APC SurgeArrest Essential - Surge suppressor - 5 Output Connector
Quicklinx: 4N4LWS00 Mfr#: P5B-UK
Lightning and power surges can permanently ruin your electronic equipment. Changes in voltage cause lockups and loss of work. This unit will protect your equipment from the threat of bad power. The Essential SurgeArrest series offers a great value for home equipment and business applications such as small office/home computers.
  • Transformer Block Spacing
    Connect bulky transformer block plugs without covering up other outlets
  • Manual disconnect switch
    Enables the surge supressor to be de-energized for service without disconnecting the protected load
  • Right Angle Plug
    Plug angle allows for equipment and furniture to be placed closer to the wall than with a standard power cord. Reduces cord stress too
  • 180 degree Rotating Cord Retainer
    A 180-degree rotating cord with strain relief offers flexibility in positioning the SurgeArrest, and in routing the power cord
APC SurgeArrest Essential - surge protector
Surge protector - external
0.7 kg
United Kingdom
Input Voltage
AC 230 V
Input Connectors
1 x power BS 1363
Output connectors
5 x power BS 1363
Charcoal
7 cm x 4.5 cm x 38.5 cm
Charcoal
United Kingdom
Input Voltage
AC 230 V
Frequency Required
50/60 Hz
Input Connectors
1 x power BS 1363
5 x power BS 1363
Max Electric Current
13 A
Surge Suppression
Surge Energy Rating
960 Joules
EMI/RFI Noise Filtration
30 dB
Circuit Protection
Circuit breaker
Power cable - integrated - 1.8 m
UL 1449
Limited warranty - lifetime
0 - 95%
7 cm
4.5 cm
38.5 cm
0.7 kg
Resources
The following resources are available for the APC SurgeArrest Essential - Surge suppressor - 5 Output Connector
