In the E-world where businesses can't stop and downtime is measured in dollars, American Power Conversion (APC) provides protection against some of the leading causes of downtime, data loss and hardware damage: power problems and temperature. As a global leader in power availability solutions, APC sets the standard in its industry for quality, innovation and support. Its comprehensive power solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes.
Long battery life
APC Replacement Battery Cartridge #14 is designed by APC by Schneider Electric exclusively for APC UPSs for complete compatibility with the intelligent battery management system. -
Fully assembled for easy hot-swap installation
APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
- APC Replacement Battery Cartridge #14 - UPS battery - Lead Acid
- UPS battery
- 108.7 kg
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Black
- 16.5 cm x 25.9 cm x 20.8 cm
- 1-year warranty
- Designed For
- P/N: MX3000XR, MX3000XRW, MX5000XR, MX5000XRW, SMARTCELL-XR, UXBP48M
- UPS battery
- Battery Enclosure Type
- Plug-in module
- Black
- Technology
- Lead Acid
- Limited warranty - 1 year
- 16.5 cm
- 25.9 cm
- 20.8 cm
- 108.7 kg
- Designed For
