APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
Automatic internal bypass
Supplies utility power to the connected loads in the event of a UPS power overload or fault -
Modular design
Increases adaptability with an open architecture configurable to any IT environment -
USB connectivity
Provides management of the UPS via a USB port (not available on all models) -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment -
Global safety approvals
UL60950, CSA60950, IEC60950, EN60950 safety approvals. Meets IEC 61000-4-5 Immunity To Surge, and GR-1089-CORE, Section 4, Lightning and AC Power Faults standards
- APC Smart-UPS XL Modular 1500VA - UPS - 1.425 kW - 1500 VA
- UPS - external
- Rack Size
- 2U
- 47 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 220/230/240 V ± 5%
- Power Capacity
- 1.425 kW / 1500 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 9 x power IEC 60320 C13
- Batteries Qty
- 1
- Run Time (Up To)
- 11.9 min at full load
- Remote Management Protocol
- SNMP, HTTP
- Black
- 43 cm x 68 cm x 9 cm
- 2-year warranty
- Designed For
- P/N: AR2487G, AR3100W, AR3103SP, AR3105SP, AR3105W, AR3106SP, AR3140G, AR3140W, AR3150W, AR3155W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
- UPS - external
- Height (Rack Units)
- 2U
- Black
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 285 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 490 Joules
- Quantity
- 1
- Run Time (Up To)
- SNMP, HTTP
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x USB - Ethernet 10Base-T/100Base-TX , 1 x LAN - RJ-45
- Rack Mounting Kit
- Included
- Audible alarm
- C-Tick, GOST, EN 61000-3-2, EN55022 Class A, EN 50091-2
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 43 cm
- 68 cm
- 9 cm
- 47 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103SP, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £30.76 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £54.29 |
APC Replacement Battery Cartridge #43 - UPS battery - Lead Acid | In Stock | £434.61 |
APC 2-Post Mounting Kit for Smart-UPS | In Stock | £178.50 |
APC 3Yr Extended Warranty SP | In Stock | £322.69 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £59.73 |
APC Power Cable (pack of 6) 1.22m | In Stock | £90.09 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £131.99 |
APC Extended Warranty Service Pack Technical Support 1 Year | In Stock | £138.73 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £63.36 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £685.66 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £463.90 |
