Protects an Ethernet data port from damaging transients. Supports Cat5, Cat5E and Cat6 cabling standards. Compatible with Power Over Ethernet (POE) and network speeds up to 10GbE (10GigE).
Data-line Protection
Protection of data lines (Ethernet, Coaxial and Phone lines) ensures complete protection of your equipment from surges. It is very important to protect your equipment from “back door” electric surges traveling through data lines, as they can be as damaging to your equipment as surges traveling over power lines -
Replaceable surge protection modules
Allows you to use any combination of APC rack-mount surge protection modules and replace them quickly and conveniently if needed
- APC ProtectNet Surge Module for CAT6 or CAT5/5e Network Line - surge protector
- Surge protector - plug-in module
- 20 g
- Black
- 1.9 cm x 6.9 cm x 4.4 cm
- Limited lifetime warranty
- Black
- Surge Suppression
- 1 x Gigabit LAN - RJ-45
- UL, UL 497B, RoHS
- Limited warranty - lifetime
- -15 °C
- 45 °C
- 0 - 95%
- 1.9 cm
- 6.9 cm
- 4.4 cm
- 20 g
- Shipping Width
- 3.3 cm
- Shipping Depth
- 9.5 cm
- Shipping Height
- 9.9 cm
- Shipping Weight
- 40 g
