APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V
Quicklinx: 86CHWS00 Mfr#: SMX2200RMHV2U
Type: UPS
Power Rating: 2200VA
19 In Stock
£2,059.33 ex VAT
£2,471.19 inc VAT
Intuitive LCD interface provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
High frequency design reduces or eliminates bulky transformers resulting in lighter units for ease of handling.
APC Smart-UPS X 2200 Rack/Tower LCD recognizes when external battery packs are attached and automatically adjusts runtime.
Patent-pending operating mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Intuitive LCD interface
    It provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • High frequency design
    It reduces or eliminates bulky transformers resulting in lighter units for ease of handling.
  • Auto recognition of external batteries
    UPS recognizes when external battery packs are attached and automatically adjusts runtime.
  • Predictive replace battery date
    It dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Green mode
  • Energy meter
    It provides actual kilowatt hours of usage for energy conscious users.
  • Audible alarms
    Audible alarms provide notification of changing flywheel conditions
  • Pure sine wave output on battery
    It simulates utility power to provide the highest degree of compatibility for active PFC servers and sensitive electronics.
  • Multiple switched outlet groups
    Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • Wide input voltage range
    Wide input voltage range is designed for harsh electrical environments to save battery life.
  • Battery failure notification
    It provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • High online efficiency
    It reduces utility costs, generates less heat.
  • LED indicators
    LED indicators provide easy-to-read status of your utility power conditions, UPS and battery.
  • Overload protection
    It safeguards unit from damage by automatically turning it off in the event of a short circuit or overload.
  • Cold-start capable
    It provides temporary battery power when the utility power is out.
  • Hot-swappable batteries
    It ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Automatic restart of loads after UPS shutdown
    It automatically starts up the connected equipment upon the return of utility power.
  • Adjustable voltage-transfer points
    It maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation.
  • Adjustable voltage sensitivity
    It provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications.
  • Audible alarms
    It provides notification of changing utility power and UPS conditions.
  • Serial connectivity
    It provides management of the UPS via a serial port.
  • Scalable runtime
    It allows additional run time to be quickly added as needed.
  • Intelligent battery management
    It maximizes battery performance, life, and reliability through intelligent, precision charging.
  • Power conditioning
    It protects connected loads from surges, spikes, lightning, and other power disturbances.
  • Network manageable
    It provides remote management of the UPS over the network.
    It provides the ability to adapt the power conditioner for optimal performance in specific power environments or generator applications.
APC Smart-UPS X 2200 Rack/Tower LCD - UPS - 1.98 kW - 2200 VA
UPS - external
Rack Size
2U
37.3 kg
Input Voltage
AC 208/220/230/240 V
Output Voltage
230 V ( 47 - 53 / 57-63 Hz )
Power Capacity
1.98 kW / 2200 VA
Output Connector(s)
8 x power IEC 320 EN 60320 C13 , 1 x power IEC 320 EN 60320 C19
Lead Acid
Batteries Qty
1
Run Time (Up To)
9.8 min at full load
RS-232, USB
43.2 cm x 66.7 cm x 8.5 cm
3 years warranty
UPS - external
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
Input Voltage Range
AC 141 - 255 / 160 - 280 V
Frequency Required
50/60 Hz
Input Connector(s)
3 x power IEC 320 EN 60320 C20, power CEE 7/7 (SCHUKO), power BS 1363A
Output Voltage
Power Capacity
1.98 kW / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
645 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
9.8 min at full load , 25.3 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x USB , 1 x serial - RJ-45 , 1 x EPO (emergency power off)
Expansion Slot(s)
1 (total) / 1 (free) x SmartSlot
1 x serial cable , 1 x USB cable , 1 x power cable - 1.8 m
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, overload protection, automatic self-test
CSA, C-Tick, GOST, UL 1778, VDE, IEC 60950, EN 50091-2, IRAM, RoHS, EN 50091-1, FCC Part 15 A, REACH
Software Included
Drivers & Utilities
3 years warranty
Service & Support Details
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
55 dBA
43.2 cm
66.7 cm
8.5 cm
37.3 kg
Shipping Width
59.6 cm
Shipping Depth
86.9 cm
Shipping Height
24.3 cm
Shipping Weight
45.4 kg
Type: UPS
Brand: APC
Price Range Ex VAT: £1500+
