APC's Switched Rack Power Distribution Units (PDUs) are premium solutions to many of the power management problems seen in today's IT environments. Some of the problems are unauthorized use of power outlets, locked-up equipment, in-rush current, overloaded circuits, and the need of remote access to power outlets in the rack. The Switched Rack PDUs address these problems through individual outlet control, power on and off delays, current monitoring, alarm thresholds, and network management. Individual outlet control allows users to turn outlets on, turn outlets off, or recycle power to equipment, which can reboot locked-up equipment and avoid unauthorized use of outlets. Power delays allow users to determine the order in which equipment is powered up or down. Utilizing the power delay feature will avoid in-rush current, which can cause overloads. Monitoring the current draw at the rack level is key to avoiding downtime due to overloaded circuits. The Switched Rack PDUs provide an aggregate current draw, which can be viewed remotely or locally, via digital display. In addition, alarms will be generated based on user-defined thresholds to alert users of potential circuit overloads (on select models). Users can access, configure, and control the Switched Rack PDUs through Web, SNMP, or Telnet Interfaces.
Flash Upgradeable
Quickly and easily upgrade firmware via network download for future product enhancements. Eliminates the need to replace products already installed in the field when new features are released. (Note: Networked units only)
- APC Switched Rack PDU - power control unit
- Power control unit - rack-mountable
- Rack Size
- 19" - 2U
- 4.5 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Input Connectors
- 1 x power IEC 60309
- Output connectors
- 16 x power IEC 60320 C13
- Networking
- Ethernet 10/100
- Remote Management Protocol
- SNMP, Telnet, HTTP
- Black
- System Requirements
- Microsoft Windows NT 4.0, Microsoft Windows 98/2000/XP
- 44.5 cm x 11.4 cm x 8.9 cm
- 2-year warranty
- Designed For
- P/N: AR3100, AR3150
- Height (Rack Units)
- 2U
- Rack Size
- 19"
- Black
- Input Voltage
- AC 230 V
- Input Voltage Margin
- ± 10%
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Max Electric Current
- 32 A
- Remote Management Interface
- Ethernet 10/100
- 1 x management (Ethernet) - RJ-45 , 1 x management - RJ-11
- Cables Included
- Power cable - integrated - 3.05 m , Serial cable - external
- Rack Mounting Kit
- Included
- LCD display, LED display
- FCC Class A certified, UL, VCCI, C-Tick, cUL, ICES-003, IEC 61000-3-2, IEC 61000-3-3, VDE, EN55024, EN55022 Class A
- OS Required
- Limited warranty - 2 years
- 0 °C
- 45 °C
- Min Storage Temperature
- -25 °C
- Max Storage Temperature
- 65 °C
- 0 - 95%
- Humidity Range Storage
- 0 - 95%
- 44.5 cm
- 11.4 cm
- 8.9 cm
- 4.5 kg
- Designed For
