APC Smart-UPS XL Modular 3000VA 230V Rackmount / Tower
Quicklinx: 3LSXWS00 Mfr#: SUM3000RMXLI2U
Type: UPS
Power Rating: 2.85kW
£2,867.88 ex VAT
£3,441.45 inc VAT
APC Smart-UPS XL protects your data by supplying reliable, network-grade power with scalable run-time in tower and rack mount form factors. With optional, matching battery packs, run-time can be easily extended and optimized for the application. APC understands long run-time requirements so; Smart-UPS XL's can be configured with up to 10 additional battery packs - for run-times exceeding 24 hours, if necessary. The convergence of voice and data networks is placing higher demands on availability expectations - and the Smart-UPS XL delivers. Voice over Internet Protocol (VoIP), e-commerce, WiFi ("hotspots", WLAN/ WWAN, and mixed wireless), and data enabled PBX's are a few of the applications driving the need for Smart-UPS XL. APC Smart-UPS XL is also the perfect UPS for fileservers (Intel or UNIX based), minicomputers, Network switches and hubs, ATM's, telecommunications systems and other mission-critical applications requiring longer runtime.
With included PowerChute management software for servers and workstations, IT administrators can provide safe system shutdown and advanced UPS management (All major operating systems supported). Connectivity is through a serial or USB port. Additional manageability is available through the SmartSlot, an internal accessory slot that allows you to install optional accessories to enhance the performance of your UPS. Network connection with Web browser management and/or environmental monitoring, serial port expansion, and out-of-band management options are available. With pure sine-wave output ensuring compatibility with all connected devices, Intelligent Battery Management ensuring a highly available UPS and an advanced 16 segment bar graph display ensuring information and management, the Smart-UPS XL is a UPS you can count on.
  • Automatic internal bypass
    Supplies utility power to the connected loads in the event of a UPS power overload or fault
  • Modular design
    Increases adaptability with an open architecture configurable to any IT environment
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models)
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment
APC Smart-UPS XL Modular 3000VA - UPS - 2.85 kW - 3000 VA
UPS - external
Rack Size
2U
47 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
2.85 kW / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
7 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Battery Form Factor
Plug-in module
Run Time (Up To)
3.5 min at full load
43 cm x 68 cm x 9 cm
P/N: AR3003, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3140G, AR3155W, AR3305W, AR3340G, AR3355W, AR3357X674, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 285 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
50/60 Hz
Input Voltage Margin
± 5%
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
2.85 kW / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
490 Joules
Run Time (Up To)
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB , 1 x LAN - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Serial cable , USB cable , Power cable 3 m
Rack Mounting Kit
Included
Audible alarm
C-Tick, GOST, EN 61000-3-2, UL 1449, EN55022 Class A
Software Included
Drivers & Utilities
Limited warranty - parts and labour - 2 years
0 - 95%
43 cm
68 cm
9 cm
47 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3003, AR3003SP, AR3006, AR3006SP, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103, AR3103SP, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
3LSX APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £28.90
3LSX APC - Power cable - Male-Female - 1.98 m In Stock £47.79
3LSX APC Basic Rack-Mount PDU - power distribution strip In Stock £197.72
3LSX APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £50.88
3LSX APC Pwr Cord, 16A, 200-240V, C19 to UK Plug In Stock £56.28
3LSX APC Replacement Battery Cartridge #43 - UPS battery - Lead Acid In Stock £416.09
3LSX APC Power cable - 2.4 m In Stock £82.25
3LSX APC Rack PDU Basic Zero U 16A 208/230V In Stock £286.90
3LSX APC 2-Post Mounting Kit for Smart-UPS In Stock £169.50
3LSX APC 3Yr Extended Warranty SP In Stock £288.00
3LSX APC Temperature and Humidity Sensor In Stock £133.79
3LSX APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £271.25
3LSX APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £953.12
3LSX APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £82.34
3LSX APC Power Cord Locking C19 to C20 3.0m In Stock £66.28
3LSX APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £51.95
3LSX APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £56.28
3LSX APC Power Cable (pack of 6) 1.22m In Stock £84.43
3LSX APC Dry Contact I/O SmartSlot Card In Stock £165.13
3LSX APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £126.10
3LSX APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £100.67
3LSX APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £614.64
3LSX APC Extended Warranty Service Pack Technical Support 1 Year In Stock £120.61
3LSX APC Switched Rack PDU AC 208-230 V Ethernet In Stock £731.73
3LSX APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.34
3LSX APC Switched PDU 10A 0U C13x16 In Stock £1,129.15
3LSX APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.72
3LSX APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,217.48
3LSX APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £155.82
3LSX APC Rack PDU Basic 0U/1U 100-240V/ In Stock £80.21
Resources
The following resources are available for the APC Smart-UPS XL Modular 3000VA 230V Rackmount / Tower
Type: UPS
Brand: APC
Price Range Ex VAT: £1500+
