APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and network power protection. Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption. Smart-UPS feature a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
Intelligent battery management
Maximizes battery performance, life, and reliability through intelligent, precision charging -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics -
Cold-start capable
Provides temporary battery power when the utility power is out -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection -
High online efficiency
Reduces utility costs, generates less heat -
Intuitive LCD interface
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning -
SmartSlot
Customize UPS capabilities with management cards -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users -
Scalable runtime
Allows additional run time to be quickly added as needed -
Auto recognition of external batteries
UPS recognizes when external battery packs are attached and automatically adjusts runtime -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment -
Multiple switched outlet groups
Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding -
High frequency design
Reduces or eliminates bulky transformers resulting in lighter units for ease of handling -
StruxureWare Data Center Expert Compatibility
Discover and monitor PowerChute Agents via SNMP v1 or v3. Integrate SNMP Traps for timely notifications of UPS critical events -
Sequenced shutdown and reboot
Customize shutdown and reboot sequence of connected servers and UPSs
- APC Smart-UPS X 3000 Rack/Tower LCD - UPS - 2700 watt - 3000 VA
- UPS - rack-mountable / external
- Rack Size
- 4U
- 38.64 kg
- Input Wiring
- 1-phase
- Input Voltage
- AC 208/230 V
- Output Voltage
- AC 208/230 V
- Power Capacity
- 2700 watt / 3000 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 8 x power IEC 60320 C13 , 2 x IEC jumper , 2 x power IEC 60320 C19
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 6.3 min at full load
- Networking
- RS-232, USB
- Black
- Pricing Type
- APC Take-Back
- 17.8 cm x 48.3 cm x 43.2 cm
- 3-year warranty
- Height (Rack Units)
- 4U
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 208/230 V
- Input Voltage Range
- AC 140 - 280 V
- Frequency Provided
- 47 - 63 Hz
- Input Wiring
- 1-phase
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 208/230 V 47 - 63 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 645 joules
- Circuit Protection
- Circuit breaker
- Efficiency
- 98.5%
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 6.3 min at full load , 15.7 min at half load
- Recharge Time
- 3 hours
- Remote Management Interface
- RS-232, USB
- 1 x USB , 1 x RS-232 , 1 x EPO (emergency power off)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Serial cable , USB cable , Power cable 1.83 m
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, overload protection
- CSA, C-Tick, GOST, UL 1449, UL 1778, VDE, IEC 60950, EN 50091-2, IRAM, RoHS, EN 50091-1, FCC Part 15 A, REACH
- Pricing Type
- APC Take-Back
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years , Limited warranty - battery - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 55 dBA
- 17.8 cm
- 48.3 cm
- 43.2 cm
- 38.64 kg
- Shipping Width
- 58.6 cm
- Shipping Depth
- 63.3 cm
- Shipping Height
- 33 cm
- Shipping Weight
- 47.73 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £30.76 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £204.71 |
APC 1U Vertical Cable Organiser | In Stock | £126.14 |
APC 1U Horizontal Cable Organiser | In Stock | £56.26 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £54.29 |
APC Netshelter heavy duty shelf | In Stock | £142.83 |
APC Rackmount Rail Kit | In Stock | £91.22 |
APC Power cable - 2.4 m | In Stock | £85.34 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £302.01 |
APC 2-Post Mounting Kit for Smart-UPS | In Stock | £178.50 |
APC 3Yr Extended Warranty SP | In Stock | £322.69 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £327.62 |
APC Temperature and Humidity Sensor | In Stock | £132.19 |
APC Cable Managers (Qty 10) | In Stock | £36.89 |
APC 2G Power distribution strip | In Stock | £645.20 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,014.15 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £973.78 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £70.05 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £81.35 |
APC Power Cord Kit (6 ea) Locking C19 to C20 1.2m | In Stock | £153.80 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £55.29 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,498.11 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £59.73 |
APC Smart-UPS X 120V External Battery Pack Rack/Tower | In Stock | £674.88 |
APC 1U Blanking Panel Kit | In Stock | £35.27 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.44 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £49.47 |
APC Power Cable (pack of 6) 1.22m | In Stock | £90.09 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,743.67 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £70.10 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £131.99 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £647.80 |
APC Extended Warranty Service Pack Technical Support 1 Year | In Stock | £138.73 |
APC Replacement Battery Cartridge #143 | In Stock | £430.28 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £737.92 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,111.99 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £63.36 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £685.66 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,274.19 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,325.53 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £463.90 |
