The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
Robust design
The APC NetShelter SX Enclosure with Roof and Sides is crafted to provide a sturdy and reliable housing solution for your computing equipment. Its robust design ensures your PC components are well-protected against physical impacts and environmental factors, offering peace of mind for the security and longevity of your technology investments. -
Seamless compatibility
Designed with PC compatibility in mind, this rack seamlessly integrates with your existing computing setup. It eliminates the hassle of mismatched components, ensuring a smooth and efficient organization of your PC hardware within a secure enclosure.
- APC NetShelter SX Enclosure with Roof and Sides - rack - 42U
- Product Type
- Rack
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 42U
- 75 cm x 120 cm x 199 cm
- 161 kg
- Wheels
- 5-year warranty
- Product Type
- Rack
- Rack Size
- 19"
- 42U
- 75 cm
- 120 cm
- 199 cm
- 161 kg
- Black
- Weight Limit
- 1364 kg
- Wheels
- EIA-310-D, IEC 60529 IP20, BAA
- TAA Compliant
- Limited warranty: - 5 years
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £204.64 |
APC 1U Vertical Cable Organiser | In Stock | £124.80 |
APC 1U Horizontal Cable Organiser | In Stock | £55.47 |
APC Smart-UPS SC 450VA 1U | In Stock | £279.98 |
APC Netshelter heavy duty shelf | In Stock | £141.95 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £302.47 |
APC Smart-UPS 5000VA | In Stock | £3,661.99 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £326.06 |
APC Smart-UPS RT 20kVA RM 230V | In Stock | £12,188.13 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £289.09 |
APC Smart-UPS X 1500VA Rack/Tower LCD 230V | In Stock | £1,186.69 |
APC Cable Managers (Qty 10) | In Stock | £36.38 |
APC 2G Power distribution strip | In Stock | £649.15 |
APC Rack PDU 2G METERED ZEROU | In Stock | £698.60 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V | In Stock | £2,317.04 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 | In Stock | £511.74 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card | In Stock | £2,667.34 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,000.76 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £959.96 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £80.88 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,472.17 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £99.01 |
APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U | In Stock | £1,457.00 |
APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA | In Stock | £1,908.54 |
APC 1U Blanking Panel Kit | In Stock | £34.80 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £55.94 |
APC Smart-UPS SRT 6000VA RM 230V | In Stock | £4,787.01 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.98 |
APC Smart-UPS SRT 8000VA RM 230V | In Stock | £6,184.96 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,714.30 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £69.11 |
APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V | In Stock | £2,389.72 |
APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net | In Stock | £1,639.84 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £638.53 |
APC Smart-UPS SRT 2200VA RM 230V | In Stock | £1,801.52 |
APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid | In Stock | £2,782.64 |
APC Metered Rack PDU | In Stock | £856.35 |
APC Smart-UPS 1500VA RM 230V w/Network Card | In Stock | £1,185.53 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £265.59 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,097.93 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £62.16 |
APC Rack PDU 2G Metered-by-Outlet ZeroU 32A 230V (21) C13+(3)$ | In Stock | £1,207.93 |
APC Smart-UPS SRT 10000VA RM 230V | In Stock | £7,502.13 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £677.83 |
APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) | In Stock | £595.90 |
APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) | In Stock | £717.17 |
APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) | In Stock | £891.35 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,261.34 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £163.11 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,306.71 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £84.13 |
APC Smart UPS 2200VA LCD RM 2U 230 | In Stock | £1,488.58 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £472.34 |
APC Smart-UPS SRT 3000VA RM Network Card | In Stock | £3,171.15 |
APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ | In Stock | £1,932.30 |
APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V | In Stock | £2,254.08 |
APC Smart-UPS 750VA RM 230V SmartConnect | In Stock | £525.39 |
