APC SURT Equipment Cart
Quicklinx: 8DJBWS00 Mfr#: SURT013
£245.98 ex VAT
£295.17 inc VAT
APC Smart-UPS RT is a family of high-density, performance UPSs for voice and data networks, medical labs, and light industrial applications. Capable of supporting 10KVA in a 6U rack/tower convertible form, users can support power hungry blade servers or heavily loaded equipment racks. This flexible form factor allows standardization across multiple applications. High power internal chargers allow virtually unlimited additional matching battery packs to comply with aggressive runtime demands of business-critical systems. Customers with harsh power environments looking for extremely tight voltage and frequency regulation, internal bypass, and input power factor correction typical of double conversion online topology will get them in the Smart-UPS RT.
  • Adjustable leveling feet
    Leveling feet can be quickly adjusted through the use of a screwdriver or drill, eliminating the need to reach underneath with a wrench.
  • Heavy load bearing casters
    Casters are rated at 650 lbs each, total 2600 lbs.
APC - UPS cart
UPS cart
43.2 cm x 63.5 cm x 8.9 cm
15 kg
Wheels
P/N: SURT10000UXICH, SURT10000XLICH, SURT10000XLTW, SURT10KRMXL6U-TF5, SURT14KRMXLJ, SURT15KRMXLT, SURT15KRMXLT-1TF10K, SURT15KRMXLT-TF5, SURT15KUXICH, SURT18KRMXLJ, SURT20KRMXLT, SURT20KRMXLT-1TF10K, SURT20KRMXLT-TF5, SURT20KUXICH, SURT20KUXI-IN, SURT8000UXICH, SURT8000XLICH, SURT8KRMXL6U-TF5
UPS cart
43.2 cm
63.5 cm
8.9 cm
15 kg
Wheels
P/N: SURT10000RMXLI, SURT10000RMXLT, SURT10000RMXLT-2TF5, SURT10000RMXLT6U, SURT10000UXI, SURT10000UXICH, SURT10000XLI, SURT10000XLI-CC, SURT10000XLICH, SURT10000XLJ, SURT10000XLT, SURT10000XLT-1TF10K, SURT10000XLT-2TF3, SURT10000XLTW, SURT10KRMXL6U-TF5, SURT14KRMXLJ, SURT15KRMXLI, SURT15KRMXLT, SURT15KRMXLT-1TF10K, SURT15KRMXLT-TF5, SURT15KUXICH, SURT18KRMXLJ, SURT20KRMXLI, SURT20KRMXLT, SURT20KRMXLT-1TF10K, SURT20KRMXLT-TF5, SURT20KUXICH, SURT20KUXI-IN, SURT8000RMXLI, SURT8000RMXLT-1TF5, SURT8000RMXLT6U, SURT8000UXI, SURT8000UXICH, SURT8000XLI, SURT8000XLICH, SURT8000XLJ, SURT8000XLT, SURT8000XLT-1TF3, SURT8000XLTW, SURT8KRMXL6U-TF5
Brand: APC
