Intuitive LCD interface provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
High frequency design reduces or eliminates bulky transformers resulting in lighter units for ease of handling.
APC Smart-UPS X 2200 Rack/Tower LCD recognizes when external battery packs are attached and automatically adjusts runtime.
Patent-pending operating mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
It provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. -
It reduces or eliminates bulky transformers resulting in lighter units for ease of handling. -
Auto recognition of external batteries
UPS recognizes when external battery packs are attached and automatically adjusts runtime. -
Predictive replace battery date
It dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning. -
Green mode
Patent-pending operating mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Energy meter
It provides actual kilowatt hours of usage for energy conscious users. -
Audible alarms
Audible alarms provide notification of changing flywheel conditions -
Pure sine wave output on battery
It simulates utility power to provide the highest degree of compatibility for active PFC servers and sensitive electronics. -
Multiple switched outlet groups
Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding. -
Wide input voltage range
Wide input voltage range is designed for harsh electrical environments to save battery life. -
Battery failure notification
It provides early-warning fault analysis on batteries enabling timely preventive maintenance -
High online efficiency
It reduces utility costs, generates less heat. -
LED indicators
LED indicators provide easy-to-read status of your utility power conditions, UPS and battery. -
Overload protection
It safeguards unit from damage by automatically turning it off in the event of a short circuit or overload. -
Cold-start capable
It provides temporary battery power when the utility power is out. -
Hot-swappable batteries
It ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced. -
Automatic restart of loads after UPS shutdown
It automatically starts up the connected equipment upon the return of utility power. -
Adjustable voltage-transfer points
It maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation. -
Adjustable voltage sensitivity
It provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications. -
Audible alarms
It provides notification of changing utility power and UPS conditions. -
Serial connectivity
It provides management of the UPS via a serial port. -
Scalable runtime
It allows additional run time to be quickly added as needed. -
Intelligent battery management
It maximizes battery performance, life, and reliability through intelligent, precision charging. -
Power conditioning
It protects connected loads from surges, spikes, lightning, and other power disturbances. -
Network manageable
It provides remote management of the UPS over the network. -
It provides the ability to adapt the power conditioner for optimal performance in specific power environments or generator applications.
- APC Smart-UPS X 2200 Rack/Tower LCD - UPS - 1.98 kW - 2200 VA
- UPS - external
- Rack Size
- 2U
- 37.3 kg
- Input Voltage
- AC 208/220/230/240 V
- Output Voltage
- 230 V ( 47 - 53 / 57-63 Hz )
- Power Capacity
- 1.98 kW / 2200 VA
- Output Connector(s)
- 8 x power IEC 320 EN 60320 C13 , 1 x power IEC 320 EN 60320 C19
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 9.8 min at full load
- Networking
- RS-232, USB
- 43.2 cm x 66.7 cm x 8.5 cm
- 3 years warranty
- UPS - external
- Height (Rack Units)
- 2U
- Black
- UPS Technology
- Line interactive
- Input Voltage
- Input Voltage Range
- AC 141 - 255 / 160 - 280 V
- Frequency Required
- 50/60 Hz
- Input Connector(s)
- 3 x power IEC 320 EN 60320 C20, power CEE 7/7 (SCHUKO), power BS 1363A
- Power Output Connectors Details
- Output Voltage
- Power Capacity
- 1.98 kW / 2200 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 645 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 9.8 min at full load , 25.3 min at half load
- Recharge Time
- 3 hours
- Remote Management Interface
- RS-232, USB
- 1 x USB , 1 x serial - RJ-45 , 1 x EPO (emergency power off)
- Expansion Slot(s)
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- 1 x serial cable , 1 x USB cable , 1 x power cable - 1.8 m
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, overload protection, automatic self-test
- CSA, C-Tick, GOST, UL 1778, VDE, IEC 60950, EN 50091-2, IRAM, RoHS, EN 50091-1, FCC Part 15 A, REACH
- Software Included
- Drivers & Utilities
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 55 dBA
- 43.2 cm
- 66.7 cm
- 8.5 cm
- 37.3 kg
- Shipping Width
- 59.6 cm
- Shipping Depth
- 86.9 cm
- Shipping Height
- 24.3 cm
- Shipping Weight
- 45.4 kg
