In Stock | £2,293.26 |
APC Smart-UPS 750VA RM 230V SmartConnect | In Stock | £521.19 |
