APC Smart-UPS X 750VA Rack/Tower LCD 230V
Quicklinx: 7LLDWS00 Mfr#: SMX750I
Type: UPS
Power Rating: 600Watt
48 In Stock
£581.26 ex VAT
£697.51 inc VAT
Attach the device to an emergency power off (EPO) system so that power can be turned off in an emergency situation. Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. High frequency design reduces or eliminates bulky transformers resulting in lighter units for ease of handling. Energy meter provides actual kilowatt hours of usage for energy conscious users. Intuitive LCD interface provides clear and accurate information with the ability to configure the UPS locally with easy to use navigation keys. UPS recognizes when external battery packs are attached and automatically adjusts runtime. Multiple outlet groups may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on / off and non-critical load shedding.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Scalable runtime
    Allows additional run time to be quickly added as needed
  • Plug-and-Play external batteries
    Ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS
  • Auto recognition of external batteries
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment
  • Multiple switched outlet groups
    Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • High frequency design
    Reduces or eliminates bulky transformers resulting in lighter units for ease of handling
  • EPO
    Attach the device to an Emergency Power Off (EPO) system so that power can be turned off in an emergency situation
APC Smart-UPS X 750 Rack/Tower LCD - UPS - 600 Watt - 750 VA
UPS - rack-mountable
Rack Size
2U
22.1 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
600 Watt / 750 VA
Input Connectors
Power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
14.2 min at full load
8.9 cm x 49 cm x 43.2 cm
3-year warranty
Height (Rack Units)
2U
UPS Technology
Line interactive
Power Modules Qty
1
Input Voltage
AC 230 V
Frequency Provided
47 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 230 V ± 5% - 47 - 63 Hz
Power Capacity
600 Watt / 750 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
645 Joules
Lead Acid
Run Time (Up To)
14.2 min at full load , 37.8 min at half load
Recharge Time
3 hours
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , Power cable - integrated - 1.8 m
Audible alarm, LCD display
C-Tick, UL 1449, VDE, EN 50091-2, RoHS Exemption 7b, EN 50091-1
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
40 dBA
8.9 cm
49 cm
43.2 cm
22.1 kg
Shipping Width
24.6 cm
Shipping Depth
62 cm
Shipping Height
58.9 cm
Shipping Weight
26.5 kg
7LLD APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.95
7LLD APC Basic Rack-Mount PDU - power distribution strip In Stock £204.36
7LLD APC 1U Horizontal Cable Organiser In Stock £56.61
7LLD APC Netshelter heavy duty shelf In Stock £144.25
7LLD APC Rackmount Rail Kit In Stock £91.78
7LLD APC Rack PDU, Basic, Zero U, 10A,2 In Stock £280.19
7LLD APC Rack PDU Basic Zero U 16A 208/230V In Stock £303.36
7LLD APC Rack PDU Basic Zero U 32A 230V In Stock £329.44
7LLD APC Temperature and Humidity Sensor In Stock £133.03
7LLD APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £300.02
7LLD APC Smart-UPS X-Series 48V Ext. Batt Pack Rack/Tower In Stock £670.52
7LLD APC Cable Managers (Qty 10) In Stock £37.12
7LLD APC 2G Power distribution strip In Stock £648.80
7LLD APC Rack PDU 2G METERED ZEROU In Stock £706.28
7LLD APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,021.49
7LLD APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £979.84
7LLD APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,507.44
7LLD APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £59.45
7LLD APC 1U Blanking Panel Kit In Stock £35.50
7LLD APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.75
7LLD APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £49.71
7LLD APC Power Cable (pack of 6) 1.22m In Stock £90.64
7LLD APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,754.51
7LLD APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.53
7LLD APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £133.14
7LLD APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £105.31
7LLD APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £643.09
7LLD APC Replacement Battery In Stock £243.65
7LLD APC Metered Rack PDU In Stock £880.85
7LLD APC Switched Rack PDU AC 208-230 V Ethernet In Stock £762.02
7LLD APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,118.18
7LLD APC 1 Year Extended Warranty 2015-4037 In Stock £63.46
7LLD APC Service Pack 3 Year Warranty Extension In Stock £118.80
7LLD APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.64
7LLD APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £686.60
7LLD APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,286.82
7LLD APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £164.54
7LLD APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,333.77
7LLD APC Rack PDU Basic 0U/1U 100-240V/ In Stock £85.11
7LLD APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.49
Type: UPS
Brand: APC
Price Range Ex VAT: £500 - £750
