APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V
Quicklinx: BBXFWS00 Mfr#: SMX3000HVNC
Type: UPS
Power Rating: 2700Watt
12 In Stock
£2,371.97 ex VAT
£2,846.36 inc VAT
Intuitive LCD interface provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
High frequency design reduces or eliminates bulky transformers resulting in lighter units for ease of handling.
APC Smart-UPS X 3000 Rack/Tower LCD recognizes when external battery packs are attached and automatically adjusts runtime.
Patent-pending operating mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Multiple switched outlet groups
    Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
APC Smart-UPS X 3000 Rack/Tower LCD - UPS - 2700 Watt - 3000 VA - with APC UPS Network Management Card AP9631
UPS - rack-mountable / external
Rack Size
4U
38.64 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
2700 Watt / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Batteries Qty
1
Run Time (Up To)
6.3 min at full load
Ethernet 10/100, RS-232, USB
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2
43.2 cm x 48.3 cm x 17.8 cm
3-year warranty
Bundled with
P/N: AR3105W, AR3140G, AR3155W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A, SMX3000HVTUS, SRT1000RMXLA, SRT1500RMXLA-NC, SYAF8KRMTX424
Height (Rack Units)
4U
Bundled with
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 140 - 280 V
Frequency Provided
47 - 63 Hz
Frequency Required
47 - 63 Hz
Input Connectors
Output Voltage
AC 230 V 47 - 63 Hz
Power Capacity
2700 Watt / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
645 Joules
Circuit Protection
Circuit breaker
Efficiency
98.5%
Quantity
1
Lead Acid
Run Time (Up To)
6.3 min at full load , 15.7 min at half load
Recharge Time
3 hours
Remote Management Interface
1 x USB , 1 x RS-232 , 1 x EPO (emergency power off) , 1 x management (Ethernet) - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Serial cable , USB cable , Power cable 1.83 m
Rack Mounting Kit
Included
Audible alarm, LCD display, overload protection
CSA, C-Tick, GOST, UL 1449, UL 1778, VDE, IEC 60950, EN 50091-2, IRAM, RoHS, EN 50091-1, FCC Part 15 A, REACH
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
55 dBA
43.2 cm
48.3 cm
17.8 cm
38.64 kg
Shipping Width
58.6 cm
Shipping Depth
63.3 cm
Shipping Height
33 cm
Shipping Weight
47.73 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, ACF001, ACF002, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR4000MV, AR4000MVX429, AR4000MVX432, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A, SMX3000HVTUS, SRT1000RMXLA, SRT1500RMXLA-NC, SU2000R3X155, SYAF8KRMTX424
BBXF APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £28.73
BBXF APC Basic Rack-Mount PDU - power distribution strip In Stock £200.74
BBXF APC 1U Vertical Cable Organiser In Stock £121.86
BBXF APC 1U Horizontal Cable Organiser In Stock £54.38
BBXF APC Rackmount Rail Kit In Stock £91.70
BBXF APC Power cable - 2.4 m In Stock £84.14
BBXF APC Rack PDU Basic Zero U 16A 208/230V In Stock £292.54
BBXF APC 3Yr Extended Warranty SP In Stock £295.50
BBXF APC Rack PDU Basic Zero U 32A 230V In Stock £314.25
BBXF C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
BBXF APC Temperature and Humidity Sensor In Stock £150.00
BBXF APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £281.45
BBXF APC Rack PDU Basic ZeroU 16A 230V (20)C13 & (4)C19; In Stock £312.88
BBXF APC Cable Managers (Qty 10) In Stock £35.36
BBXF APC 2G Power distribution strip In Stock £627.52
BBXF APC 2U Horizontal Cable Organizer In Stock £57.69
BBXF APC APC POWERCORD C19 TO C20 1.8M In Stock £181.73
BBXF APC Rack PDU 2G METERED ZEROU In Stock £683.94
BBXF APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £962.45
BBXF APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £924.71
BBXF APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £84.14
BBXF APC 17" Rack LCD Console w/ Integrated 8-Port Analog KVM Switch In Stock £1,926.60
BBXF APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £51.94
BBXF APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,442.54
BBXF APC NetShelter Zero U Accessory Mounting Bracket In Stock £65.06
BBXF APC Smart-UPS X 120V External Battery Pack Rack/Tower In Stock £661.51
BBXF APC Blanking Panel Kit In Stock £107.35
BBXF APC 1U Blanking Panel Kit In Stock £33.63
BBXF APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £47.14
BBXF APC Power Cable (pack of 6) 1.22m In Stock £86.19
BBXF APC Basic Rack PDU Zero U - Power Distribution Panel In Stock £351.61
BBXF APC Dry Contact I/O SmartSlot Card In Stock £175.45
BBXF APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,661.01
BBXF APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £127.88
BBXF APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £618.51
BBXF APC Replacement Battery Cartridge #143 In Stock £413.43
BBXF APC Metered Rack PDU In Stock £828.20
BBXF APC Switched Rack PDU AC 208-230 V Ethernet In Stock £730.21
BBXF APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £259.61
BBXF APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,073.90
BBXF APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £645.61
BBXF APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,217.34
BBXF APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £156.86
BBXF APC Rack PDU Basic 0U/1U 100-240V/ In Stock £79.55
Type: UPS
Brand: APC
Price Range Ex VAT: £1500+
