APC's Switched Rack Power Distribution Units (PDUs) are premium solutions to many of the power management problems seen in today's IT environments. Some of the problems are unauthorized use of power outlets, locked-up equipment, in-rush current, overloaded circuits, and the need of remote access to power outlets in the rack. The Switched Rack PDUs address these problems through individual outlet control, power on and off delays, current monitoring, alarm thresholds, and network management. Individual outlet control allows users to turn outlets on, turn outlets off, or recycle power to equipment, which can reboot locked-up equipment and avoid unauthorized use of outlets. Power delays allow users to determine the order in which equipment is powered up or down. Utilizing the power delay feature will avoid in-rush current, which can cause overloads. Monitoring the current draw at the rack level is key to avoiding downtime due to overloaded circuits. The Switched Rack PDUs provide an aggregate current draw, which can be viewed remotely or locally, via digital display. In addition, alarms will be generated based on user-defined thresholds to alert users of potential circuit overloads. Users can access, configure, and control the Switched Rack PDUs through Web, SNMP, or Telnet Interfaces.
                Remote Management CapabilitiesFull-featured network management interfaces that provide standards-based management via Web, SNMP, and Telnet. Allows users to access, configure, and manage units from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements
                Flash UpgradeableQuickly and easily upgrade firmware via network download for future product enhancements. Eliminates the need to replace products already installed in the field when new features are released. (Note: Networked units only)
- APC Switched Rack PDU Zero U - power distribution strip
- Power distribution strip - rack-mountable
- Cord Length
- 3.05 m
- 4.32 g
- Input Voltage
- AC 200/208/230 V
- Output Voltage
- AC 230 V
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 16 x power IEC 60320 C13
- Networking
- Ethernet 10/100
- Remote Management Protocol
- SNMP, Telnet, HTTP
- Black
- 5.6 cm x 4.4 cm x 124.5 cm
- 2-year warranty
- Designed For
- P/N: SCL400RMJ1U, SCL500RM1UC, SCL500RM1UNC, SCL500RMI1U, SCL500RMI1UC, SCL500RMI1UNC, SMT3000I-AR, SMT3000R2I-AR, SMTL1000RM2UC, SMTL750RM2UC, SMTL750RMI2UC, SMX1000C, SMX1500RM2UC, SMX2KR2UNCX145, SMX750CNC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLI, SRT1500XLI, SRT2200XLI-KR, SRT5KRMXLW-TW
- Cord Length
- 3.05 m
- Black
- Input Voltage
- AC 200/208/230 V
- Input Voltage Range
- AC 200 - 240 V
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Max Electric Current
- 10 A
- Remote Management Interface
- Ethernet 10/100
- 1 x management (Ethernet) - RJ-45 , 1 x serial - RJ-11
- Cables Included
- Power cable 3.05 m
- Rack Mounting Kit
- Included
- LED display, current meter
- GOST, EN 61000-3-2, VDE, EN 61000-3-3, EN55024, IRAM, RoHS, REACH, EN 55022 Class A
- Limited warranty - parts and labour - 2 years
- -5 °C
- 45 °C
- 0 - 95%
- 5.6 cm
- 4.4 cm
- 124.5 cm
- 4.32 g
- Shipping Width
- 15.2 cm
- Shipping Depth
- 12.7 cm
- Shipping Height
- 213.4 cm
- Shipping Weight
- 5.23 kg
- Designed For
- P/N: AR3355W, AR3357X674, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4038IX432, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBPD0160A, NBWL0355A, NBWL0356A, SCL400RMJ1U, SCL500RM1UC, SCL500RM1UNC, SCL500RMI1U, SCL500RMI1UC, SCL500RMI1UNC, SMC1000-2UC, SMC1000-2UTW, SMC1000-BR, SMC1000I-2UC, SMC1000I-BR, SMC1000IC, SMC15002U-BR, SMC1500-2UC, SMC1500-2UTW, SMC1500-BR, SMC1500I2U-BR, SMC1500I-2UC, SMC1500I-BR, SMC1500IC, SMC2000I2U-BR, SMT1000I-AR, SMT1000IC, SMT1000R2I-AR, SMT1000RM2UC, SMT1000RMI2UC, SMT1500I-AR, SMT1500IC, SMT1500R2I-AR, SMT1500RM2UC, SMT1500RM2UNC, SMT1500RMI2UC, SMT1500RMI2UNC, SMT2200I2U-BR, SMT2200I-AR, SMT2200IC, SMT2200R2I-AR, SMT2200RM2UC, SMT2200RM2UNC, SMT2200RMI2UC, SMT2200RMI2UNC, SMT30002U-BR, SMT3000I2U-BR, SMT3000I-AR, SMT3000IC, SMT3000R2I-AR, SMT3000RM2UC, SMT3000RM2UNC, SMT3000RMI2UC, SMT3000RMI2UNC, SMT750RM2UC, SMT750RM2UNC, SMT750RMI2UC, SMT750RMI2UNC, SMTL1000RM2UC, SMTL750RM2UC, SMTL750RMI2UC, SMX1000C, SMX1000US, SMX1500RM2UC, SMX1500RMNCUS, SMX1500RMUS, SMX2000LVNCUS, SMX2000LVUS, SMX2200HVNC, SMX2200R2HVNC, SMX2200RMLVUS, SMX2KR2UNCX145, SMX2KRMLVNCUS, SMX3000HV-BR, SMX3000HVTUS, SMX3000LV2U-BR, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750CNC, SMX750INC, SMX750NC, SMX750US, SRC2000XLI-CC, SRC3KUXI, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT10KRMXLT-10KTF, SRT10KRMXLT30, SRT10KRMXLT-5KTF2, SRT10RMXLIX806, SRT1500RMXLA, SRT1500RMXLA-NC, SRT1500RMXLI, SRT1500XLI, SRT2200RMXLA, SRT2200RMXLA-NC, SRT2200RMXLAUS, SRT2200RMXLI, SRT2200RMXLI-NC, SRT2200XLI, SRT2200XLI-KR, SRT3000RMXLA, SRT3000RMXLA-NC, SRT3000RMXLI, SRT3000RMXLI-NC, SRT3000RMXLT, SRT3000RMXLT-5KTF, SRT3000RMXLT-NC, SRT3000RMXLW-IEC, SRT3000XLI, SRT3000XLW-IEC, SRT5KRMXLIM, SRT5KRMXLTUS, SRT5KRMXLW-TW, SRT6KRMXLIM, SRT6KRMXLT-5KTF, SRT8KRMXLT30, SRT8KRMXLT-5KTF, SUA1000ICH-45, SUA1500I-IN, SUA2200ICH-45, SUA3000I-IN, SURT1000RMXLI-NC, SURT1000XLI-NC, SYAF16KRMICH
|  | APC 1U Vertical Cable Organiser | In Stock | £122.27 |
|  | APC 1U Horizontal Cable Organiser | In Stock | £54.65 |
|  | APC Netshelter heavy duty shelf | In Stock | £142.22 |
|  | APC Rackmount Rail Kit | In Stock | £91.78 |
|  | APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £205.75 |
|  | APC Equipment Support Rails for 600mm Wide Enclosure | In Stock | £72.89 |
|  | APC AP9520TH TEMP & HUMIDITY | In Stock | £258.75 |
|  | APC Cable Managers (Qty 10) | In Stock | £35.20 |
|  | APC 19" Rack LCD Console | In Stock | £1,378.61 |
|  | APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £80.63 |
|  | APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £66.83 |
|  | APC 1U Blanking Panel Kit | In Stock | £34.57 |
|  | APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.74 |
|  | APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.09 |
|  | APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,687.54 |
|  | APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £70.76 |
|  | APC Metered Rack PDU | In Stock | £842.67 |
|  | APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £743.40 |
|  | APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £263.36 |
|  | APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,089.67 |
|  | APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,252.19 |
|  | APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £160.99 |
|  | APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,282.18 |
|  | APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £81.63 |
|  | APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £467.92 |
