APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V
Quicklinx: 7QK8WS00 Mfr#: smx3000rmhv2u
Type: UPS
Power Rating: 2.7kW
10 In Stock
£2,353.94 ex VAT
£2,824.72 inc VAT
APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and network power protection. Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption. Smart-UPS feature a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery. The entry level Smart-UPS SC is an economical choice for small and medium businesses looking to protect small switches, networking devices and point-of-sale (POS) equipment.
  • Intuitive LCD interface
    It provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • High frequency design
    It reduces or eliminates bulky transformers resulting in lighter units for ease of handling.
  • Auto recognition of external batteries
    UPS recognizes when external battery packs are attached and automatically adjusts runtime.
  • Predictive replace battery date
    It dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Green mode
    Patent-pending operating mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Energy meter
    It provides actual kilowatt hours of usage for energy conscious users.
  • Audible alarms
    Audible alarms provide notification of changing flywheel conditions
  • Pure sine wave output on battery
    It simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Multiple switched outlet groups
    Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • Wide input voltage range
    Wide input voltage range is designed for harsh electrical environments to save battery life.
  • Battery failure notification
    It provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • High online efficiency
    It reduces utility costs, generates less heat.
  • LED indicators
    LED indicators provide easy-to-read status of your utility power conditions, UPS and battery.
  • Overload protection
    It safeguards unit from damage by automatically turning it off in the event of a short circuit or overload.
  • Cold-start capable
    It provides temporary battery power when the utility power is out.
  • Hot-swappable batteries
    It ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Automatic restart of loads after UPS shutdown
    It automatically starts up the connected equipment upon the return of utility power.
  • Adjustable voltage-transfer points
    It maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation.
  • Adjustable voltage sensitivity
    It provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications.
  • User-replaceable batteries
    It increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR).
  • Serial connectivity
    It provides management of the UPS via a serial port.
  • Temperature-compensated battery charging
    It prolongs battery life by regulating the charge voltage according to battery temperature.
  • Boost and trim Automatic Voltage Regulation (AVR)
    It gives higher application availability by correcting low and high voltage conditions without using the battery.
  • Scalable runtime
    It allows additional run time to be quickly added as needed.
  • Intelligent battery management
    It maximizes battery performance, life, and reliability through intelligent, precision charging.
  • Safety-agency approved
    It ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
  • Rack/tower convertible
    It protects the initial investment in the UPS when migrating from tower to rack-mount environment.
  • Power conditioning
    It protects connected loads from surges, spikes, lightning, and other power disturbances.
  • Network manageable
    It provides remote management of the UPS over the network.
  • Frequency and voltage regulation
    It gives higher application availability by correcting poor frequency and voltage conditions without using the battery.
  • Predictive failure notification
    It provides early-warning fault analysis ensuring proactive component replacement.
APC Smart-UPS X 3000 Rack/Tower LCD - UPS - 2.7 kW - 3000 VA
UPS - external
Rack Size
2U
37.3 kg
Input Voltage
AC 208/220/230/240 V
Output Voltage
AC 230 V ± 5%
Power Capacity
2.7 kW / 3000 VA
Input Connectors
Power IEC 60320 C20, power CEE 7/7, power BS 1363A
Output connectors
8 x power IEC 60320 C13 , 2 x IEC jumper , 1 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
6.3 min at full load
RS-232, USB
43.2 cm x 66.7 cm x 8.5 cm
3-year warranty
P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A, SRT1000RMXLA
UPS - external
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
Input Voltage Range
AC 141 - 255 / 160 - 280 V
Frequency Provided
47 - 63 Hz
Frequency Required
47 - 63 Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 47 - 63 Hz
Power Capacity
2.7 kW / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
645 Joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
6.3 min at full load , 18 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable , USB cable , Power cable 1.8 m
Rack Mounting Kit
Included
Audible alarm, emergency power off, LCD display, LED indicators
CSA, C-Tick, GOST, EN 60950, UL 1449, UL 1778, VDE, EN 50091-2, RoHS Exemption 7b, IRAM, EN 50091-1, FCC Part 15 A, REACH
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
55 dBA
43.2 cm
66.7 cm
8.5 cm
37.3 kg
Shipping Width
59.6 cm
Shipping Depth
86.9 cm
Shipping Height
24.3 cm
Shipping Weight
45.4 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A, SMX2000LVNC, SRT1000RMXLA
7QK8 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.44
7QK8 APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £48.99
7QK8 APC - Power cable - Male-Female - 1.98 m In Stock £50.90
7QK8 APC Basic Rack-Mount PDU - power distribution strip In Stock £202.03
7QK8 APC 1U Vertical Cable Organiser In Stock £122.75
7QK8 APC 1U Horizontal Cable Organiser In Stock £54.86
7QK8 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.74
7QK8 APC Netshelter heavy duty shelf In Stock £142.89
7QK8 APC - rack cable guide - 1U In Stock £51.09
7QK8 APC Power cable - 2.4 m In Stock £84.15
7QK8 APC Rack PDU Basic Zero U 16A 208/230V In Stock £299.80
7QK8 APC 3Yr Extended Warranty SP In Stock £325.83
7QK8 APC Rack PDU Basic Zero U 32A 230V In Stock £320.46
7QK8 APC Temperature and Humidity Sensor In Stock £133.14
7QK8 APC POWER CORD C13 TO C20 1.98m Black In Stock £52.05
7QK8 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £287.81
7QK8 APC Cable Managers (Qty 10) In Stock £35.34
7QK8 APC 2G Power distribution strip In Stock £645.98
7QK8 APC Rack PDU 2G METERED ZEROU In Stock £689.69
7QK8 APC Smart-UPS X 120V EXT BATTERY In Stock £930.12
7QK8 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £984.76
7QK8 APC 19" Rack LCD Console In Stock £1,385.59
7QK8 APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £84.15
7QK8 APC Power Cord Locking C19 to C20 3.0m In Stock £68.64
7QK8 APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.00
7QK8 APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £53.14
7QK8 APC NetShelter Zero U Accessory Mounting Bracket In Stock £66.29
7QK8 APC Replacement Battery Cartridge In Stock £393.07
7QK8 APC 1U Blanking Panel Kit In Stock £34.72
7QK8 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.96
7QK8 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.30
7QK8 APC Power Cable (pack of 6) 1.22m In Stock £87.46
7QK8 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,694.93
7QK8 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.94
7QK8 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £131.85
7QK8 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £101.73
7QK8 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £636.90
7QK8 APC Extended Warranty Service Pack Technical Support 1 Year In Stock £135.83
7QK8 APC Metered Rack PDU In Stock £846.52
7QK8 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £736.14
7QK8 APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £264.70
7QK8 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.44
7QK8 APC Switched PDU 10A 0U C13x16 In Stock £1,164.00
7QK8 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £671.74
7QK8 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,258.20
7QK8 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £162.29
7QK8 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,287.30
7QK8 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £81.93
7QK8 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £470.30
Type: UPS
Power Rating: 2.7kW
Brand: APC
Price Range Ex VAT: £1500+
