APC Smart-UPS XL Modular 1500VA 230V Rackmount / Tower
Quicklinx: 3P7VWS00 Mfr#: SUM1500RMXLI2U
Type: UPS
Power Rating: 1.425kW
£1,628.16 ex VAT
£1,953.79 inc VAT
APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
  • Automatic internal bypass
    Supplies utility power to the connected loads in the event of a UPS power overload or fault
  • Modular design
    Increases adaptability with an open architecture configurable to any IT environment
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models)
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment
  • Global safety approvals
    UL60950, CSA60950, IEC60950, EN60950 safety approvals. Meets IEC 61000-4-5 Immunity To Surge, and GR-1089-CORE, Section 4, Lightning and AC Power Faults standards
APC Smart-UPS XL Modular 1500VA - UPS - 1.425 kW - 1500 VA
UPS - external
Rack Size
2U
47 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
1.425 kW / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
9 x power IEC 60320 C13
Batteries Qty
1
Run Time (Up To)
11.9 min at full load
Remote Management Protocol
SNMP, HTTP
43 cm x 68 cm x 9 cm
P/N: AR2487G, AR3100W, AR3103SP, AR3105SP, AR3105W, AR3106SP, AR3140G, AR3140W, AR3150W, AR3155W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
UPS - external
Height (Rack Units)
2U
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 285 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
Power Capacity
1.425 kW / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
490 Joules
Quantity
1
Run Time (Up To)
SNMP, HTTP
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x USB - Ethernet 10Base-T/100Base-TX , 1 x LAN - RJ-45
Rack Mounting Kit
Included
Audible alarm
C-Tick, GOST, EN 61000-3-2, EN55022 Class A, EN 50091-2
Limited warranty - parts and labour - 2 years
0 - 95%
43 cm
68 cm
9 cm
47 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103SP, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
3P7V APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £29.10
3P7V APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £51.01
3P7V APC Replacement Battery Cartridge #43 - UPS battery - Lead Acid In Stock £419.08
3P7V APC 2-Post Mounting Kit for Smart-UPS In Stock £170.71
3P7V APC 3Yr Extended Warranty SP In Stock £290.06
3P7V APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £56.44
3P7V APC Power Cable (pack of 6) 1.22m In Stock £84.69
3P7V APC Dry Contact I/O SmartSlot Card In Stock £169.64
3P7V APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £127.00
3P7V APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £101.53
3P7V APC Extended Warranty Service Pack Technical Support 1 Year In Stock £121.49
3P7V APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.76
3P7V APC Switched PDU 10A 0U C13x16 In Stock £1,137.24
3P7V APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.72
Resources
The following resources are available for the APC Smart-UPS XL Modular 1500VA 230V Rackmount / Tower
Type: UPS
Brand: APC
Price Range Ex VAT: £1500+
